OKCamaros
Drives: 4 banger Diesel Join Date: Mar 2010
Independent Throttle Body?
I wus surfing on the web today and I came across this. I saw some pics of the LS1 guys running them on their cars. Just curious if its compatible with our cars also. whats the difference between this and the regular IM? what can you benefit with this set up? anybody here have this set up? Their a little pricey to they sell for $2-3k.
This would look great under the hood. wish I could afford one! lol Really don't know what its called eight stack? or Independent Throttle Body? |
Drives: 99 Camaro SS, 79 z28, 70 GTX Join Date: Oct 2009
ITB"s have been around for a while.. some are good some are not so good......
they bring their own nuances |
![]() ![]() ![]() ![]() Drives: 2010 camaro 2SS LS3 Join Date: Aug 2011
are they carbureted?
same as what you have now.. except for the linkage vs fly by wire....
its a throttle body per cylinder vs one big one.. just lets air in |
OKCamaros
#6 |
OKCamaros
#7 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2011 imperial blue SS, black 92 RS Join Date: Apr 2011
I would say do it if you enjoy changing rings and honing and or boring the cylinders on a regular basis.
2011 imperial blue SS/RS a6 12.43@112 vararam, tune, jba cats, magnaflow axle back, self ported tb, under drive pulley, NO headers, Stock tires. 1.87 60ft. Stock tires. SOLD :(
2000 1500 silverado extra cab SOLD :( 2017 Silverado 5.3 all stock 2004 5.7 GTO 78mm turbo |
#8 | |
looks pretty restricted to me. i still dont see where the injectors would mount |
#9 | |
thats an open debate... its allows you to run a huge cam without the issues associated with one.. but its a huge pia to tune and I'm not even sure they make them for the FBW tb.... I'd opt for the 102/102 combo but then again the newer LS7 syle one is kind of nice... its a tough call but.. I get pretty good response from my ported 102 combo.. |
#10 |
![]() Drives: 2010 2SS/RS IOM M6 Join Date: May 2011
Yup. Used for N/A gigantic cam speed density setups.
#11 |
![]() Drives: SS, CTS & SRT-4 Join Date: Aug 2009
No turbo either. ...unless you ran plumbing back to each TB, but good luck getting the pressure even across the banks, and I don't even want to think about what it would take to tune it... More hassle than even worth trying.
#12 |
#13 |
They help with idle and throttle response, because ITB setups are less sensitive to nasty things like intake port reversion. They'll sometimes generate more power over a Fast 90/90 LSX setup as well.
#14 |
The stick man
Drives: 2004 GTO - C5 'vert - SRX Join Date: Jul 2006
Not necessarily big camshafts, just the ones that match the combination.
This is a daily driver BMW with ITB system. ![]()
![]() PONY WARS |
| Cold Air intake, throttle body, headers, lots of questions. | shadowghost21 | Camaro V6 LLT Engine, Exhaust, and Bolt-Ons | 6 | 10-09-2011 03:59 PM |
| PORTED THROTTLE BODY and INTAKE MANIFOLD | ablackburn99 | Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons | 29 | 07-19-2010 04:16 PM |
| 95mm Wilson Throttle Body | Jim85IROC | V8 - Engine, Exhaust, Bolt-Ons, Tuning Equipment | 0 | 12-29-2009 09:17 AM |
