Old 10-13-2011, 10:32 PM   #1
ipimpthisc
Banned
Drives: @twinturbo, cammed, intrcooled@
Send a message via AIM to ipimpthisc
need advice , stay with stock block or ......
need advice from true learned folks...let me tell you the situation.
I currently have a stock block with a twin rear mount turbo set up. I am doing 9 psi..for about 650 rwhp. I want to go about 15 to 16 pounds of boost. Should I get new forged pistons, rods, and use my heads (which are beefed up with a good cam) or should i buy a good short block and use stock crank. I am really confused on which way to go. My concern is getting the best bang for my buck while achieving the goal. And durability of course is a major concern. I know you fellaz can lead me the right direction
ipimpthisc is offline   Reply With Quote
Old 10-13-2011, 10:50 PM   #2
casper sc/1ss/rs
casper sc/1ss/rs's Avatar
Drives: 2011 camaro ss vortech supercharged
650 is alot for a stock bottom end but its be done time after time i would recomend beefn it up a little but it would probley be ok if you didnt dog it all the time.
casper sc/1ss/rs is offline   Reply With Quote
Old 10-13-2011, 10:58 PM   #3
ipimpthisc
Banned
The turbos are much of a relaxed fit then a sc set up. I have a good cam, and I dont beat it up at all. I dont drag, and i dont hole shot like most do. I just like raw power from 60-160. I want about 1k hp so I need to know which is the best route. I like to embarrass super cars and exotics
Old 10-13-2011, 11:08 PM   #4
SSE 4 2SS
Boosted Moderator
SSE 4 2SS's Avatar
Drives: Bone Stock LS3
Personally, if you are looking for 1000 HP, RW or at the flywheel, I wouldn't use the stock block with forged internals, or the stock crank... I would have a built short block with the entire internal assembly of forged parts, and the block built/designed to handle that kind of power.... It should be sleeved, either wet sleeved or dry sleeved and fully studded with ARP studs, etc...
60-160 pulls with that kind of power are hard on the components...
Old 10-13-2011, 11:34 PM   #5
ipimpthisc
Banned
What are good companies to start looking for a good price sb for this set up.
Old 10-13-2011, 11:39 PM   #6
CC Performance
Drives: 99 Camaro SS, 79 z28, 70 GTX
We offer a deal at $4275 for the bottom end from one of the top 3 leading LSx engine builders in the world
I would definitely forge it no matter who you chose
CC Performance is offline   Reply With Quote
Old 10-13-2011, 11:50 PM   #7
FloMoCamaro
FloMoCamaro's Avatar
Drives: 2010 Camaro SS
Call Lingenfelter
FloMoCamaro is offline   Reply With Quote
Old 10-14-2011, 12:14 AM   #8
SSE 4 2SS
Boosted Moderator
SSE 4 2SS's Avatar
^^^This is a good one... I went with ERL... I've heard good things about several of the vendors on this site...
Old 10-14-2011, 11:54 AM   #9
JLE58
Drives: CGM,twin turbo, cam 2010 SS/RS
HKE is known as one of the best if not the best LSX engine builders in the world for sure. These guys have been building the baddest lsx motors since LS1's were cool. Ask 50 people that has been dealing with LS engines for a long time to give you their top 3 LS engine Builders and HKE will be on every list.
JLE58 is offline   Reply With Quote
Old 10-14-2011, 12:28 PM   #10
ipimpthisc
Banned
wow fellas thank you for the input. When I get my ducks in a row I will look at these options, and choose one for sure. meantime i will be in one of these trying to figure it out
Old 10-14-2011, 12:34 PM   #11
JLE58
Hey I Want one!!
Old 10-14-2011, 12:40 PM   #12
HufferSS
I Wanna Go Faster!!
HufferSS's Avatar
Drives: 2011 2SS Synergy Green M6
I would not retain the LS3 block or the 4 bolt heads....I'd definitely go with an LSX block for a low buck option or something like an RHS or an ERL block on the high end.
You should plan on probably 10k minimum and then more on the clutch or trans, rear axle, fuel pumps etc that a 18psi build is going to require.
HufferSS is offline   Reply With Quote
Old 10-14-2011, 01:01 PM   #13
JLE58
IMHO 16 psi it nothing for a forged ls3 block These ls3 blocks are very strong.
Old 10-14-2011, 01:08 PM   #14
HufferSS
I Wanna Go Faster!!
HufferSS's Avatar
Opinions vary I guess but 4 head bolts per cylinder would worry me at that boost level. There are probably a lot of things you could get away with for a while but I'd rather just do it right the first time.
DIY: LS3 Camshaft Install (a lot of pictures, may take a moment to load) robertway Camaro DIY & HOW-TO instructions & discussions 313 12-16-2023 07:53 PM
First Ever DOUBLE DIN (monitor / screen) NO LONGER AVAILABLE**** Hess RS Audio, Video, Bluetooth, Navigation, Radar, Electronics Forum 992 06-13-2013 12:13 AM
2010 LS3 stock short block $2,500? nuptualnemesis V8 - Engine, Exhaust, Bolt-Ons, Tuning Equipment 4 06-26-2011 12:24 AM
ALL Our Camaros are GM Prefer Pricing (old Supplier Pricing) at MacMulkin Chevrolet! MacMulkin Dealer Camaros for Sale 0 01-20-2010 07:40 PM
