10-19-2011, 11:30 PM | #1 |
Drives: 10 LS3 2SSRS IOM,21 ZLE Wild Cherry Join Date: Aug 2009
EPDM (brake fluid rated) Clutch reservior line source needed
Does anyone know of a source for purchasing the "EPDM" type clutch fluid line for between the Clutch Master Cylinder and the separate reservior? Looking to buy 4' of it... more if needed for minimum sale (can always sell remainder to a local club member in need)
I've been checking all over and keep getting nowhere. Looks like we need 1/4" inside diameter hose? Already did reservior install long ago.... just changing to the correct one that holds up to brake fluid. Any help would be appreciated..... last component I need. Redoing tranny , but problem points to hydrolic system. Problem reared it's head after changing tranny fluid to "Be Safe". I found it that it's not uncommon for a mild tranny problem to get much worse with new fluid. Theory is the dirty fluid was slowing down the syncros, hence making up for syncro wear. And the new fluid has fresh detergents. Clutch appears perfect without removing - not a hint of clutch dust. So anyway, now I'm replacing all hydrolics even if they look good - much cheaper than high performance transmissions and clutches. NEW Slave cylinder, master cylinder, Tick Performance clutch stainless steel clutch line and 4' bleeder line for a 100% bleed system. $$$ extra, better than $$$$ repeat
860 RWHP 924 RWTQ,TVS2300 10/14 OD 2.75/NW 102mm,RDS/FLOWED "109" SHOT/LPE NCC NLP spoiler/GM splitter/Torq HE-fans/oil coolers/IC1000cc Squash twins,GT9,Coil Covers,Mats,Pedals/ADM Gauges,Race Scoop/Trunions DDS CVs,Carbon F DS/RPM L6/LPE 9.5 3.73/Pedders HD bushes,align kit RB 2-piece rotors,S/S Lines,Hawk HPE Pads/Forgeline SP3P/Weld RTS Ceramic ARH 2" LT/3" X-pipe,Corsa Touring/BMR TA,Toe,LCA,DS Loop StreetSlayer BC3/MTI Shifter-Trans mt/Hotchkis CB/Monster CC/SJM LineLock PFADT Coil Overs,Sways,Links,Mounts,SF Bushes,Camber Kit LPE Brotherhood . Last edited by Blue70SS; 10-19-2011 at 11:48 PM. |
10-20-2011, 06:58 AM | #2 |
Try your local semi truck parts store, that's where I ended up getting mine.
10-20-2011, 07:31 AM | #3 |
Sent you a PM. BMW part number 21521163714 which comes in a 38" length. If you need 4' of it you need to have the BMW parts guy order quantity of 2, hose will then come in a 76" length.
Ed M.
RJT 2SS/RS, AAM 3.70's, MTI Sway Bars, Shifter & SS brake lines, ZLI calipers, rotors & pads, BMR Trailing & Toe Arms, rear cradle & diff bushes, Pedders XA's, Camber/Toe eccentrics, Radius arm inserts, GTO clutch reservoir, LS9 cam, Comp valve springs, Melling 10296 oil pump, CR5 timing chain, LS6 damper, CAI Cold Air Intake, ARH LT headers w/HF cats, GMPP touring axle back, Elite Engineering Catch Can, Forgeline 20x9.5 & 20x11 DS3 whls, 275/40/20 & 315/35/20 tires, 2011 Convertible spoiler, 1LE front spoiler, Lloyd "SS" Floor Mats, GM Camaro Trunk Mat, wrapped console & Grant steering wheel.
10-20-2011, 10:55 AM | #4 |
Thanks!
860 RWHP 924 RWTQ,TVS2300 10/14 OD 2.75/NW 102mm,RDS/FLOWED "109" SHOT/LPE NCC NLP spoiler/GM splitter/Torq HE-fans/oil coolers/IC1000cc Squash twins,GT9,Coil Covers,Mats,Pedals/ADM Gauges,Race Scoop/Trunions DDS CVs,Carbon F DS/RPM L6/LPE 9.5 3.73/Pedders HD bushes,align kit RB 2-piece rotors,S/S Lines,Hawk HPE Pads/Forgeline SP3P/Weld RTS Ceramic ARH 2" LT/3" X-pipe,Corsa Touring/BMR TA,Toe,LCA,DS Loop StreetSlayer BC3/MTI Shifter-Trans mt/Hotchkis CB/Monster CC/SJM LineLock PFADT Coil Overs,Sways,Links,Mounts,SF Bushes,Camber Kit LPE Brotherhood . |
Similar Threads | ||||
Sticking clutch pedal issues - Tick Performance feels your pain! | Matt@Tick | V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6) | 185 | 12-22-2018 12:21 PM |
I want a new clutch, you too????? Sign here | tjbusa | V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6) | 370 | 08-10-2013 03:27 AM |
ZR1 TWIN DISC CLUTCH KIT or Mcloed RXT twin disc clutch | qtr-camaro ss | V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6) | 10 | 06-07-2011 10:46 PM |
What exactly burns the clutch on an m6? | DarkneSS | 5th Gen Camaro SS LS LT General Discussions | 49 | 04-15-2011 10:55 AM |
Camaro 2010 Issues | Tim's.2010.Camaro.SS | Camaro Issues / Problems | Warranty Discussions | TSB and Recalls | 57 | 06-04-2010 09:27 AM |
