Old 10-21-2011, 05:26 PM   #1
=Stephens=
=Stephens='s Avatar
Drives: 2011 LS
Droid Torque app
Check this out, you can download the free version or buy the Pro app for 4.95 to your droid. And get the bluetooth OBD II module and then your car will send the info to your phone.
Revs of rpms
Speed
Acceleration
Coolant temp
Oil Temp
MPG
It also has a code reader to tell you if you have any errors from the CEL.
And you get a timer to do a 0-60, 0-100, and 1/8 mile and 1/4 mile times
I got the OBD bluetooth from Amazon. $29.95. There are several different sellers on Amazon, get the one from "Goliton" I got one and it wasn't compatible with my car.
http://www.amazon.com/gp/product/B005C6KIVS
Here are some screen shots I took of them.
=Stephens= is offline   Reply With Quote
Old 10-21-2011, 07:07 PM   #2
CGMLT
CGMLT's Avatar
Drives: 2019 2SS 1LE
I just picked up my Electrify!!! Will have to get this App!!!!!
Wooo Hooo... 2019 2SS 1LE!!!
CGMLT is offline   Reply With Quote
Old 10-21-2011, 07:28 PM   #3
steeleshark2
steeleshark2's Avatar
I have it and it works awesome. Make sure you download the track recorder and shift light add on for Torque. Also, if you have a small flat head screw drive, gently push in on the top of the OBD2 port to release it from the hangar and tie wrap it under the dash so you do not accidentally hit it with your foot!!
Old 10-21-2011, 09:10 PM   #4
=Stephens=
=Stephens='s Avatar
Drives: 2011 LS
Thanks for the tip. I will do that.
Old 10-21-2011, 11:18 PM   #5
steeleshark2
No problem!!
Did you add in the extra gm pids? If not,on the main menu of torque, hit your menu key on the phone, go to settings, scroll to the bottom, select Manage extra Pids, Hit menu key on the phone again, select add predefined set, select the section that has GM in hit. Have fun!!
Old 10-22-2011, 12:42 AM   #6
=Stephens=
=Stephens='s Avatar
Drives: 2011 LS
not yet, just got my bluetooth module today. Still messing around with it
Old 10-22-2011, 01:38 PM   #7
dcarlos55
dcarlos55's Avatar
Drives: 2017 HBM A10 ZL1
I'm hoping my bluetooth scanner shows up today. I can't wait to play with this.
My build thread http://www.camaro5.com/forums/showthread.php?t=224342
Go is good. Stop is better.
dcarlos55 is offline   Reply With Quote
Old 10-22-2011, 02:53 PM   #8
cowboy1948
cowboy1948's Avatar
Drives: 10 LT2/RS-08 SILVERADO-05 COBALT
Question
Need help here with this Lg Phoenix android phone and the torque app.I when to the market for apps on my phone. Went to categories then to transportation and found the widget for torque lite obd2 & car app and down loaded it and the screen says it is installed. Went the choose app to place on home screen it says,torque big, torque small, torque odb toggle.
I entered torque small, it went to a screen and told me application not installed to go to market place and buy it. I enter the torque toggle an it put it on the home screen But all that does nothing. So went back an got the free torque obd check So why can i not get the one i paid for to work?
or is the free one OK? It has a lot of gages to select from. So if i keep the free one then all i need is the obd blue tooth for the car? help me out here???? Does all this make sense??
Retired
cowboy1948 is offline   Reply With Quote
Old 10-22-2011, 04:46 PM   #9
Captain Awesome
Drives: 2010 Camaro 2SS/RS
Does that huge bluetooth dongle get in the way of your legs?
Captain Awesome is offline   Reply With Quote
Old 10-22-2011, 05:48 PM   #10
cactuseater
Drives: .
Hmmmm.... I'm interested in this one!
cactuseater is offline   Reply With Quote
Old 10-22-2011, 05:50 PM   #11
cactuseater
Drives: .
@ =STEVENS= ......
Holy crap, you did a 98 second quarter mile ! Just kidding with ya buddy, thanks for the pics!
Old 10-22-2011, 06:09 PM   #12
=Stephens=
=Stephens='s Avatar
Drives: 2011 LS
Lol, I drove the distance of a 1/4 and would be 98 seconds.
Cowboy, did you restart your phone after you installed it? Its just like a computer, and needs a restart after installed.
The difference from the free one to the paid one is, the paid one has alot more option and more details for you about your car. Your paid one should work just fine. And yes, all you need is the bluetooth obd module to make this work.
Old 10-22-2011, 06:30 PM   #13
cowboy1948
cowboy1948's Avatar
Cool
I LL try it. Thanks
Retired
Old 10-22-2011, 07:20 PM   #14
steeleshark2
The bluetooth is a little in the way but there is a fix.Use a small flat head screw driver to gently push the tab at the top of your OBD2 plug to take it out of the bracket. Then tie wrap the plug with the bluetooth module under the dash. Took 5 minutes and it is completely out of sight.
ProTorque Converters - FREE Shipping! tbyrne Transmission / Driveline 0 01-07-2010 01:36 PM
Cam Headers Intake Tune 446 RWHP 430 RWTQ JANNETTYRACING Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 72 11-25-2009 04:09 PM
