Old 10-22-2011, 12:05 PM   #1
ssmike
BL1ZZRD
ssmike's Avatar
DIY, trailing arms outer bushing removal
I just did the outer trailing arm bushing removals on my '10 SS! Here we go:
1) Jack up rear end and remove wheels. I used 2 jack stands, 1 on each side ahead of the wheel well.
2) Using an 18mm socket and open end wrench remove the outer trailing arm bolt form the lower control arm.
3) Using a fresh blade in a utility knife remove the outer portion of rubber on both sides so the bushing will slide though and there's room for the puller to secure itself on the metal. This IMO is the hardest part of the whole proccess! It's a real PITA!
4) Obtain a 2 arm 3 1/2" reach puller. Either rent from Autozone (or your favorite auto parts store) or buy one. Autozone has fee rental so that's what I did!
5) Use a 3/8" washer and nut on the end of the puller to push on the bushing during removal
6) Install the puller onto the bushing so it pushes the bushing out toward the front of the car. It's a tight fit but it will work if you're carefull!
7) Start tightening the puller and watch the bushing come out like butta!
8) DONE!
Here's some pics!
Old 10-22-2011, 12:23 PM   #2
2SSRS@Gen5diy
2SSRS@Gen5diy's Avatar
Nice work looks like fun, what did you replace it with? Did it help the handling?
Old 10-22-2011, 01:29 PM   #3
ssmike
BL1ZZRD
ssmike's Avatar
I'll be installing BMR bushings on Monday when they arrive! I already have BMR trailing arms but I didn't know about having to replace the bushings too! I'll let you know how they work after a couple burn outs! Hopefully no more wheel hop!
Old 11-04-2011, 01:23 PM   #4
mgoodbar
White 2ss, LT, CAI, Tune
Drives: 2010 L99
hey I will be doing this as well after income tax... post some pix up of the install please
mgoodbar is offline   Reply With Quote
Old 05-11-2012, 08:01 PM   #5
ParisTNDude
Owning SSes for 50 Years
ParisTNDude's Avatar
Drives: Sharkskin Grey LT1
Thanks for your post. I took your puller idea and used it to install my Granatelli trailing arms and BMR outer bushings and it worked like a champ. I honestly expected the puller to pop off of the mounting bracket since I had to crank so hard on the puller bolt to move the bushing, but it didn't. Like you said: comes out like butta!
The new ride: 2023 Camaro, LT1, Sharkskin Grey
Previous Performance Cars:
1966 Chevelle SS 4M, 2010 Corvette 6M
1968 Dodge Charger R/T Auto 2012 1SS 6M
1982 Corvette Auto 2010 1SS 6A
1984 Corvette Auto 2016 2SS 8A
1999 Camaro Auto 2017 HBM 1SS 1le
2002 C5 Corvette 6M 2018 2SS
2006 Corvette Auto 2023 Camaro LT1
ParisTNDude is offline   Reply With Quote
Old 05-11-2012, 10:11 PM   #6
Inuyashas_Brother
Inuyashas_Brother's Avatar
Drives: '10 Camaro LS - M6
Thanks for the pics!
Inuyashas_Brother is offline   Reply With Quote
Old 05-11-2012, 11:49 PM   #7
Dznts
Anabolic Connoisseur
Dznts's Avatar
nice write up, this is my next mod as well!
Old 05-12-2012, 08:50 AM   #8
SGOS252382
SGOS252382's Avatar
Drives: 2010 Camaro 2SS/RS
Nice
And Tuffy's Auto in Fort Myers charges $450.00 to remove that bushing.
Old 03-09-2013, 07:16 PM   #9
CamaroSSRS11
Drives: 2017 White SS 1LE
lifesaver
Thank you very much ssmike, your tip to use the two-claw puller saved me a lot of frustration! I ordered the tool sold by PHADT that was just for pulling that bushing and it didn't work at all! It would have required removal of the entire control arm to allow enough room. Your way cost less than a dollar at Lowe's for the washer and nut!
As for the benefit of the trailing arm upgrade, I highly recommend it! I did this along with a chassis brace from Hotchkis and wheel hop during hard launching has completely been eliminated! I hope to try out both on a autocross or road course soon!
CamaroSSRS11 is offline   Reply With Quote
Old 03-09-2013, 07:27 PM   #10
PQ
Booooosted.
PQ's Avatar
Drives: 2010 Supercharged SS
I did mine the hard way. With some thread stock, a hole cutter and some washers and nuts.
Got it on video with no blood.
I like your way MUCH better.
Old 03-09-2013, 11:21 PM   #11
Merc
In The Circle
Merc's Avatar
I used a propane torch and burned those two out. Great idea.
Old 03-09-2013, 11:23 PM   #12
PQ
Booooosted.
PQ's Avatar
I remember that.
Old 03-11-2013, 04:37 PM   #13
Jason@JacFab
Drives: 2016 1LT RS Camaro; 72 Chevelle
Send a message via AIM to Jason@JacFab Send a message via MSN to Jason@JacFab
Hmmm I've got a set of BMR bushings sitting on my desk that I never installed with the trailing arms because it looked like it would be more of a PITA than it would be worth vs the benefit of installing them. Perhaps I will consider this...
Jason@JacFab is offline   Reply With Quote
Old 03-11-2013, 07:16 PM   #14
LS3 SS
Drives: 2010 Cyber Grey Camaro SS (LS3)
I definitely want to try this; do you need a press or any specialty tool to get the new bushing in?
LS3 SS is offline   Reply With Quote
Trailing arm outer bushing removal question? ssmike Suspension / Brakes / Chassis 68 07-23-2021 07:39 PM
BMR 1.4" drop springs, sway bars, pro bushing kit, trailing arms, toe rods install. SUX2BU Suspension / Brakes / Chassis 22 05-08-2011 06:27 PM
DIY - Spohn Trailing Arms and Pedders TA Knuckle Bushing Install Jaysin Camaro DIY & HOW-TO instructions & discussions 0 01-20-2011 01:16 PM
LMPerformance, Spohn Camaro 2010 Tubular Rear Trailing Arms w/ Polyurethane Bushing LMPerformance V8 Bolt-Ons & Tunes 3 10-19-2009 03:33 PM
