![]() Drives: 2012 1SS Delivered! Join Date: Aug 2011
Brake caliper paint?
Wondered how to prep whatever the material is for the brake calipers? Use brake cleaner only or lightly sand?
knows 2 facts about ducks
If you get a G2 caliper paint set it comes with everything you need. But I believe you need to clean with brake cleaner and then sand and such, but I'm not sure.
#3 | |
![]() ![]() ![]() ![]() Drives: 2SS RS Join Date: Mar 2010
That's what I used. It has the brake cleaner in it. Cover up the hoses and stuff you don't want the spray to get on, hose it down, then wipe it down with an old t shirt. I didn't sand anything. Turned out great. Do all four at the same time, when you get done do another coat starting over with the caliper you started with. It really settled down flat and shiny.
Livernois 2C cam and tune, LS3 conversion, Roto-Fab intake, Kooks headers, DSS driveshaft and axles, BMR suspension parts, VMax ported throttle body, Whipple blower. (623hp).
dey see me rollin
Drives: the magic school bus Join Date: Feb 2011
I didn't sand and it came out great. Nor did I stop between coats but the time spent between calipers was enough to dry. I went from one wheel to the next until I made about 2 complete rounds and used my third to touch up any areas. I used the G2 paint. If you're getting it, yes the paint provided is more than enough to paint your calipers [you're not asking now but you will later].
| Washing/Detailing for Newbies | MRK III Z28 | Cosmetic Maintenance: Washing, Waxing, Detailing, Bodywork, Protection | 123 | 02-05-2024 09:55 PM |
| Hawk Performance Brake Pad "Updated" | KILLER74Z28 | Suspension / Brakes / Chassis | 34 | 05-04-2016 11:11 AM |
| GM bulletin on Perceived Paint Mismatch on Door and Quarter Panel Paint Appearance | Tran | 5th Gen Camaro SS LS LT General Discussions | 114 | 04-16-2012 03:04 PM |
| ROTORA BIG BRAKE KITS 4-12 PISTONS/ 15" & 16" ROTORS SPECIAL | ADKINS PERFORMANCE | Suspension / Chassis / Brakes | 0 | 08-03-2010 12:08 PM |
| G2 caliper paint | tradosaurus | Suspension / Brakes / Chassis | 2 | 05-15-2010 12:03 AM |
