Old 10-26-2011, 09:31 AM   #1
JANNETTYRACING
JANNETTYRACING's Avatar
JRE SCT CUSTOM TUNE INSTRUCTIONS V3
This has been a Tremendous Program and has and is Working Extremely Well, we have several hundreds of Happy Customers with our Tunes.
With customer feedback and lack of info in Tune requests I have revised the instructions again in an attempt to make things go even smoother than they already do.
JANNETTY RACING CUSTOM TUNE INSTRUCTIONS
When you Purchase an SCT X3 Hand Held Tuner from me you get 1, 93 OR, 1, 91 Octane Tune For Free 2010/11/12 Camaros Only, for your simple bolt on mods, exclusions apply for cams, superchargers and nitrous and other vehicles.
Additional Tunes with minor changes are available AT THE TIME OF PURCHASE For 50.00 Each, i.e. Second tune for 91 Octane.
Your new SCT X3 will come to you Blank, You will need to connect the device to your car and Upload Stock tune file, here is how, plug the device in to your OBDII port, select Program Vehicle, Using the left arrow scroll left to UPLOAD STOCK, it will prompt you to turn on the key, do so and hit select.
Your tuner came with a disc with Free Software called SCT Device Updater software, install this in your home or laptop computer Before you connect the device to your computer.
Then After you install and OPEN SCT Device updater software, you can connect your X3 to your computer, Drivers should install automatically, then Get Stock File, Click Browse, Find your Desktop and Click Save.
Go to your Desktop, there will be 3 files, Select the one with Your VinNumber.sul and email it to me tedj@jannettyracing.com along with your Full name, Address phone numbers, And all vehicle information Year, Make, Model, Engine, Trans, List of Performance Modifications and Preferred Octane ie. 93 or 91.
PLEASE RE READ LAST STEP, I CANNOT TUNE YOUR CAR WITHOUT THIS INFORMATION, EVERYONE SEEMS TO FORGET OCTANE REQUIREMENT.
Then I will send you back a custom tune file for your mods.
When you receive a response, Save the file to your desktop, it will be, YOUR NAME JRE TUNE.cef
Again open SCT Device Updater, Then, connect your X3 tuner, select Load Custom Tune File, Browse to your tune file Select it, then select a position 1, then name it anything you like, i.e. JRE TUNE, click on program, you will see the progress bar at the bottom go green, then exit when finished.
Connect to your car, Select Program Vehicle, scroll left to Custom Tunes, Select JRE tune and follow the on screen prompts.
I have developed Dyno Proven tunes for all of the Product I sell, So Unless I instruct you to do so Datalogging will NOT be necessary.
If I instruct you to Datalog your car, The best way I found is to use a laptop on the seat, First Open the LiveLink Software then connect the X3 to your laptop, then connect the X3 to the OBDII Port of the car, Then Hit the connect button, a list of PIDs will come up, you will have to scroll through them selecting the Items below.
Even thought they may not be named exactly as I listed them, I want you to select the following, but try not to select anything Not listed or doubles of any of the items listed.
You may have to test several PIDs to see which ones work best or work at all on your car.
Once you find a list that works well Save Configuration file for future use.
Engine RPM - RPM
ECT engine coolant temp – ecteng clt tmp
TPS throttle position or pedal position – acc pdl pos 1s
IAT intake air temp or Air intake temp – intk Airtmp
MAF Mass Air flow Hz – Maffre 125
TIMING spark cylinder 1 – ign Tim Adv4#1cyl
KNOCK RETARD – knk ret
Vehicle speed Kph–?
Short Term Fuel Trim bank 1 – stf tri b1
Short Term Fuel Trim bank 2 – stf tri b2
Long Term Fuel Trim bank 1 – ltf tri b1
Long Term Fuel Trim bank 2 – ltf tri b2
Pleas ONLY Select the PIDs Listed, Extra PIDs Slow Down Datalogging and give me useless information.
Names can vary from computer to computer but you get the Idea.
Once you have your PIDs configured and working, While NOT logging you can go to File/save LiveLink Configuration, for future Logging.
Go find a open road somewhere, 1/2 mile or so long would be great, from a stop drive the car 1/4 throttle up through the gears normally shifting at about 4500 RPM Paddle shift works best on Automatic trans cars.
Then repeat at about 1/2 throttle to 5500 RPM Speeding is not recommended or necessary 1st and 2nd gear are fine if you do not have the room.
Stop, and Save Datalog As to your desktop.
Email me the log files along with your Full name, Address phone numbers, And all vehicle information Year, Make, Model, Engine, Trans, and list of performance modifications, and any Comments you might think are helpful.
PLEASE RE READ THIS STEP, I CAN NOT REFINE YOUR TUNE WITHOUT THIS INFORMATION.
Thanks, Ted.
If you have other questions about SCT this is the entire FAQ section http://www.sctflash.com/support/inde...goryid=3&nav=0
www.jannettyracing.com
Celebrating 39 years Performance parts, Installation, Fabrication, Dyno tuning, Remote custom tuning, and alignments. 203-753-7223 Waterbury CT. 06705
email tedj@jannettyracing.com
Official 1/4 Mile (V8) 2010+ Camaro Fast List Merc Dragstrip and Launch Techniques Discussion 3656 11-01-2025 01:41 PM
Custom Tune and Warranty Issues Black2011SS Tuning / Diagnostics -- engine and transmission 30 11-22-2011 03:37 PM
JRE Tune BLKSS1 Tuning / Diagnostics -- engine and transmission 6 09-24-2011 09:55 AM
Calling 2010 Camaro Owners - Get a free custom dyno tune! SCT V8 Bolt-Ons & Tunes 9 09-03-2009 11:23 AM
LS3 goes 11`s Bonestock! GMRULZ Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 28 12-08-2008 09:10 PM
