Old 10-26-2011, 10:33 AM   #1
seminolejon
seminolejon's Avatar
Drives: 2011 2LS V6
Plastic tapping sound from under passenger dash
At least that's where I think it's coming from. It's driving me crazy. Has anyone else had this happen? Sounds like something very small. I've pressed on everything I can think of. It must be under the dash.
seminolejon is offline   Reply With Quote
Old 10-26-2011, 10:36 AM   #2
nancygrl
雪の玉
nancygrl's Avatar
Drives: '22 Z71 RST Silverado
How about something rattling inside the glove box? I've got a bunch of stuff in there and when I open the glove-box it stops. Just haven't gotten to straightening out the glove box yet, something else always comes up and I forget to do it.
nancygrl is offline   Reply With Quote
Old 10-26-2011, 12:40 PM   #3
Chevrolet Customer Svc
Drives: GM Vehicles
Hi seminole, have you had the time to have your dealer take a look at the vehicle or are you looking to take care of this yourself? It should be a rather quick process for them to diagnose and resolve this issue for you so you can be noise free roaring down the road. Let me know how you want to proceed with this. I'd like to help you if I can.
Jeff Morris, Chevrolet Customer Service
Old 10-26-2011, 01:53 PM   #4
Jagerday
Jagerday's Avatar
Drives: 2010 RJT SS/RS LS3
Seminole...I have something that sounds similar. It almost sounds like the front passneger tire is throwing up rock into the wheel well. But it only does it for like 20 seconds after start up and than its gone. Is this what your talking about?
By the way...Scalp 'em Noles
20% Tint - Color match Bowties - Pypes Pype Bomb Axle Back System - Apex Skip Shift Eliminator - GM OEM Splash Guards
Jagerday is offline   Reply With Quote
Old 10-26-2011, 04:11 PM   #5
steel insane
steel insane's Avatar
Drives: 2012 2LT Black (Vengeance)
whatever you do, don't feed it!
steel insane is offline   Reply With Quote
Old 10-26-2011, 04:18 PM   #6
wise
wise's Avatar
Drives: 1SS/1LE
I hear the same thing every morning I take off in my car. It usually quits by the time I make it out of my neighborhood, lasts around a minute. I don't have much in my glovebox, just the owners manual and insurance info, and I always make sure it's closed all the way when I open it, so I know that's not it.
wise is offline   Reply With Quote
Old 10-26-2011, 05:08 PM   #7
Caspers2SSRS
Caspers2SSRS
Drives: Summit White 2010 2SS/RS Camaro
Member of Fords "Function over Form" design team............taking a closer look and listening to a few others griping.
Caspers2SSRS is offline   Reply With Quote
Old 10-26-2011, 06:30 PM   #8
chriscrash37
Drives: 2010 Camaro 2ss
It's a dealer fix ... take it in.
chriscrash37 is offline   Reply With Quote
Old 10-26-2011, 08:44 PM   #9
rydahog
rydahog's Avatar
Drives: camaro ss
Seminolejon, i just had a similar situation. I dropped the glove box, take it off hinges, above the glove box is the plastic cover for the onstar,and battery, this cover was missing a screw..allowing the cover to just fall enough onto the top of glove box when it was closed..making a tapping sound.. give that a try..hope it helps. maybe its just a loose screw? good luck..ryd
rydahog is offline   Reply With Quote
Old 10-26-2011, 11:56 PM   #10
seminolejon
Drives: 2011 2LS V6
I believe I'll take it into the dealership. Thanks!
Old 10-27-2011, 05:25 AM   #11
cuspid
Drives: 04 z06 yellow
I had a monte carlo a few years ago with a noise that was driving me crazzzzzzy and was told by the tech "What do you expect a cadillac" I even got the owner involved. I found myself I had the parking brake cable rubbing against the fender -
cuspid is offline   Reply With Quote
Old 11-30-2011, 07:56 PM   #12
bballjeff2
Drives: 2011 1LT RS Silver
seminolejon - I have the same issue. There is a plastic tapping sound coming from the passenger side of my dash. It seems to get worse in cold weather. I have taken it to the dealer 3 times and they have yet to find the cause. Were you able to pin down the source?
bballjeff2 is offline   Reply With Quote
Old 12-01-2011, 02:38 AM   #13
AzItaliaSS
AzItaliaSS's Avatar
Drives: 2010 2ss RJT LS3 GONE....
every now and then I hear something as well I have to admit, mostly as I start rolling down the street pulling out of my area. this thread is making me think now.
AzItaliaSS is offline   Reply With Quote
Magnaflow Exhaust Systems In Stock! | Sound Clips+Dynos | Special Offer | FREE S&H!!! AJ@ECSMotorsports V8 Bolt-Ons & Tunes 178 11-20-2010 10:02 PM
Tapping sound from trunk area eclipsen Camaro Issues / Problems | Warranty Discussions | TSB and Recalls 41 06-15-2010 09:39 PM
Surround sound help thejushinator Off-topic Discussions 12 11-07-2009 09:49 PM
Exhaust sound bulldog Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 13 07-07-2009 02:43 PM
Shifter makes a glitch sound in the dash? edog V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6) 17 06-10-2009 08:42 AM
