USAF retired! Thank God!
Drives: 2011 1SS, 1LT red,1LT/RS SGM 98Z28 Join Date: Jul 2011
Which clutch are you big HP guys runnin?
So what is avail out there for 600+ rwhp cars, eventually will be up to 750+ in a year of so.
What are you running and how do you like it. My car is not a DD and I dont plan on taking it to the strip too often.
Boosted Moderator
Drives: Bone Stock LS3 Join Date: Sep 2009
Bull...
I'm running the ACT twin disc rated for 1400 ft/lbs and it's SFI rated... Had a little trouble with it at first, but after ACT made an adjustment to it, It's awesome...
Horsepower is how fast you hit the wall. Torque is how far you take the wall with you. “If everything seems under control, you're just not going fast enough.” Mario Andretti If you can turn, you ain't going fast enough... |
Drives: All GM Performance Join Date: Jul 2011
For the 2010+ Camaro, Monster is our best selling brand of single disc clutch: http://www.tickperformance.com/brand...er-Clutch.html
...and if you're interested in stepping up to a Twin Disc, the LS9X by Katech is what I'd suggest for your setup: http://www.tickperformance.com/produ...utch-Kit-.html We've gotten very good feedback from customers using both Monster's higher level of single disc clutches, and the LS9X! Best of luck. |
I Wanna Go Faster!!
Drives: 2011 2SS Synergy Green M6 Join Date: Apr 2011
I have an RHS/Hendrix twin carbon clutch in my car.....it is bar none the best clutch I have ever driven in a high horsepower car. It drives better than stock, no chatter or slipping of any kind and takes 4k rpm launches like it were candy.
That's 4k RPM launches with a Whipple so...probably 600 ft/lbs of torque at launch on a 4k lb car. It's expensive.....but it's an install it and forget about it clutch. |
#5 | |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2010 camaro Join Date: Aug 2009
#6 | |
I Wanna Go Faster!!
I really HATE to give up my M6 but the direction I am going the 4L80 just makes more sense. I ordered it up from RPM today...to quote them...this is the baddest of the bad when it comes to an 80e. Best of everything they sell. Huffer2.0 is going to be disgusting... tranny is just the beginning.
#7 |
Thanks for the input, i am looking at the level 5 Monster but wanted to get others opinions on monster and also on what else is out there. I want the best i can get.
#8 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2010 Camaro SS/RS 427ci Join Date: Jul 2009
McLeod RXT....PERIOD!!!!
#9 | |
I Wanna Go Faster!!
I learned a long time ago though....you get what you pay for. |
#10 |
Exactly, i thought i was set to go with monster then i read about a few issues with them. Again, who knows whats really going on. This is why i am asking all you guys here what else is out there.
There are probably hundreds of Monsters out there but you only read about the one or two that have issues. Anyway, my current HP at the flywheel (740) exceeds even the level 5 from monster. I will eventually have about 900 to 1000 at the flywheel and want to plan for that.
#11 |
get a hold of huff, he might still have his 2 step..it is good to have for track setup...imo
#12 |
Supercharged LSX
Drives: 2011 2SS/RS Black/Carbon Fiber Join Date: Dec 2010
The 20% stronger hold Lingenfelter twin disk and fly wheel.
#13 | |
I Wanna Go Faster!!
#14 |
I have the LPE ZR-1 clutch. It hasn't given me any issues at 625 rwhp at all for about 30,000+ miles. I am having a Forged 417 installed and should make around 750 rwhp. I will see how it holds up with that HP.
| BIG RED - The WORLDS BADDEST CAMARO and its '69 Z/28 non the less (True Story) | NOODLESgoneWILD | 1st & 2nd Generation Camaros | 12 | 10-01-2014 10:15 AM |
| Guys with Upgraded Clutch Setups.....Have a question | HufferSS | Forced Induction - V8 | 5 | 06-01-2011 08:07 PM |
| Big thanks to the guys at Weaver Tire in Brandon | Snake Slayer | USA - Southeast | 1 | 01-07-2011 01:46 PM |
| Oil Change Ramp | mjlash22 | Mechanical Maintenance: Break-in / Oil & Fluids / Servicing | 17 | 01-21-2010 11:40 PM |
