Old 10-28-2011, 04:51 PM   #1
GTFD2
Drives: C7 2LT Vert 2014/2LT RS 2012
Change Oil Now Or In The Spring
I have 1000 on my 2012 2LT. Going to store it for the winter. Should I cange the oil now or when I get it out next April.
GTFD2 is offline   Reply With Quote
Old 10-28-2011, 05:01 PM   #2
JDP Tech
JDP Tech's Avatar
Drives: 2010 CGM Camaro 2SS/RS 429 LSX/F1X
Have you changed it yet since you bought it? If not, I'd probably change it now. If you already have changed it, you're probably good until next year.
JDP Tech is offline   Reply With Quote
Old 10-28-2011, 05:04 PM   #3
GTFD2
No I have not changed it yet. I figured that if I change it now it will collect moisture over the winter and have to be changed in the spring.
Old 10-28-2011, 05:07 PM   #4
JDP Tech
JDP Tech's Avatar
At the same time, though, being brand new there is a lot of metal in the oil from assembly and break-in. I personally would want to get that out before it sat for 4+ months. Then I'd probably change it again after a month or so of driving it in the spring.
Old 10-29-2011, 12:22 AM   #5
mulletman
Drives: 2017 Camaro SS
Change it now. The only way the oil will collect moisture is if you start it during the winter.
mulletman is offline   Reply With Quote
Old 11-01-2011, 09:10 PM   #6
wwddnnone
Ur G'nna feel a pinch
wwddnnone's Avatar
Drives: 2011 SS Convertible
change it now, always change the oil before storage, regardless
wwddnnone is offline   Reply With Quote
Old 11-01-2011, 09:22 PM   #7
rykeith
rykeith's Avatar
Drives: 2010 Camaro 1LT M6
This.
Roto-Fab CAI / MRT V2 / 35% Tint / Emblempros Lighted Door Sills / 19" Brushed Aluminum Wheels
The frost, sometimes it makes the blade stick.
rykeith is offline   Reply With Quote
Old 11-01-2011, 09:38 PM   #8
ipimpthisc
Banned
Drives: @twinturbo, cammed, intrcooled@
Send a message via AIM to ipimpthisc
+1
ipimpthisc is offline   Reply With Quote
Old 11-01-2011, 10:00 PM   #9
GTFD2
Smile
Thanks all. I think I will change it now.
Old 11-02-2011, 12:00 PM   #10
Vipercar
Vipercar's Avatar
Drives: 2010 IOM 2LT/RS
Question about this -- Having changed the oil before storage, should I change it again in the spring or run it with the oil from the winter storage?(it has Mobil 1 )
Vipercar is offline   Reply With Quote
Old 11-02-2011, 12:24 PM   #11
mulletman
There is no need to change the oil unless the car is started during storage.
Old 11-02-2011, 02:25 PM   #12
Vipercar
Vipercar's Avatar
Thanks mulletman.
best synthetic oil to use hollywoodjose Mechanical Maintenance: Break-in / Oil & Fluids / Servicing 130 01-26-2014 09:51 AM
Pfadt Race Engineering DIY Drop Spring installation procedure PfadtRacing Suspension / Chassis / Brakes 20 09-23-2011 10:31 PM
1st oil change question rado06 Mechanical Maintenance: Break-in / Oil & Fluids / Servicing 10 09-19-2010 09:10 PM
