Old 10-29-2011, 05:22 PM   #1
Whipped416
Whipped416's Avatar
Drives: 2010 CAMARO SS
Anyone running big power with Lonnies performance fuel
Is anyone running big power with Lonnies performance dual fuel pump on there camaro.. i know lots of ppl are running them in there corvettes but i just purchased the twin pump with upgraded lines.. Trying to get a little feedback from other people running this system.
Thanks GUYS!
Whipped416 is offline   Reply With Quote
Old 10-29-2011, 06:35 PM   #2
HufferSS
I Wanna Go Faster!!
HufferSS's Avatar
Drives: 2011 2SS Synergy Green M6
Not being a wise guy but why would you buy it and THEN ask for feedback?
HufferSS is offline   Reply With Quote
Old 10-29-2011, 06:58 PM   #3
Whipped416
Whipped416's Avatar
well i have that kit and heard good things ... also have a lpe kit sitting here i was going to put in my wifes car... just trying to see which one would be better for my application.
Old 10-29-2011, 07:12 PM   #4
mikepage0007
mikepage0007's Avatar
Drives: 2010 camaro
i have heard good things in the vette forum also...he has been around...so i beieve his product is a good 1..imo..
mikepage0007 is offline   Reply With Quote
Old 10-29-2011, 07:15 PM   #5
Whipped416
Whipped416's Avatar
yeah thats all i have been told just trying to make sure i want to put lonnies in mine and not the lpe... im sure both are great and i think lonnies will be better for 800/800 rwhp/rwtq . my wifes can is only at 710/680 and she drives like it stock 95% of the time..
Old 10-30-2011, 09:07 PM   #6
blake-b
blake-b's Avatar
Drives: 2009 ZR1
Which one did you go with? The double or triple? I assume the double because you didn't mention sending anything to him for modification.
Old 10-30-2011, 09:52 PM   #7
Whipped416
Whipped416's Avatar
yeah the double can handle 1000rwhp without a boost apump.
Old 10-30-2011, 10:28 PM   #8
blake-b
blake-b's Avatar
Drives: 2009 ZR1
Did you get just the pump or pump/lines/fittings, etc?
Old 10-30-2011, 10:45 PM   #9
Whipped416
Whipped416's Avatar
pump lines fittings everything u need ... complete kit and nice upgraded lines..
Old 10-30-2011, 11:47 PM   #10
g4dadon
Straight Performance Racn
g4dadon's Avatar
Drives: Anything over 600rwhp
I have used lonnies kit on 2 of my builds so far and is very pleased with them and his customer service is awesome to say the least!! The first kit is only the dual pump with no lines on a vortech equipped ls3 car which made 640 with no problem at all and it's a simple drop in. The second kit was the tripple pump in which I had to send the tank to him it came with a wiring harness along with a fuel return kit with rails, your redoing the entire fuel system here. That car made 1000 plus rwhp and has much much to grow for sure. So yes his kits are great and will be using them on all of my future builds.
g4dadon is offline   Reply With Quote
Old 11-02-2011, 12:23 AM   #11
LSX-80MM
Ghostly Unknown
LSX-80MM's Avatar
Drives: Silver Ice 2010 SS/RS A6
I have the Lonnies Twin pump setup as well,And Lonnie informed me NOT to use my BAP,So I did not hook it back up,But I don't piticularly like my rail pressure which is 47lbs @WOT,My Tuner says it's fine do to my afr's are good @WOTseems not to be running outa fuel,But Damn I don't like seeing 47lbs,So let me know how your rail pressure is @ WOT,I'd be curious especially if you add a BAP or not...
TS416,GMPPLSX-LS3 6 Bolt Heads,Custom 80mmComp Turbo,ID850 Injectors, Lonnies Twin Pump Setup,Level 3 4L80E,DSS,3in Magnaflow Exhaust,CoolingMist Meth,RX Dual Catch Can,InnovateWB,Aeroforce Interceptor,AEM Truboost Controller,matte black CF5 Forgestars.700rwhp/712rwtrq
LSX-80MM is offline   Reply With Quote
Old 11-02-2011, 01:34 PM   #12
Whipped416
Whipped416's Avatar
how much power are u making ?
Old 11-03-2011, 02:06 PM   #13
grocerygetter
instigator
grocerygetter's Avatar
Drives: 2020 6.2 Trail Boss, 2022 XC90
Is it Lonnie Dyers? Or a different Lonnie...I just ask because if it is Lonnie Dyers...he is awesome in the Buick community for sure.
-John S.
Old 11-03-2011, 03:18 PM   #14
SC2150
Excellent product....very pleased.
BREAKING: 2012 CAMARO ZL1 - 6.2L LSA Supercharged - 6MT Revealed! Tran Camaro ZL1 Forum - ZL1 Specific Topics 756 05-01-2013 07:22 AM
2010+ Camaro StopTech Drilled Rotors & Power Slot Slotted Rotors | Cyro Treated! AutoAgenda Suspension / Chassis / Brakes 37 02-02-2013 09:12 PM
Camaro ls3 news...true or false? Dark Knight Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 74 06-05-2008 06:29 PM
