Old 10-30-2011, 04:37 PM   #1
Rock-It Man
376 cubic inches of fun
Rock-It Man's Avatar
Drives: 2023 Camaro ZL1 A10
Winterization fail
Got caught off-guard by the storm in Massachusetts.
The Camaro had not been winterized yet. It has a full tank of premium with no Sta-Bil, and the oil hasn't been changed.
Now there's salt on the roads, and no rain in the forecast for the next 10 days to wash it away.:(
Question: does it make sense to put Sta-Bil into a full tank, or should I drive the car to the gas station, put in the Sta-Bil, and top off the tank to mix it in?
Plan B is to put it in the full tank, and then run the car in the garage for a while to get the peservative into the injectors and to watm up the engine for an oil change.
Rock-It Man is offline   Reply With Quote
Old 10-30-2011, 05:30 PM   #2
CAM 5-OH
Drives: 2011 Camaro Convertible 2SS/RS
Go with Plan B - When you put in Stabil (use the marine formula) rock the car a bit to mix it with the gasoline, then run it for a while to get it into your fuel rails, injectors and engine, change your oil and you're done.
CAM 5-OH is offline   Reply With Quote
Old 10-30-2011, 05:56 PM   #3
babaron
Totally into it
babaron's Avatar
Drives: '67 427vette/'11 Pacecar/'02 BMW ci
why does the oil have be warm to change?
babaron is offline   Reply With Quote
Old 10-30-2011, 06:18 PM   #4
clg_98ta
clg_98ta's Avatar
Drives: 2010 Camaro 2SS
It will drain out much quicker...
Old 10-30-2011, 06:36 PM   #5
KEEP RT
Wonderfully Awful Idea
KEEP RT's Avatar
Drives: 2010 2SS/RS
But you realize that allot of it will still be dispersed throughout the engine if you run it to get it warm. It was warm when you shut it off last and had allot of time to drain all the way to the bottom. Then all that's left is in the pan and filter. And if you really want it drained leave the plug out as long as possible. 2-3 hrs. to get it all.
OP>> how cold where it's being stored are we talking? Fuel additives are good for certain temps and below. Otherwise a waste. Remember top it off (DON"T OVER FILL!) and that minimizes air in the tank which causes condensation and leaving water in the tank. Once you put the cap on the tank is essentially sealed. Good luck.
KEEP RT is offline   Reply With Quote
Old 10-30-2011, 06:37 PM   #6
pincoin
Camaro owner since 1982
pincoin's Avatar
Drives: 2012 Camaro 2SS-RS Conv IBM L99
I think warmer oil also helps get out more of the contamination
2012 Camaro RS-SS Conv IBM, L99
1968 Camaro RS Coupe 327 AT
1968 Camaro RS-SS Conv, sold 1993
pincoin is offline   Reply With Quote
The Official FAIL thread theholycow Off-topic Discussions 926 09-01-2014 11:23 PM
Kooks cats fail, warranty? Supercharged SS Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 10 07-06-2011 09:14 PM
Nearly 1 in 4 Americans fail the ASVAB! BlissStreet Off-topic Discussions 31 12-25-2010 09:06 PM
Guy puts NOS engergy drink in his motorcycle drivingincamaro General Automotive + Other Cars Discussion 53 05-29-2009 12:34 PM
Epic Fail for Chrysler Management The_Blur General Automotive + Other Cars Discussion 27 11-16-2008 05:28 PM
