![]() Drives: 2013 Camaro 2LT RS in Crystal Red Join Date: Oct 2011
18" Heritage Rims on Gen 5 Camaro SS/RS!
18" Heritage Rims on Gen 5 SS/RS....
Yes, you can mount 18” Heritage Wheels on your 5th Gen Camaro SS! Here is how I did it: Photo of the front disk and studs before mods: ![]() I use a 10,000 rpm cutoff saw… ( much fun! ) Cut off ¼” of the non threaded tip of the Wheel Stud: ![]() The results look like this: ![]() On the front wheels only: cut off the 2 outer 'skate wheels' ONLY: ![]() The inner 'skate wheels' are ok and can be left on. After cutting all 5 studs, mount wheel spacer and torque to 100 to 200 ft lbs. NOTE: car studs must be flush with wheel spacer or they will push on wheel! ![]() The spacers are from: www.autopartswarehouse.com Part #: E27904300442 ( 30mm spacers ) Eibach Wheel Spacer Wheel Spacer Camaro|SS Qty: 4.00 Price: $ 250 ( about +- tax and S&H ) There are HIGH quality German engineered wheel spacers with hubs. Mount Wheel and torque to 100 to 120 ft lbs: ![]() Install the center plastic hub cover: (twist carefully until you hear a click) ![]() Install the outer Silver beauty Ring: ![]() Do the same for the other front wheel. The rears don’t have ‘skate wheels’ on the Brembo brakes so Nothing to cut but the studs. The rear wheel: ![]() I purchased the tires at: www.tirebuyer.com Brigstone – Blizzak WS70 - Size: 225/60R18 - 4 ea @ $160.00 + Tax These tires mounted are very, very close to the outside dimensions of the 20” with Factory pzero’s on so the odometer and speedodometer will be the same. I put new Tire Pressure Monitoring Valves in the new wheels and they will have to be ‘re-calibrated’ to show up in the cars electronics. www.Rockauto.com Dorman - 974009 – Tire Pressure Monitoring System (TPMS) $ 35.79 ea. The Wheels look really great ( for a winter set! ) ![]() The car rides softer, but the side to side ‘sway’ is noticeable and it doesn’t feel as ‘planted’ in the corners… but what the heck… it’s a Winter setup and looks great! Happy cruzin! Sirdag |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2013 Camaro 2SS/RS 1LE Join Date: Sep 2010
But my question is now that you cut the studs will you be able to mount the stock 20's back on in the spring?
I know that it is only the non threaded part, but it just seems as it was like that for a reason |
SW
Drives: 2011 Camaro Summit White Join Date: Apr 2011
I don't understand why you had to cut the studs....the studs on my LS look the same as yours before cutting them off ??????
SoCal Headturners
Drives: 2010 SGM Join Date: Mar 2010
Sent from my Droid using Tapatalk
Quit being a pu$$y
He is running a 30mm adapter. If the studs stick out too far then the wheel will not be able to sit flush on the adapter face.
#6 |
1LT RS 2011 BLACK
I'm planning on mounting 18" heritage wheels on my 1 LT RS for the winter. Can this be done without cutting anything and adding spacers?
#7 |
![]() ![]() ![]() ![]() ![]() ![]() Drives: Silver 1LT 2011 camaro Join Date: Jul 2011
#8 | |
I installed LS wheels on my dads 45th anniversary 2012 2LT.
Check out my Camaro http://www.camaro5.com/forums/showthread.php?t=84133
#9 |
1LT RS 2011 BLACK
Amesone! Thanks for the info.
#10 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2010 Camaro 1LS 3.6 LLT V6 325 HP Join Date: May 2009
I like the look but am partial to steel wheels, HA
#11 |
In Mud We Trust
Drives: 2010 Camaro 2SS/RS LS3 Join Date: Mar 2011
Maybe I'll go this route. That looks good. I was planning on getting the steel wheels and painting them silver or a titanium color.
2010 2SS/RS, LS3 -Hurst Shifter -American Racing Torq Thrust/Anthracite -CAI Intake |
#12 |
![]() Drives: '10 IBM 2SS, '01 Black SS Join Date: Jun 2009
Dumb question, but I live in AZ where we don't have a winter. What does changing the wheels help with during the winter?
#13 |
Rolling along...
Interesting approach to dealing with winter tires/wheels.
I'd probably just have saved up a couple hundred more and bought a second set of 20" RS wheels instead of cutting up the studs and roller skates, then put winter tires on those. But whatever works for you...
#14 |
![]() Drives: 2011 camaro 1ss synergy green Join Date: Apr 2011
| Tags |
| 18" heritage rims on ss, winter wheels |
| CAMARO WIKI | Tran | Wiki | 67 | 11-27-2024 09:02 AM |
| GM unveils Jay Leno Camaro, Camaro Synergy, Camaro Chroma, Camaro Dusk at SEMA | irocnroll | 5th Gen Camaro SS LS LT General Discussions | 101 | 02-27-2012 01:25 PM |
| 4th Annual GM Performance Parts LSX Shootout!! | nmcajeff | Dragstrip and Launch Techniques Discussion | 3 | 07-30-2010 01:05 PM |
| Ambient lighting (ABL) - the FINAL update = LIMITED TO DOOR PANELS | CamaroScotty | 5th Gen Camaro SS LS LT General Discussions | 338 | 04-15-2009 06:33 PM |
| Answeres to questions I have stumbled on | dieseldave24v | 5th Gen Camaro SS LS LT General Discussions | 13 | 02-23-2009 07:56 PM |
