![]() Drives: 2011 Synergy Green 1SS/RS Hurst Join Date: Oct 2011
purple ice by royal purple?
Anyone using this and if so is there a noticeable difference in temperature? Or is it just a waste of money?
![]() Drives: 2017 Camaro SS Join Date: Oct 2009
Purple Ice is the same as Water Wetter by Redline Oil. The less antifreeze used the better they work. Redlineoil.com has technical info.
GrINned & JUICEd
Drives: 15STI, 10Expy, 10 2SS/RS M6, 47KB1 Join Date: Nov 2009
I haven't used purple ice, but have used water wetter with distilled water added to the coolant in my off road vehicles. I believe it helps, but have no hard data to prove it. Just be careful. Don't use too much or you could dillute the good properties of your coolant; freeze protection, anti-corrosives.
GPI SS3 Cam & stuff,N.O. Plate(dedicated fuel tank,progressive,fuel hose upgrade,remote opener,heater,console switches),LNC2000,CTAP,ARH 1 7/8" LTs/gutted cats/X pipe/mufflers,Jet Hot coated LTs,GPI HPT Tune,CAI, Scoop,Rx Catch Can,Gates heater hose relocation, Remote clutch & auto brake res,Metco loop,Momentum Tunnel Brace,TSW Nurb 18",555 & 05,Pfadt trailing arms & toe rods,Autometer WB,Fesler Pillar Pod,LED strips (int),Lloyds floor & trunk mats,LED DRL/front turn & license plate,DRL harness,VLEDs tail lights,Plasticoat Bowties. Ord: Oct 5, 2009 Rec: Nov 19, 2009 13.17@112.6 stock
I use it but don't have any fact to say if it works.
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: cars Join Date: May 2011
Yes it works. Although not scientific my water cooled bike no longer had the fan kick on while sitting in traffic after adding it. The fan operation and relay was verified to be in working order. Before that it went on every day on the commute to work. There's no temp gauge so I never got hard numbers but it had to be running at least 10 degrees cooler consistently for the fan to stop going on.
#6 |
Drives: 2012 Camaro RS, RX supercharged Join Date: Dec 2009
Works. As posted above the less antifreeze the better it works.
#7 |
San Diego Head Tuners
Drives: 2016 Camaro 1SS ,NPP,MagRide, A8 Join Date: May 2009
I would not use it. Do some searches and make your own decision.
2016 1SS A8, NPP, MagRide, Black Rims
My 5th Camaro (3 Gen5, 1 Gen4) Member of San Diego Head Tuners https://www.youtube.com/c/MojaveKY https://www.instagram.com/mojaveky/ https://twitter.com/MojaveKY http://dinowax.refr.cc/bryanm 15% off DinoWax orders |
#8 |
would 1 12 oz bottlealong with antifreeze be good for a complete drain and refill?
#9 |
Drives: 2011 Camaro SS/ 2016 Camaro SS Join Date: Jun 2009
There isn't going to be any advantage for a street car. We've used it for track cars in the past but those were water with Redline Water Wetter only. Are you having coolant temperature issues? I beat my Camaro on the road course and my biggest problem is oil temps gong up to 300* in 3 laps... Next mod is an oil cooler set up for me.
![]() Kind regards, Jordan Priestley 888.308.6007 |
| The birth of Orange Krate... | Orange Krate | Member Car Journals | 674 | 09-16-2025 03:19 PM |
| Royal purple or mobile 1 | naga | Mechanical Maintenance: Break-in / Oil & Fluids / Servicing | 28 | 06-13-2010 12:11 PM |
| What type of Royal Purple? | rawj7 | Mechanical Maintenance: Break-in / Oil & Fluids / Servicing | 44 | 06-02-2010 12:19 PM |
| What type of oil? | alwinSS | Mechanical Maintenance: Break-in / Oil & Fluids / Servicing | 21 | 05-24-2010 05:38 PM |
| Flipping weather | Iroczlover | Off-topic Discussions | 10 | 02-11-2009 09:46 PM |
