Old 11-02-2011, 01:28 PM   #1
997turbo
Drives: CAMARO 1SS 2011
Is my battery dying?
Hi everyone.
First post from me.
I have a 2011 1SS,done about 19k miles now.
Recently I experinced the battery voltage dropping after turn off the engine.Normally when the engine running the voltage guage showing at 13v right?After I turn it off and check the voltage guage it dropping slowly and after 1-2 hours it only has around 10-11 v..
I also experinced elec. system rapidly shut problem.Like if I keep start/off the engine couple of times then drive it on the road.For about 0.5-1 sec the lights flashing and dash lights /display gone off then they back up.It only happend 1-2 times in past week ,but right after I start/off the engine more offen within a short time..
Oh I also have slow cold start problem,and obviously I think it due to the low voltage from the battery?
The battery is still the ACDelco one from new(19k miles of usage).This sounds like the battery is dying?I am asking here because I am not from US and my car is an import to me.No warranty,I need to buy new battery myself.So if anyone could please also recommend a good brand.My local chev dealer do not stock battery for SS.Only for LT.
Thanks for the help.US musle car rocks
997turbo is offline   Reply With Quote
Old 11-02-2011, 02:55 PM   #2
Madness11
086YN
Drives: Black 2SS/RS Demon of Madness
Optima batteries are great. They are on the pricey side but I have seen them last for 7 years.
Have you tried checking the terminal connections on the battery? Make sure they are good and tight. It sounds like your battery might be defective.
Madness11 is offline   Reply With Quote
Old 11-05-2011, 04:37 PM   #3
Rock-It Man
376 cubic inches of fun
Rock-It Man's Avatar
Drives: 2023 Camaro ZL1 A10
Seems like you drive enough to keep the battery charged, considering that your 2011 has 19,000 miles.
But still, has your car sat unused for more than 2 weeks at a time? If so, you should connect to a battery tender.
It's cool that there are Camaros in China. Got any photos?
Rock-It Man is offline   Reply With Quote
Old 11-06-2011, 02:51 PM   #4
Crime2
Got Boost?
Crime2's Avatar
Drives: 2010 1SS RS
Any one know what Optima red top is correct for the SS?
Sent from my iPhone using Tapatalk. If is spelllled wrong deal with it.
Crime2 is offline   Reply With Quote
Old 11-12-2011, 08:33 PM   #5
Ozzie RS
Ozzie RS's Avatar
Drives: '11 Camaro RS 2LT
As mentioned previously check the battery terminals. The cold start being slow gives me concern that the battery voltage is low. The way I understand the start system is that turning the key to start begins the sequence of powering up the start cycle, meaning whether you hold the key to start or let go of the key the start will continue until it completes the start cycle or it times out. With it being slow says to me that it is possible for the voltage to be low. I hope that makes sense. I have to post a disclaimer that I am not an expert by any means.
I would love to see pictures of your car and you in China. I have a friend in Dubai with a Camaro or did have. He has since sold it. Good luck with your car.
Ozzie RS is offline   Reply With Quote
Old 11-13-2011, 01:02 PM   #6
Crime2
Got Boost?
Crime2's Avatar
Drives: 2010 1SS RS
Not to thread jack, but I am going to a little. What should the voltage of a good battery be at when the is on and off?
Old 11-14-2011, 12:31 PM   #7
Mag-Tex
Drives: 2010 Camaro 2LT/RS
After your car sits overnight it should be around 12.7 volts. It it is less than 12.3 you probably need to replace it.
With the engine running and battery charging, it should be in the 14.0 to 14.5 volt range. But it will depend on RPM and other factors.
Mag-Tex is offline   Reply With Quote
Old 11-14-2011, 12:35 PM   #8
Crime2
Got Boost?
Crime2's Avatar
Drives: 2010 1SS RS
Ya, think I need a new battery and might need to get the alternator checked to.
Old 11-14-2011, 12:40 PM   #9
KalCorp
Space Coast Camaros
Drives: 2012 Camaro Vert
I think if the battery is fully charged the alt turns off. I only get 14+volts when charging if the bat needs it. If not its the normal 12v. when driving.
KalCorp is offline   Reply With Quote
Old 11-14-2011, 12:46 PM   #10
Crime2
Got Boost?
Crime2's Avatar
Drives: 2010 1SS RS
Having a soft crank issue on start. I do have a cam so I wonder if the tune is off on start or the battery is getting week.
Old 11-14-2011, 06:04 PM   #11
caligrown562
Drives: 2012 1SS
I have a 2011 v6 that after it sits over night it only has 12.0v when I go to start it in the morning and while driving its charging 15. It also starts up really rough. It only has a 1000 miles so could I possibly have a bad battery.
caligrown562 is offline   Reply With Quote
CTEK Battery Chargers southerncarparts Miscellaneous Items 28 10-27-2019 11:25 AM
CTEK Multi US 3300 Battery charger available at www.gmpartshouse.com patrickt Audio / Visual / Electronics/ Gauges / Nav 15 03-02-2012 02:20 AM
Whats the cold Cranking Amps on a 2010 Camaro's battery ? Jekyll-N-Hyde 5th Gen Camaro SS LS LT General Discussions 2 01-09-2011 07:59 PM
Smartest Battery Charger in the World!!! southerncarparts Miscellaneous Items 10 02-15-2010 06:08 PM
GM To Build Battery Plant Mr. Wyndham General Automotive + Other Cars Discussion 5 01-13-2009 01:03 PM
