Old 11-04-2011, 06:36 PM   #1
PRECIOUS-SS
PRECIOUS-SS's Avatar
Drives: 2012 CAMARO 2SS
DISK BRAKES !!! NEED HELP
I detailed my rims yesterday with this alloy rim detailer from maguires, and today i look at my disk brakes and they have turned this yellow brown color. almost looks like rusting... WHAT SHOULD I DO? and should i be worried. it has to be from that spray.
PRECIOUS-SS is offline   Reply With Quote
Old 11-04-2011, 06:40 PM   #2
kannon
kannon's Avatar
Drives: 2012 Camaro 2SS/RS/M6
Just a thin layer. Drive your car around the block and you'll be good to go!
kannon is offline   Reply With Quote
Old 11-04-2011, 06:40 PM   #3
Parag
Drives: 2010 camaro 2SS LS3
it happens alot just drive it off
Parag is offline   Reply With Quote
Old 11-04-2011, 06:40 PM   #4
1CamaroSS
1CamaroSS's Avatar
Drives: 2011 Camaro 1SS Inferno Orange
Just go drive it and it will go away and wont hurt anything. This happens after you wash your car too or if its real humid outside.
1CamaroSS is offline   Reply With Quote
Old 11-04-2011, 06:48 PM   #5
rolnslo
Rolling along...
rolnslo's Avatar
Drives: 2011 2SS/RS SGM
Just as a side note, all of the factory wheels are clear coated. There is no need to use wheel cleaner designed for alloy wheels. Just wash them off with soap and water.
rolnslo is offline   Reply With Quote
Old 11-04-2011, 07:02 PM   #6
PRECIOUS-SS
wow thank you so much for all your help. so i guess ill take her for a spin. is there anuything else i can do besides take her around the block or is that the best solution ?
Old 11-04-2011, 07:53 PM   #7
Adam's Polishes
Adam's Polishes's Avatar
Drives: The shiny ones.
You could spend hours scrubbing the wheels, but it so much easier just to drive around the block and let the brake pads do the work.
BTW - it has very little to do with the cleaner... they will get surface rust like that anytime they get wet, but it'll be gone as soon as you get moving and hit the brakes.
Old 11-04-2011, 10:46 PM   #8
vroomapunk
[COTW 5/12/14]
vroomapunk's Avatar
Iron rusts when reacting with oxygen, the oxygen in water makes this happen, the more surface area you have the more rust you will get and the faster it will happen. There are millions of little pieces and ridges and grooves in and on your pads that makes for a lot of surface area to have this happen, so it happens fast, but it would happen if you parked your car outside for a week and didnt drive it, just the moisture in the air would make em rust. But they all do it on the actual braking surface
Drum brakes hard to beat KILLER74Z28 General Automotive + Other Cars Discussion 17 02-16-2012 01:40 PM
KNS Brakes - Say hello to the FNG! KNS Brakes Sponsor Announcements / Giveaways / Contests 47 01-21-2011 11:18 PM
KNS Brakes - Your Street and Racing Brake Experts KNS Brakes Suspension / Chassis / Brakes 50 01-21-2011 11:00 PM
TRADE V8 SS BRAKES FOR V6 BRAKES jrpxxii Suspension / Chassis / Brakes 7 08-03-2010 10:50 PM
EWB Electronic Wedge Brakes KILLER74Z28 General Automotive + Other Cars Discussion 10 11-13-2006 01:12 AM
