Old 11-05-2011, 01:40 PM   #1
Russell James
Russell James's Avatar
Fuel line won't disconnect w/ 3/8" tool, any tips?
I can't get the fuel line disconnected above the intake manifold. I'm using the blue 3/8" disconnect tool from Advance Auto. Rail is drained no fuel.
I push the lines together hard, push the tool in, pull the line... nothing, still hung up on the flare. Any hints? Should I be pushing the tool in harder while pulling on the line? Feels like the tool just pushes in and bottoms out, then pulling on the line - nothing is releasing?
Thanks for any hints!
Old 11-05-2011, 01:44 PM   #2
kevin1106
kevin1106's Avatar
Drives: 2015 ZO6 3LZ Stage 2 A8
let your car run out of gas before trying to remove your fuel line. pull the fuse to your fuel pump. Located on the passenger side of the trunk.
kevin1106 is offline   Reply With Quote
Old 11-05-2011, 01:48 PM   #3
Russell James
Too dissassembled to run the motor now. I've pushed in the schrader valve several times while pushing on the fuel line, doesn't seem like any more fuel is going to come out.
Old 11-05-2011, 01:52 PM   #4
kevin1106
kevin1106's Avatar
Not sure what to say. I removed mine. It was pretty simple. I started my car, then pulled the fuse. The line came right off once the engine ran out of gas. Id say try that. Then see if it will come off.
Old 11-05-2011, 01:56 PM   #5
kevin1106
kevin1106's Avatar
I'm thinking the line is still under pressure. If you did manage to get if off, fuel would shoot out everywhere. Be 100% sure the line has no pressure and the no fuel.
Old 11-05-2011, 02:02 PM   #6
Russell James
There is no fuel pressure, I've pushed the schrader in for a while and it drained fine. Not possible to start it now, motor too stripped down. I don't think fuel is the problem, maybe the tool isn't thick enough, I may try to wrap some tape around it or find a different one.
Old 11-05-2011, 02:47 PM   #7
Russell James
Tried a few wraps of tape around the plastic tool, no luck. Also tried the other end of the fuel line, exact same thing there - the tool won't disconnect it.
Any other ideas, any auto parts stores sell a little different tool maybe?
Old 11-05-2011, 02:51 PM   #8
bigsquirrel
My car runs on acorns....
bigsquirrel's Avatar
Drives: 2010 SS RS Inferno Orange
Mine were a real pain in the ass to. Try to twist a little when you're squeezing them together.
My car runs on acorns, the tears of ricers and these other slightly less important things...
2.9 Polished Whipple, Kooks LT 1 7/8 headers, HiFlow Cats, Kooks Sleeper catback, Cooling Mist Methanol Injection, PFADT Sport Sways, PFADT Springs, PFADT rear trailing arms, ADM intake, JDP stainless brake lines, Jegs Catch can, Stock SS wheels widened to 10 3/4, Hawks HPS Pads, Pedders Rear Subframe Bushing Inserts, BMR Center Brace, MSD BAP, AAC side markers, Emblem Pro's Custom Lighted Door Sills, Dash-Floor-Cupholder ABL lighting and other stuff....
bigsquirrel is offline   Reply With Quote
Old 11-05-2011, 03:08 PM   #9
doomsdayjesus081
Drives: VR 2010 Camaro SS/RS
Pull harder, and twist. It is not easy but there is no need to do any more than that.
doomsdayjesus081 is offline   Reply With Quote
Old 11-05-2011, 03:30 PM   #10
Russell James
Finally got it! The stupid tool from Advance Auto must be too thin. Grabbed a Lisle brand tool from Oreilly and it came right off. I can tell it looks thicker.
Lisle 39420 - 3/8" Angled Fuel Line Disconnect if anyone ever needs one that works.
Old 11-05-2011, 04:21 PM   #11
MRGOODWRENCH3
Drives: 2010 Camaro 2SS/RS
It does not matter if there is fuel pressure in the line, it will still release. Before inserting the tool push the fuel line in hard toward the installed position, then insert the tool making sure it seats in 360 degrees. Then pull it off. I have found that the plastic tools work better than the metal ones.
MRGOODWRENCH3 is offline   Reply With Quote
Old 11-05-2011, 05:26 PM   #12
Russell James
Here's the tools - the one on the left is the Lisle brand tool that worked great. Popped the line right off. The POS on the right, made in China, was never going to get the line off.
Old 11-10-2011, 03:42 AM   #13
GTRDIABLO
GTRDIABLO's Avatar
Drives: Black with silver stripes and 22s
I didn't even use a tool. Just cut a piece of plasic oil jug about 1" rectangle and pushed in. Popped right off. I always use this method. It works great.
GTRDIABLO is offline   Reply With Quote
Old 05-29-2014, 01:43 PM   #14
PFL
PFL's Avatar
Drives: Camaro SS
what do you call this connector? where can I find?
PFL is offline   Reply With Quote
fuel line location MidnightNitemare 5th Gen Camaro SS LS LT General Discussions 1 08-29-2011 08:42 PM
Fuel line limits Ovenmitt Forced Induction - V8 5 05-30-2011 06:54 AM
Camaro ls3 news...true or false? Dark Knight Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 74 06-05-2008 06:29 PM
