Old 11-06-2011, 02:46 PM   #1
Kiowa88
Out Front!
Kiowa88's Avatar
Drives: OH-58D (R)
Question about the spark plug threads in the cylinder head
Just curious to know the probability of the threads being cross threaded from the factory. Pulled the factory plug out, and threaded the new one until it was seated. No unusual resistance seeing as how the other 7 went it without a snag. Well I thought it was fully seated. Turns out about half the threads where cross threaded and mangled with the plug in just far enough to appear ok. Ran into this nasty suprise during my cam swap.
B Troop, 3-17CAV - Out Front
Kiowa88 is offline   Reply With Quote
Old 11-06-2011, 03:10 PM   #2
Russell James
Russell James's Avatar
Normally when cross threaded, it will be very hard to pull out the entire thread distance. And the plug will be in at a funky angle with a compression puff puff noise.
Have you tried a thread chaser? Auto parts stores will have a spark plug thread chaser. Put some grease in the groove and crank it in. I've fixed several just chasing the threads. If it won't hold tq after that, then a heli-coil is needed.
Old 11-06-2011, 03:12 PM   #3
BowlingSS
Camaro Owner Since 1987
Drives: 2011 2SS/RS L99 RJT
I have never heard of threads messed up from the factory but it could of happen. Good luck on the fix.
Bill
BowlingSS is offline   Reply With Quote
Old 11-06-2011, 05:23 PM   #4
bannonm
bannonm's Avatar
Drives: 2011 2SS/RS M6 VR
I would think you would have leakage around the plug if it were cross-threaded from the factory. I am assuming you have been driving the car for a while?
A few tips for replacing plugs. Always use anti-seize and always start the plug by hand. Meaning start the thread using only your fingers so you know it's going in correctly. You may need to use the plug socket and an extension and spin it in by hand if you can't reach the threads, but never use a ratchet to start a plug. Hope it works out for you.
bannonm is offline   Reply With Quote
Old 11-06-2011, 06:58 PM   #5
Kiowa88
Out Front!
Kiowa88's Avatar
Drives: OH-58D (R)
Thanks for the suggestions. I really appreciate it. I ended up pulling the head off. I've never done a heli-coil before so I'm going to take it to my machine shop. Thanks again guys!
Old 11-06-2011, 10:03 PM   #6
MikeOD
Drives: 2010 M6 2SS
It's very unlikely to be factory cross-threaded...they are tapped on CNC machines, not by hand. What is more likely, is a damaged thread on a new plug causing a problem with a head, or (not trying to be mean to you) operator error when changing the plugs.
2010 Camaro SS M6. Heads/Cam/Intake/Headers/Exhaust/Suspension
MikeOD is offline   Reply With Quote
Old 11-06-2011, 10:07 PM   #7
Juiced1
Drives: 2012 2SS CAMARO 45th
Might as well get them ported while they are there.
Juiced1 is offline   Reply With Quote
Old 11-06-2011, 10:11 PM   #8
Kiowa88
Out Front!
Kiowa88's Avatar
Drives: OH-58D (R)
Haha no offense taken. Either way I got to spend the better part of the past three weeks taking this engine apart and putting her back together. Some serious bonding time. I think I'll be able to do this blind-folded soon!
AFM turned off by my dealer???? fastfreddie 5th Gen Camaro SS LS LT General Discussions 95 08-25-2012 03:55 PM
Big savings on MSD 8.5mm spark plug wires at PFYC - PartsForYourCar PFYC V8 Bolt-Ons & Tunes 0 04-05-2011 01:16 PM
Hot Spark Plug Wires in Stock MTI Racing Kevin Tuning / Diagnostics -- engine and transmission 1 02-16-2011 05:45 PM
Spark plug question quinthawk Forced Induction - V8 8 05-31-2010 02:03 AM
AFM: how does it works? tommygun6644 5th Gen Camaro SS LS LT General Discussions 9 02-28-2010 04:36 PM
