Old 11-08-2011, 07:58 PM   #1
ChargedCamaro
ChargedCamaro's Avatar
Drives: Twin Turbo LSX Camaro
What are the best valve springs to run?
Hi guys,
Im new to the site and just picked up a 2010 Camaro with some bolt ons.
I was reading around on some threads and im trying to see what are a good set of valve springs? The 5 day I had the car my brother in law drove the car down the street and over reved the motor and bent pushrods!!!!!
I was talking to my mechanic buddy and he said I should upgrade the valve springs to help with this issue. Any suggestions?
Thanks guys!!
BTW.. Dont let anyone ever drive your car!!
ChargedCamaro is offline   Reply With Quote
Old 11-08-2011, 08:03 PM   #2
Parag
Drives: 2010 camaro 2SS LS3
manley they are soo pretty. bent push rods will get worse with stronger springs. what bolt ons??????
Parag is offline   Reply With Quote
Old 11-08-2011, 08:05 PM   #3
JDP Motorsports
JDP Motorsports's Avatar
Drives: 2011 Camaro SS/ 2016 Camaro SS
Originally Posted by ChargedCamaro View Post
Hi guys,
Thanks guys!!
The factory valve springs are just fine. He must have gone into 2nd gear at 80 MPH? That is pretty crazy! Have you done anything else to the car?
Kind regards,
Jordan Priestley
888.308.6007
JDP Motorsports is offline   Reply With Quote
Old 11-08-2011, 08:15 PM   #4
ChargedCamaro
Has headers, full exhaust, snow meth injection kit, supercharged, CAI and tuned
Old 11-08-2011, 08:18 PM   #5
Parag
you should not be bending rods. make sure there is a rev limiter intact and dont let people drive your car. dont replace your springs, just wasted money. put stronger pushrods in if you are worried about it. comp cams make a good set.
Old 11-08-2011, 08:44 PM   #6
Camarowguy
Camarowguy's Avatar
Drives: 2011 imperial blue SS, black 92 RS
So next time you can bend your valves instead of easy to change push rods. Lol
2011 imperial blue SS/RS a6 12.43@112 vararam, tune, jba cats, magnaflow axle back, self ported tb, under drive pulley, NO headers, Stock tires. 1.87 60ft. Stock tires. SOLD :(
2000 1500 silverado extra cab SOLD :(
2017 Silverado 5.3 all stock
2004 5.7 GTO 78mm turbo
Camarowguy is offline   Reply With Quote
Old 11-08-2011, 08:48 PM   #7
Camarowguy
Camarowguy's Avatar
Btw, likely the car was downshifted instead of up shifted which will cause a mechanical over rev. Putting stiffer springs in wont help that really. It would not hurt to put better springs in so you could rev it a little higher without valve float. But if you don't really plan on doing many mods to it, your just pissing up a rope and wasting money.
Old 11-08-2011, 09:01 PM   #8
JDP Motorsports
What blower do you have on it and what is the rev-limiter set to? Valve springs are a waste in most cases unless you're planning on a camshaft but being in CA you're walking a fine line already.
Kind regards,
Jordan Priestley
888.308.6007
Old 11-08-2011, 10:53 PM   #9
ChargedCamaro
I bought the car from someone in Tx, Lethal Performance did all the work on the car, and to tell you the truth I never heard a rev limiter when he was driving
Old 11-08-2011, 11:02 PM   #10
JDP Motorsports
I would get some factory pushrods and get it back together; then get the tune checked out. You honestly shouldn't be going past 6500 RPM and depending on the blower some stop making power at 5500-6000...
Please feel free to call, email or PM me anytime with questions. Good luck.
Kind regards,
Jordan Priestley
888.308.6007
Old 11-08-2011, 11:03 PM   #11
CC Performance
Drives: 99 Camaro SS, 79 z28, 70 GTX
Has it been cammed? If not and has the factory cam then the oem springs are what you want.
Other than that we like to run PAC
CC Performance is offline   Reply With Quote
Old 11-08-2011, 11:16 PM   #12
ChargedCamaro
Ok,
I just took out 2 spark plugs and the ground wire is pushed into the center wire. I will take some pictures and post them up.
Old 11-08-2011, 11:24 PM   #13
JDP Motorsports
Ok,
You might have more problems than you think... Do you have a complete mod list? How exactly did he manage to over rev the engine? I'd guess 3rd to 4th shift gone bad into 2nd.
Kind regards,
Jordan Priestley
888.308.6007
Old 11-08-2011, 11:26 PM   #14
ChargedCamaro
Maggie TVS 2300 SC with a 3.6" pulley.
ZR1 Twin Disc clutch.
Hurst Short Shifter.
1 7/8" ARH LT with highflow cats.
Drive Shaft safety loop
Roto-Fab CAI
160º Tstat.
Stage 2 Snow Meth kit safe injection.
ADM Dual Pump kit
ADM boost and AFR guages
Catch Can.
There was never a mis-shift, was in the car
Valve Springs SStothebone Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 22 07-21-2011 11:27 AM
FS/FT: LS7 Intake, fuel rail, and Injectors, LS7 cam, valve springs! walhan_qtr V8 - Engine, Exhaust, Bolt-Ons, Tuning Equipment 4 03-04-2011 05:33 PM
Billet Custom Products LLC has released a NEW all billet valve cover kit for the 2010 Bruce at Billet Engine Internals 5 11-20-2010 12:14 AM
Dual Valve Springs with Retainers Available.... dmax86 Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 0 06-08-2010 09:45 PM
L99 AFM -- It's REALLY a tough choice, for some. Step Inside. 2KZ28_For_Now 5th Gen Camaro SS LS LT General Discussions 128 04-03-2009 05:03 PM
