Old 04-10-2009, 08:30 AM   #1
omarrakeen
Camaro Freak
Drives: 1998 Z28,1996 RS, 2005 Altima
Send a message via MSN to omarrakeen Send a message via Yahoo to omarrakeen
best oil pressure??!
hey i got 1998 LS1 i noticed the oil pressure gauge is exatly in the middle when car is hot or cold reving or not...is that normal??
whats the best oil pressure, normal lets say ??
omarrakeen is offline   Reply With Quote
Old 04-10-2009, 10:24 AM   #2
radz28
Petro-sexual
radz28's Avatar
Drives: Ultra-Grin
I'm not sure if the gauges in the '98s are similar to later models, in this respect, but cold, I'm at 60+ lbs. above idle. I know the temp' gauges were crap in later models, but I thought '98s were good.
As far as best oil pressure, it's my understanding you want something like at least 10 lbs. per 1000 RPMs.
'20 ZL1 Black "Fury"
Old 04-10-2009, 10:41 AM   #3
Super83Z
Super83Z's Avatar
Drives: 1999 Z28 1983 Z28
That oil pressure is fine. Some LS1's as they get older only have about 20 at idle. That is still ok. 7-10 lbs per 1000 RPM is what is recommended. If the gauge never moves, consider changing the sending unit( a PITA) its located behind the intake manifold on top of the block.
And yes 98 was the only year to have a fully functional temp gauge. The later years were basically an idiot light. The problem was being an all aluminum engine it fluctuates in temp alot. People were bringing their cars in thinking there was something wrong with it. Probably why the new Camaro reads "C Normal H" so they don't have to worry about that again.
Current cars:
99 Z28
06 Silverado
14 Silverado
Super83Z is offline   Reply With Quote
Old 04-10-2009, 11:33 AM   #4
CamaroSpike23
Truth Enforcer
CamaroSpike23's Avatar
LT1's at idle are known to run around 5-10psi. your oil press is fine. tho it should fluctuate some when you are driving.
I piss excellence
and fart awesomeness
Old 04-10-2009, 02:11 PM   #5
AGM76
Drives: 1995 z28 - 2000 SS - 08' vette
Yeah at idle my lt-1 hovers around 7-8. Goes up as the rpm's increase o course. Think its a normal pressure.
AGM76 is offline   Reply With Quote
Old 04-10-2009, 06:50 PM   #6
omarrakeen
Camaro Freak
mmm the 98 is LS1 too its all alminuim too anyways the pressure seems to get better i think its jst dirts and old oil coz i bought the car 3 days ago and i didnt drive it for long time i jst tried it..also i got engine light on then off after 5 mins lol ill change oil filter and c..and the car runs amazing..thx all
Old 04-10-2009, 07:14 PM   #7
4thGenZ14X2
4thGenZ14X2's Avatar
Drives: 2000 LPM Z28
My 2000 Z28 stays around 70-75psi @ any given time. I also have a ported/shimmed LS6 oil pump though. your's is good to go...
Heads/Cam/Stall/Fully Bolted.
4thGenZ14X2 is offline   Reply With Quote
Old 04-10-2009, 07:43 PM   #8
Super83Z
Super83Z's Avatar
Hey man I like your car. Where did you get that hood? Thats the only cowl hood I ever liked on a 4th gen. The others are too angular they don't look like they belong on the car. Got any more angles of it?
Current cars:
99 Z28
06 Silverado
14 Silverado
Old 04-11-2009, 08:00 AM   #9
omarrakeen
Camaro Freak
cool then ill change oil n filter n c...should i put some sport oil filter or it doesnt matter....? acdelco is fine?
Old 04-11-2009, 03:31 PM   #10
CamaroSpike23
Truth Enforcer
ac delco is a decent filter.
top filters are Wix, Purolator PureOne, Mobil 1, K&N.
top oils Royal Purple, Mobil 1, Amsoil
I piss excellence
Old 04-12-2009, 07:47 AM   #11
omarrakeen
Camaro Freak
ill stick to mobile coz i dnt think we have royal around here....
L99 AFM -- It's REALLY a tough choice, for some. Step Inside. 2KZ28_For_Now 5th Gen Camaro SS LS LT General Discussions 128 04-03-2009 05:03 PM
How about a barrel of oil for around $16? Blownhotrodder General Automotive + Other Cars Discussion 19 03-06-2009 08:25 PM
The 3,000 Mile Oil Change Myth KILLER74Z28 General Automotive + Other Cars Discussion 35 07-20-2008 10:02 PM
