Old 11-11-2011, 11:10 AM   #1
probee773
Drives: 2011 Camaro 1LT RS 6MT Double Black
Exclamation AY6 (V6 M6) aftermarket 1st to 2nd gear synchro and blocker ring to fix grind
Any companies want to step up and design a more durable replacement 1st to 2nd gear sychro and blocker ring? One with a carbon friction material instead of brass should alleviate the power shift grind we all seem to have. I would even buy a rebuilt synchro and blocker ring if they were available.
I think there is a big market for this considering it is a design flaw with this transmission and millions of these transmissions are on the road. Can we get some help with this issue, from someone... anyone... pretty please?
At the moment, I just have to shift from 1st to 2nd a split second slower than I'd like to... Gets the job done, but not representative of a true performance car.
probee773 is offline   Reply With Quote
Old 11-11-2011, 01:58 PM   #2
piticu667
Drives: 2010 Camaro
Sorry dude but as far as I know nobody makes it..
piticu667 is offline   Reply With Quote
Old 11-11-2011, 02:59 PM   #3
Run and Gun
Run and Gun's Avatar
Drives: 2011 1SS/RS , 1966 GTO
GM already has a updated carbon fiber blocking ring for this problem they're just not making a recall for it.
A machine for shrinking time and distance.
Run and Gun is offline   Reply With Quote
Old 11-11-2011, 03:08 PM   #4
Mach
Mach's Avatar
Drives: White M6 1LT RS
No they haven't. This update was for the V8 guys. Not the AY6. The OP drives a LT1.
Pfadt Sway Bars - FE3 Suspension - Barton Shifter - IdealG's Clutch Master Cylinder - Trifecta - Vmax TB - Vararam Intake - MACE 25mm Insulator - Plenum Insulator - Ported/Gasket Matched Intake Manifold - Rx Catchcan - AAC DRL's - 4 Pack Aux Gauges - Steering Controls - AAC Afterburners - DIY Led Sidemarkers - ZL1 Front End
Next mod: Done!
Mach is offline   Reply With Quote
Old 11-11-2011, 04:49 PM   #5
DarkneSS
Drives: 2010 Camaro 2SS/RS 6MT
My problem has gone away but Im not confident at all that it wont come back. Id still want this fix.
DarkneSS is offline   Reply With Quote
Old 11-11-2011, 05:44 PM   #6
justa25thTA
justa25thTA's Avatar
Drives: 2011 Camaro SS/RS LS3
an LT1? Really?
Yeah, I'll get around to it...
justa25thTA is offline   Reply With Quote
Old 11-12-2011, 06:00 AM   #7
mtbikerinme83
mtbikerinme83's Avatar
Drives: 2010 2SS/RS LS3-M6
I think he means a 1LT refering to the cars trim level, not a LT1 engine.
Currently:
2010 CGM 2SS/RS GFX LS3-M6, 3.91 1LE diff, Kooks LTH w/ cats, Borla Touring axel back, CAI intake with race scoop, and custom dyno tune
Previously:
2010 IBM 2SS LS3-M6
CAI intake with JRE race scoop, VMax TB, Solo HF Catted Mid pipes, and JRE SCT tune
mtbikerinme83 is offline   Reply With Quote
Old 11-12-2011, 07:20 PM   #8
Mach
Mach's Avatar
Yeah I meant a 1LT. Brain fart.
Next mod: Done!
Old 11-12-2011, 08:47 PM   #9
brian ludwig
brian ludwig's Avatar
Drives: 2010 2lt
update to royal purple oil and this will help. It worked for me. No grind.
brian ludwig is offline   Reply With Quote
Old 11-12-2011, 11:44 PM   #10
Ventmaster
Ventmaster's Avatar
Drives: 2017 1SS 6spd
AMSoil MTG 75w-90 is my solution- perfectly adequate manual trans oil, but its G-4 rated, not the GL-5 called for by GM.
G-5 has more extreme pressure additives for extreme conditions. I don't live in Antartica, and sychro's need just a little friction to do their job.
Try it, you'll like it.
Old 11-13-2011, 09:45 AM   #11
Mach
Mach's Avatar
I think I might. How many quarts?
Next mod: Done!
Old 11-13-2011, 10:52 AM   #12
Ventmaster
Ventmaster's Avatar
1.9 quarts. I think it was about $15/quart. It's very helpful to get one of those hand pumps that screw into the bottle to get the oil up to fill hole .
Old 11-17-2011, 05:19 PM   #13
probee773
So, in lay man's terms, is the GL-4 thicker or less slippery? I'm trying to understand why this helps the grind. Does it help the synchro work faster?
Old 11-18-2011, 07:58 PM   #14
Ventmaster
Ventmaster's Avatar
A GL-5 has more extreme pressure additives (6.5% vs 4.0%) than a GL-4.
GL-5 is the highest, extreme condition gear oil currently available.
The EP additives are "antiscuffing" and maintain a thin layer of oil between surfaces whenever possible.
The synchro ring in a manual trans rotates slowly due to frictional torque from a cone clutch. The brass clutch ring gradually causes both gears to rotate at the same speed. When they do spin at the same speed, there is no more torque on the cone clutch and gear engagement occurs. In a modern manual trans this should occur so quickly you hardly notice
This system was designed by Porsche in 1952, before GL-5 was around, or synthetic oil for that matter.
75W-90 is the proper viscosity for our trans and I think GL-5 may offer the best possible fuel mileage- but I also think GL-4 offers better function (its less slippery).
Its not a magic bullet, this is still a clunky trans with alot of room for improvement, but I've had better performance with it.
