Old 11-12-2011, 05:09 PM   #1
SSTG
Drives: 2014 Z51 Corvette
Pfadt drop springs, now I have noise?
I did a search and only found four threads on this issue. I am gonne recheck my endlinks per the other threads. But I tightened everything TIGHT! I go overboard even at times.
I installed the springs myself and had the bushings timed and the car aligned today.
The tech did not see anything wrong with the install. My question is, has anyone else had a clunking noise after your drop spring install? What did you do to fix it?
Thanks for any and all help!
SSTG is offline   Reply With Quote
Old 11-12-2011, 05:21 PM   #2
mhog
mhog's Avatar
Drives: 2010 V6 Camaro 2LT/RS
I had a problem with noise with my pfadt spring on one corner. I took it apart, and the bump stop was stuck on the top of the shaft.
mhog is offline   Reply With Quote
Old 11-12-2011, 05:51 PM   #3
SSTG
Would that matter? Doesn't it end up there anyway?
Old 11-12-2011, 07:18 PM   #4
Snake Slayer
Snake Slayer's Avatar
Drives: Awaiting 2014 C7
Did you cut the bump stops? Also Make sure the coils are seated in the perch?
Awaiting 2014 C7
Snake Slayer is offline   Reply With Quote
Old 11-12-2011, 07:57 PM   #5
SSTG
I did cut the Bump stops. And the springs are in the perch.
I just finished rechecking the Sway bar end links,and they are tight. I check all the bolts. I tried raising the suspension with a floor jack and it is dead quiet.
Any other ideas?
Old 11-12-2011, 08:15 PM   #6
CALI_FIREFIGHTER
CALI_FIREFIGHTER's Avatar
Drives: 2LT/RS SIM
Same issue
Had the same problem. Jacked up the car and twisted the spring a little, problem fixed. It was like 1/4 of an inch from being seated.
CALI_FIREFIGHTER is offline   Reply With Quote
Old 11-12-2011, 08:16 PM   #7
mhog
mhog's Avatar
It was stuck on the thin part of the shaft.
Old 11-12-2011, 08:20 PM   #8
SSTG
Thanks for your input, if i rotate them they will be out of the recessed area on the rubber. This is so frustrating.
Oh, thanks for clarifying.
Old 11-12-2011, 08:49 PM   #9
SSTG
Also, I was told to leave the plastic covers on the coil, is this correct?
Old 11-12-2011, 09:32 PM   #10
69307
69307's Avatar
Drives: 2010 2SS/RS Summit White Camaro
Had the same problem with my Eibach's... Took it back to the shop and they re- greased and re-tightened everything (I had both lowering springs and sway bars installed). Everything is good now!
GM/Hurst Shifter, Pedders Xa coilovers, Eibach Sway Bars, Borla ATAK Cat-Back Exhaust, CAI Inc. Cold Air Intake
69307 is offline   Reply With Quote
Old 11-12-2011, 09:37 PM   #11
SSTG
What is there to grease?
Old 11-12-2011, 09:42 PM   #12
69307
69307's Avatar
My understanding is that the Eibach sway bars have grease zerks.
Old 11-12-2011, 09:49 PM   #13
SSTG
Ok, I still have the stock sway bars. Thanks for helping out though.
Old 11-12-2011, 10:28 PM   #14
Ventmaster
Ventmaster's Avatar
Drives: 2017 1SS 6spd
your stock bushings will pre-load the swaybar and make it difficult to fully seat the endlink if the spindle or wheel is hanging unsupported.
measure the distance from the center of the wheel to fender lip while its on the ground. Put it up on jackstands and then raise the wheel with your jack (or a small bottle jack) back to this position.
now check your endlink connection. it should be in a more static or "relaxed" attitude and you may find it can be tightened a bit more to 33lb/ft of torque.
that's my WAG for the night anyway!
Pfadt Stage 2 Performance Handling Package Is Now $600 Shipped At APEX Motorsports!! Apex Motorsports Suspension / Chassis / Brakes 167 08-09-2012 05:05 PM
Drop It Like Its Hot! (Pfadt Lowering Springs) ShizzyIzzy Suspension / Brakes / Chassis 13 09-16-2011 11:44 AM
Pfadt Race Engineering's newest distributor is... Apex Motorsports Suspension / Chassis / Brakes 6 06-12-2011 10:53 AM
Save $$$ with Pfadt suspension packages from Apex Motorsports Apex Motorsports Suspension / Chassis / Brakes 75 12-13-2010 09:29 AM
PEDDERS TAKING ORDERS FOR DROP COILS WITH OPTIONS! Info@PeddersUSA.com Suspension / Chassis / Brakes 25 08-03-2009 10:45 PM
