![]() Drives: RS Join Date: Sep 2011
daily driver, eibach pro kit reviews, is it that harsh?
I have the springs ready but iam waiting to install the body kit first to see how low the skirts hang. I already installed the front splitter looks great.
I can liv with a stiff ride i've owned an 89 iroc 94 impala ss and sum rams that were lowered. How harsh is the ride with the pro kit i've been reading reviews on springs but i want actual Eibach pro kit reivews from peeps driving their camaro on a daily basis. Any suggestions better shocks or shorted bumpstops???? Thanks in Advance, Manny |
So Cal Race Team
Drives: 2013 Camaro Join Date: Mar 2010
Unless your buying coilovers which are better than drop springs, since you can adjust the ride, the Eibach springs work great, ride is definitely firmer than stock, but handling is much better, add the sway bars to further improve handling. In my opinion, the others have to do something to justify the cost of their products, Eibach isn't on here cheerleading their products. Others will chime in, good luck with your mods...
Search Ninja
Drives: 2010 Black 2SS/RS A6 Join Date: Oct 2009
When you make thousands of different springs for every car imaginable, you can cut prices. Pfadt, Pedders, BMR, and Hotchkis make them for specific cars at specific tolerances. Eibach isn't cheerleading their stuff cause they let the cheap prices do that. Call the Eibach tech line and see if you get someone that KNOWS the specifics on installation in your Camaro. Some may want to call it cheerleading while others call it customer service.
Halltech CF 102 fed GPI modded intake manifold Bo (knows) White ported TB Kooks LT's/ Dynomax VT Pfadted (springs/sways) Dyno tuned by Rhino and GPI I once parallel parked a train. |
![]() ![]() ![]() Drives: BLACK 2SS/RS Join Date: Sep 2009
Ride quality is fine.....just a little stiffer which is the case with any brand. Have had the Eibach Pro Springs installed for two years with no issues. Bumpstops do not need trimmed. Eibach's customer service is fine....I have talked with them in the past and they were helpfull and knowledgable.
CCW polished 505a's
Front 20x10 w/275/40/20's Rear 20x11.5 w/305/35/20's Eibach 1" Pro Spring Kit Factory GFX MPD1 spoiler painted bowties 15% tint |
#5 | |
![]() Drives: 2010 Camara SS Supercharged Join Date: May 2010
http://youtu.be/xkgcJcs-1XU |
#6 |
Can't stop ***ifying
Burned. Haha. Over in the zl1 area the eibachs are getting all positive reviews. So, I just ordered some...
Rotofab, grinding rear diff sound forever, dealer replaced supercharger - now i have a rattle when starting from a stop, ordered 2.35 lingenfelter pulley, hp tuner, belt, 100mm idler pulley, tr7IX spark plugs, wideband kit, long tubes with no cats...hoping for 650hp. dyno with rotofab = 518hp |
| Camaro5 Fest III "Official" Pre-Registration | garcmol | 2012 Camaro5 Fest (III) | 1628 | 02-23-2013 05:23 PM |
| Where we are coming from (check inside) | ljustin293 | 2010 Camaro5 Fest (I) | 106 | 05-13-2010 12:31 AM |
| Camaro 5 Fest Drivers or Spectators | garcmol | 2010 Camaro5 Fest (I) | 427 | 04-23-2010 03:32 PM |
| CLOSED - Driver Signup for the 1st Annual Official Camaro5Fest (April 16-18, 2010) | GTAHVIT | 2010 Camaro5 Fest (I) | 923 | 03-20-2010 12:56 AM |
