Ruby & Blu Imp
Drives: 2010 LS3 2SSRS M6 & LLT RS A6 Join Date: Dec 2009
Question will front stock RS polished aluminium 20s fit on the rear?
Does anyone know if the stock polished RS 20 inch rim from the front will fit on the rear of a stock 2010 RS Camaro without the Brembo's?
Just thinking it could be an option for a matched set that could be partially able to rotate (unidirectional only...) Thanks,
Ruby
2SSRS M6 - Blown & LLT RS A6 |
knows 2 facts about ducks
yes
#3 | |
Master of All Things
Drives: '26 Corvette Stingray Join Date: Jul 2009
![]() ![]() ![]() ![]() ![]() Drives: 2010 Camaro 2SS/RS Join Date: Dec 2009
The OP asked if the FRONT WHEELS will fit on the rear without any problems.. To answer your question Yes they will. I sold four 20 x 8's to member up north for him to run snow tires on.
94 Firebird Formula (Drowned 08/30/05)
2010 IBM 2SS/RS 6M Arrived 3/25/10. ADM CAI, Borla Type S Cat Back, VMAX Ported TB, LG Short Throw Shifter, 1LE Shocks, Hotchkis Sway Bars, Whiteline Cradle Bushing Inserts, Custom Powdercoated ZL1's ,Michelin Pilot Supersports, Stainless Power Headers, Solo J Pipes, AAC LED Sidemarkers, ZL1 Rockers, SLP Splitter, ADM Stage II Cam,ZL1 Diffuser,Vitesse Throttle Controller. |
oops.....thats right.......but YES.....you can do that as well.....as a few people have done the 9's all the way around, and took their 8's, got another set of them as well and put WINTER tires on the 8's.
#6 |
I had to read it more than once myself.
#7 |
Drives: nothing Join Date: Nov 2010
You want pizza cutters on all 4 ey?
#8 |
Ruby & Blu Imp
It opens up a lot of options...
1. running 275's on the 8's should in theory give a little more protection from curb rash, but depends on the tire mount...had a pair of BFG MTRs on a land cruiser that had a rim protective sidewall that rocked. 2. curious if running the 245's if it would change the mpg / drag strip time or any other handling aspects (running V6 so the 9's grip is not an issue currently @ launch) 3. potential of installing Atturo AZ800 and running them as the snow / winter tire as the price is great. 4. ability to rotate them partially - front to back and vice versa - as they are unidirectional...and I have unfortunately learned on another vehicle that running them in the wrong direction on the fronts makes it squirrley as hell. 5. the REAL reason - taking a set and blacking them out to see what it looks like on the IBM Thanks guys!!! G-
Ruby
2SSRS M6 - Blown & LLT RS A6 Last edited by gwbates3; 11-26-2011 at 09:13 AM. Reason: changes |
| 5th Gen Suspension -- The Book | JusticePete | Suspension / Brakes / Chassis | 151 | 05-07-2015 06:52 PM |
| Poll -- Camaro vs Mustang Supercar Shootout | JusticePete | Suspension / Brakes / Chassis | 105 | 10-09-2013 03:18 PM |
| Suspension guys out there - lets talk wheel hop | Crowley | Suspension / Brakes / Chassis | 14 | 10-09-2009 01:06 AM |
