Old 12-01-2011, 07:14 AM   #1
bluetorp
bluetorp's Avatar
Drives: 2010 2SS/RS IOM M6
Tutorial: Disabling CAGS
Figured I'd start doing some tutorials for those interested in doing their own tuning, those who are curious, whatever. If you're interested in seeing more of these, leave a comment to that effect- I don't want to spend a bunch of time on these if there isn't really an audience here for it.
(Note: These tutorials are geared towards HPT, because that's what I use and have access to. However, achieving the same thing in EFI Live should be very similar. The main differences should just be the interface and menu structure.)
Let's start really simple, with disabling CAGS!
After opening the tune file in HPT, click on the Trans menu, and you'll be rewarded with the following screen (without the big red arrow):
We can see that here we have all of the enable/disable parameters for CAGS. There's more than one way to go about disabling CAGS, since we have enable/disable parameters for TPS, ECT, speed, and barometric pressure. One thing that I personally like to do when tuning is to try to stay as consistent as possible; when there is a way to enable or disable a function via ECT, I typically choose that one over any other. So, to disable CAGS, I'm simply going to set the minimum ECT to enable it to something that is not reachable.
In the screenshot above, my mouse cursor is actually hovering over the "Min Coolant" field, and doing so gives us a handy tooltip at the bottom of the window that tells us briefly what the field is, and what the valid value range is for it. Given that, I'm going to increase the "Min Coolant" field from 171* to the max of 493*, as shown below:
You can see that the "Min Coolant" field has changed from blue to red, which signifies that I have made unsaved changes. Once saved, this field will change back to blue. So, save the file, and load it into your PCM! No more CAGS. Unless you somehow manage to hit an ECT of 493*, in which case CAGS is the least of your problems...
Whipple 2.9L S/C, ARH LT's, Flowmaster AMT, HPTuners
bluetorp is offline   Reply With Quote
Old 12-01-2011, 12:40 PM   #2
2SSRS@Gen5diy
2SSRS@Gen5diy's Avatar
Nice keep going.
Old 12-01-2011, 11:30 PM   #3
Three of Swords
Three of Swords's Avatar
Drives: 2011 IBM 1SS/RS L99
While I'm not ready to tune yet, I would definitely love a repository of 'basic tune concepts'.
Eventually I'll get a tune. But I'll want to tweak it, and this would be an awesome way to get into it!
Thank you in advance. Please keep it up.
Three of Swords is offline   Reply With Quote
Old 12-02-2011, 07:47 AM   #4
Tampa Tuning
Drives: TAMPA TUNING FACEBOOK & INSTAGRAM
Camaro performance tuner in Tampa
I like to lower the disable TPS % threshold to zero or 1.
You can do both for overkill, but you have to do one or the other to disable CAGs
The CAGs are such a PITA, I run a special on the Tampa Tuning website to disable the CAGs and reduce torque management for the guys that want just a little touch of freedom from GM.
www.TampaTuning.com
Tampa Tuning is offline   Reply With Quote
Old 01-22-2012, 08:47 PM   #5
Black1SS
Drives: 2010 Camaro 1SS/RS 6 Speed
Keep them coming. These are a great read and would love to read more. Thanks
Black1SS is offline   Reply With Quote
Old 01-22-2012, 09:34 PM   #6
Fuel74
Drives: 2012 Camaro 2LT RS
Fantastic - bookmarking these. Plan on doing my own tune eventually. Thanks for taking the time.
Fuel74 is offline   Reply With Quote
Old 01-08-2022, 10:07 AM   #7
Iceintheback
Iceintheback's Avatar
Drives: 15 Commemorative Edition Camaro 2SS
Sadly Tampa is a bit far from Vacaville, CA... But, if ever there will definitely stop by.
Iceintheback is offline   Reply With Quote
Old 08-09-2023, 06:02 PM   #8
Ck1984
Drives: 2015 camaro LFX V6
Ive only tuned my LS swap pcm with PcmHammer and tunerpro but if i can do the same process with LFX pcm im in for all the free tuning advice you got.
Not sure what CAGS is or if my LFX auto even has it? last time i heard of dreaded skipshifts was on corvette
2015 2LT LFX 3.6L
FE2 Sport Suspension
MXO-6 Speed auto w/Tapshift
Aftermarket Oval mufflers
Ck1984 is offline   Reply With Quote
Old 08-09-2023, 06:45 PM   #9
SlowLS1
SlowLS1's Avatar
Automatics do not have CAGS, it' was GM's version of forced fuel economy for the manual trans. Under certain conditions, it forces you to shift from 1st to 4th gear, been around since the first manual LS1 cars...
SlowLS1 is offline   Reply With Quote
Competitive mode Vs. Disabling TC completely: For Speed/Power mrosa 5th Gen Camaro SS LS LT General Discussions 39 06-27-2013 08:25 PM
CAGS (aka: Skip Shift) De-mysified! Apex Motorsports V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6) 0 04-18-2011 06:07 PM
CAGS (aka: Skip Shift) Apex Motorsports 5th Gen Camaro SS LS LT General Discussions 108 06-25-2010 09:26 PM
Will the Corvette CAGS By-Pass work on the Camaro SS TomServo Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 10 05-25-2009 09:08 PM
