Old 12-02-2011, 10:42 AM   #1
nyrfan
Let's go Rangers!
nyrfan's Avatar
Drives: 13' AGM 2SS/RS L99
V6 Oil Life Monitor readings
I’m beginning to think there may be a problem with mine; I hope not but would like to try and confirm it.
I’ve seen people on these board with 8-10K miles on their current oil change with >20% left on the OLM.
I’ve been tracking my monitor, today I am at 2806 (since my last oil change) and I only have 47% left, from my readings this seams very low, but I’d like to gauge it and see.
Can some of my V6'ers post some of their recent stats? Thanks for the help!!
FSP tuned: 377/389
Old 12-02-2011, 10:46 AM   #2
UT-Engineer
Just Cruisin'
UT-Engineer's Avatar
Drives: 2010 Synergy Camaro
Are you sure your OLM was reset after your last oil change. I do mainly Hwy miles and can get 10,500 miles. I usually change it at 8 or 9K though. Best way is to go for another oil change and reset it again and see if that works. Im guessung it was never reset.
2010 Synergy Green Camaro
25% Tint - CGM Painted GM GFX - 20" Niche M102 Wheels
UT-Engineer is offline   Reply With Quote
Old 12-02-2011, 10:52 AM   #3
nyrfan
Let's go Rangers!
nyrfan's Avatar
I reset it myself, so I am 100% sure it was reset. I drive around 200 miles a week, 50% HW,/50% city, all in "S" mode.
Here are my stats (from Onstar) since getting the car:
Email Date%-----Remaining Oil----- LifeOdometer (Miles)
06/21/2011---------------96%--------------------135
07/22/2011---------------78%--------------------1151
08/21/2011---------------100%------------------2444
09/20/2011---------------87%--------------------3129
10/19/2011---------------69%---------------------4047
11/19/2011---------------51%---------------------4991
FSP tuned: 377/389
Old 12-02-2011, 10:55 AM   #4
formare
The Milano
formare's Avatar
Drives: 2017 Firefly ShipWorks
That seems right to me. It appears you drove 2,500 miles and are at 51% of oil life. No? I am a big fan of not going more than 5,000 on an oil change.
My first Love. She was called "Miss Carriage" (still cry when I think about her)
383, Muncie 4 speed, custom linkage mated to hurst short throw shifter.
formare is offline   Reply With Quote
Old 12-02-2011, 10:57 AM   #5
nyrfan
Let's go Rangers!
nyrfan's Avatar
Correct, but is that actually correct. I see others easily getting 8-10K on their OLM. So which is correct?
FSP tuned: 377/389
Old 12-02-2011, 10:59 AM   #6
formare
The Milano
formare's Avatar
Just a guess - but do you drive a lot of city? It will lower the oil life if you do, or a lot of short trips?
Old 12-02-2011, 11:00 AM   #7
nyrfan
Let's go Rangers!
nyrfan's Avatar
My daily commute is 36 miles, 18 city/18hw. On the weekends, it's mostly city.
FSP tuned: 377/389
Old 12-02-2011, 11:11 AM   #8
Flashpoint135
Flashpoint135's Avatar
Drives: 2016 SS
Both are correct. The system takes into account all kinds of factors, so one person will need an oil change after 3000 miles and another at 10000. That's the point of the system - it does not just count miles.
Flashpoint135 is offline   Reply With Quote
Old 12-02-2011, 11:15 AM   #9
nyrfan
Let's go Rangers!
nyrfan's Avatar
Interesting, I knew there could be some differences, I just did not think that drastic.
FSP tuned: 377/389
Old 12-02-2011, 11:19 AM   #10
RS/4Life
RS/4Life's Avatar
Drives: 2014 2ss/rs
MY first oil change was at 1,600 mi. My next was at 3,000 mi, i don't go by that OLM. i reset my OLM but i use my trip #2 for mileage when when it hits 3,000 i change oil and filter,i have changed my oil 5 times with less than 15,000 mi on car and i don't think it a waste of money. My next one will be Mobile 1
RS/4Life is offline   Reply With Quote
Old 12-02-2011, 11:23 AM   #11
formare
The Milano
formare's Avatar
My thoughts - if you drive the car like a normal car then the OLM will likely be correct. If you drive the car like a sports car, then change the oil at least every 5K. Also, be certain to check the oil level at every fill-up. The LLT uses a huge amount of oil and with VVT a small amount of lacking ol can damage the engine.
Old 12-02-2011, 11:27 AM   #12
RedVert
Drives: 2011 RS convertible - Red
I have 3800 miles on original oil and it reads 25%
[SIGPIC]
RedVert is offline   Reply With Quote
Old 12-02-2011, 11:29 AM   #13
RS/4Life
RS/4Life's Avatar
Drives: 2014 2ss/rs
i check my oil constantly it is always up to par, i measure what i put in and take out. Your oil is the lifes blood of your engine.
Old 12-02-2011, 11:30 AM   #14
nyrfan
Let's go Rangers!
nyrfan's Avatar
I have no plans on following the OLM, I plan to change evey 4K miles (I am using Mobil 1). I just wanted to see if I had/have an actual issue.
FSP tuned: 377/389
best synthetic oil to use hollywoodjose Mechanical Maintenance: Break-in / Oil & Fluids / Servicing 130 01-26-2014 08:51 AM
Gas prices WILL go lower... ga0358 General Automotive + Other Cars Discussion 113 05-02-2011 01:16 PM
GAS PRICES GOING UP 5 CENTS IN GTA APRIL 2ND, 2011 SQUALO Canada 56 04-21-2011 03:19 PM
OIL CATCH CANS john468 Mechanical Maintenance: Break-in / Oil & Fluids / Servicing 5 09-16-2010 02:02 PM
Major U.S. oil source is tapped KILLER74Z28 Off-topic Discussions 32 10-30-2007 09:47 AM
