Old 12-08-2011, 07:50 PM   #1
Dr.Bender
Dr.Bender's Avatar
Drives: 2011 2SS/RS
HELP...Increase MPG?
Hey all, I have recently moved my practice. My 7 mile round trip has turned to a 100 mile round trip a day.
Anyone know how to get more MPG?
Im getting 15mpg.
Please help.
Michael
Dr.Bender is offline   Reply With Quote
Old 12-08-2011, 07:55 PM   #2
POWERFREAK
I.AM.
POWERFREAK's Avatar
Drives: 2011 2SS/RS/A6 cammed-n-whippled
make sure your tires are properly inflated, dont get stuck in traffic, dont do over 75mph, keep rpms under 3,000.
POWERFREAK is offline   Reply With Quote
Old 12-08-2011, 08:04 PM   #3
SC2150
Use premium fuel and do the fuse pull to get the ECU out of the low octaine tables will help, but a "economy tune" can get you 2-4 mpg plus improvement. The Vmax CNC TB will also help.
Old 12-08-2011, 08:07 PM   #4
Devryn17
Suffers Fools Poorly
Devryn17's Avatar
Drives: 2010 SS/RS, CGM w/ Silver Stripes.
I had a 100 mile commute and I got 21 MPG regularly...With my mods...
2010 2SS/RS, CGM w/ silver stripes. Hurst Shifter, long tube headers, full exhaust, CAI, tune. SAE 407 RWHP/402 RWTQ
Momma didn't bronze my shoes, but when I turned 16 I inherited a lead foot.
Devryn17 is offline   Reply With Quote
Old 12-08-2011, 08:08 PM   #5
kiteman
Drives: 2012 45th Camaro, 2SS/M6
i have actually never owned a car (LS1 included) that has suffered more in terms of mpg depending on throttle level. i know it sounds crazy but i really don't think driving your car harder means it uses all that much more gas. after all you are going further faster. the only time i believe it has an impact is at constant high rpms. so if you're going 100mph and at 3k rpm's, that'll eat up the gas pretty quickly. otherwise i think a good majority of it is just urban legend.
i think things like AC, idling, and slow speeds contribute to bad mpg more than anything. i usually reset my average speed and average mpg both before i fill up. i generally have an average speed well under 30mph, usually around 25mph.
kiteman is offline   Reply With Quote
Old 12-08-2011, 08:13 PM   #6
hunter1660
hunter1660's Avatar
Drives: 2011ss/rs camaro
I put a k&n typoon on mine and it gave 3 mpg better not mention the roar when you pun h it. But then punching it has negative mpg éffect. But it sure sounds wicked
hunter1660 is offline   Reply With Quote
Old 12-08-2011, 08:15 PM   #7
hunter1660
hunter1660's Avatar
24.9 mpg
Old 12-08-2011, 08:18 PM   #8
bajamoon
bajamoon's Avatar
Drives: 2014 Subaru WRX
Take it easy on the gas and only run 91 and do the fuse pull like sc2150 said. Not sure how you are getting that low. We drive more of less the same freeways and I am getting 27 with out traffic, 16-17 on the street.
bajamoon is offline   Reply With Quote
Old 12-08-2011, 08:29 PM   #9
MikeOD
Drives: 2010 M6 2SS
...you'd be handing in your man card.
If you have an LS3 and your MPG sucks that much...you're either doing a LOT of city/stop and go driving...or running crappy fuel and the car isn't running the right spark advance.
Most "bolt on" mods don't actually have THAT much of a change...my car got 21 mpg average on my commute to the office when it was stock...with a Vararam, a tune, Kooks 1.875's and 3" full exhaust...it still gets 21 mpg average on the same commute...which is 99% 75 mph through New England hills on cruise control...it is what it is.
...for what it's worth, I reset my average speed one time, when I got the car. I've put 31K miles on it (the original owner did just under 7K) and my average speed is 51 mph...once in a while I'm in the city, but for the most part, I just get to the highway, and go.
2010 Camaro SS M6. Heads/Cam/Intake/Headers/Exhaust/Suspension
MikeOD is offline   Reply With Quote
Old 12-08-2011, 09:22 PM   #10
Juiced1
Drives: 2012 2SS CAMARO 45th
Im getting 15mpg.
Please help.
Michael
I recommend a four cylnder for work and back. It'll help keep the miles of the SS, I'm sure you don't want to rack up to many!
If you have to drive the SS I'd keep it under 70 on the highway.
Juiced1 is offline   Reply With Quote
Old 12-08-2011, 09:34 PM   #11
bannonm
bannonm's Avatar
Drives: 2011 2SS/RS M6 VR
When I was completely stock for the first 850 miles, on the highway according to the computer if I kept it at 60 MPH I would hit 30 MPG. Anything above 65 MPH mileage started to drop significantly. And having any city traffic I drop to the low 20's.
Adding headers and cats recently dropped me a couple of MPG. I can still get low 20's in 40-45 MPH city traffic (lights every mile or so) by shifting quickly and getting into 6th gear and letting the Prius' pass me by. That's the advantage of the manual.
bannonm is offline   Reply With Quote
Old 12-08-2011, 10:07 PM   #12
Nessal
Drives: Exige, Miata, Ghia
My commute takes me 45 minutes to travel 18miles...it's all stop and go. I average about 16mpg. I miss my last job where I only had to travel 5 miles to get to work. If I were you, I would just get a 4 cylinder beater....or a bike....the kind with a motor.
Nessal is offline   Reply With Quote
Old 12-09-2011, 10:20 AM   #13
axis
Search Ninja
axis's Avatar
Drives: 2010 Black 2SS/RS A6
If you're traveling 100 miles per trip, i'd HIGHLY suggest a 4cyl beater. It will save you a TON of $$ in the long run.
Halltech CF 102 fed
GPI modded intake manifold
Bo (knows) White ported TB
Kooks LT's/ Dynomax VT
Pfadted (springs/sways)
Dyno tuned by Rhino and GPI
Old 12-09-2011, 12:37 PM   #14
Shu71
Drives: 2011 Camaro RS M6
Small precise throttle movements; like an egg is under the pedal. Accelerate on downhills, hold steady uphills, basically hypermileing. Push the clutch in and neutral when approaching a stop and coast as far as possible using as little brakes as possible. It is BORING to drive that way though and ANNOYING as hell for those around you. You must have a lot of city driving to be at 15 though. What is your average mph? Do the fuse pull and premium fuel and watch how much throttle you use. If that doesn't help, then maybe a new daily driver is what you need.
Keep in mind a 5mpg increase for your monthly mileage would pay you back $100 plus each month. I drive 2000 miles a month too and I average about 22 mpg versus my old trucks 14 and I've been saving $175 per month.
Shu71 is offline   Reply With Quote
Best MPG boosting mods jackka Camaro V6 LLT Engine, Exhaust, and Bolt-Ons 13 07-09-2010 06:29 AM
Terrible MPG after Airaid installation?? BaylorCamaro Camaro V6 LLT Engine, Exhaust, and Bolt-Ons 32 02-12-2010 12:35 AM
Ford to post 1st monthly sales increase in 2 years camaro5 General Automotive + Other Cars Discussion 18 08-05-2009 01:48 PM
Help Me Pick An Economy Car Marosolid Off-topic Discussions 75 07-11-2009 07:41 AM
Official V6 MPG confirmed at 29 MPG hwy! fastball Camaro V6 LLT Engine, Exhaust, and Bolt-Ons 83 03-23-2009 08:45 AM
