| View Poll Results: take it to dealer? | |||
| take it to dealer |
5 | 100.00% |
| live with it |
0 | 0% |
| trade it in! (J/K) |
0 | 0% |
| Voters: 5. You may not vote on this poll | |||
Thread Tools |
![]() Drives: 2010 camaro 2SS non-RS RJT M6 Join Date: Oct 2011
Clutch noise and 3rd gear grind
2010 2SS: ok so ive been reading alot of threads on here about these problems. i have a very very loud clunking noise when going slow in 1st gear and pushing the pedal in. took it to the dealer they said operating as designed. after reading on here i guess that is just the nature of the beast. but going into third gear it seems to be grinding no matter what temp the trans is at. second gear doesnt do it much, only a few times. i dont want to take it to the dealer to have them say its fine or normal or whatever excuse they have. do you guys think if i took it in they would actually fix it? the car is bone stock with 28k miles on it. bought it used in october with 25k miles on it. clutch always made the noise 3rd gear started within the last 1000 miles. any insight is appreciated!
o yea ive also taken it in because of all the paint chips by the rear wheels and front bumper cover. the front is completly covered in chips and the sides in front of the back wheels are pretty much the same. dealer said not their problem. but i love this car otherwise
taking it to the dealer on the 29th. hope they will fix it
RIP JoePa
Drives: 2010 2SS/RS & 2001 Audi S4 Join Date: Apr 2010
is the car modded? they have to fix the trans. you didn't notice the paint chips before you bought it?
nope the car is bone stock. i didnt notice any chips on the car at all untill my first car wash. when we took it to them they said they were there but they covered them with something im not sure what (my wife took it in) and said it comes off in a car wash sometimes not their problem. sounds like bs to me so i will have to live with them for now
#6 |
![]() Drives: 2019 GMC Sierra 1500 AT4 Join Date: Nov 2011
I get the same clunk noise in 1st at low revs. It feels like play in the driveline. It doesn't do it at moderate or high revs, just usually around the parking lot (and mostly when the engine is cold).
The grinding needs to be checked out thought. That is a common problem with the TR-6060 transmission and needs to be fixed. If one dealer wont, go to another one.
Summit White 6" Lift, 37x13.50R24's |
#7 | |
Ed M.
RJT 2SS/RS, AAM 3.70's, MTI Sway Bars, Shifter, SS brake lines ZLI calipers, rotors/pads BMR Trailing & Toe Arms, rear cradle/diff bushes, Pedders XA's, Camber/Toe eccentrics, Radius arm inserts, GTO clutch reservoir, LS9 cam, Comp valve springs, Melling 10296 oil pump, CR5 timing chain, LS6 damper, CAI Cold Air Intake, ARH LT headers, HF cats, GMPP axle back, Elite Eng Catch Can, Black ZL1 20x10 & 2011 whls 285/35/20 & 305/35/20 General G-Max RS, 2011 Convertible spoiler, 1LE front spoiler, Lloyd "SS" Floor Mats, GM Camaro Trunk Mat, wrapped console, hand brake lever, Grant steering whl.
#8 |
thanks for all the info! i upgraded to the dot4 brake flid already because what came with the car was almost black. but did not put in a serperate resevoir yet. thanks for the info on the clutch noise im glad its normal even though anoying lol. i have it scheduled to go to the dealer on the 29th to get the trans checked out. thanks guys i love the camaro5 forum!
#9 |
just an update. the car is at the dealer got the oil changed and they could not get it to grind. so me and my wife drove the tech and service advisor around. they both also drove the car. everything is working perfect. but they decided to keep it over night and will drive it cold, said if anything sounds like a grind they will tear into the trans and pay for a rental. if all checks out ok they are going to fill it up with gas
im pleased and hoping they hear it
#10 |
![]() Drives: 2010 2SS Join Date: Nov 2011
I traded my C6 Corvette for a 2SS and what a nightmare this Camaro has been. 1st - 3rd gear sychronizers were bad. The dealer had my car for 3 weeks and rebuilt the transmission 4 times. Finally gave the car back to me and 3rd gear still has intermittent issues, grinding! Took the POS back to the dealer and they won't fix it, claim nothing is wrong with it. Took to another dealer, the service advisor drove with me and agreed that there's an issue but the service manager claims its normal. I hate this car!!! Should have never traded in my Corvette.
#11 |
![]() Drives: 2011 1LT Camaro Join Date: Nov 2010
i had the same problem with my transmission, sometime it would enter 3rd or it would throw it back out, but anyway i took it to the dealer and GM gave me a new transmission. lets see how this one does.
#12 |
![]() Drives: 2012 camaro ss/ls3 m10 transmission Join Date: Mar 2012
camaro good but not great
took my camaro in with the same exact problems grind shifting into third and poping out of second while making a clanking clacking noise at a idle took it in to reliable chevy alb nm turns out chevy issued a recall on all manual transmission for failure on the slave cylyinder becouse of this it cuased the clutch to be worn down so new clutch and pressure plates with fixed cylider thankgod for warranties and recalls most likely will sell my camaro after this dissapointed to much money spent for my car to be in the shop all the time
#13 | |
![]() Drives: 1972 Z28 Join Date: Mar 2009
mystery noises in the front end, Why couldn't they spend a little more time engineering before they put them on the market. Problem solved got a 012 Mustang GT I can't believe two cars can be so different 3:73 manual no problems at all I have owned a Camaro from all generations and the 010 was the worst. I never owned a Ford I know there were issues with the trans but they made changes in production to make it right.
#14 | |
![]() Drives: camaro Join Date: Feb 2012
| Rear End Gears 101 | danhr | V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6) | 93 | 12-23-2025 06:01 PM |
| 1st and 2nd gear problems. 1SS 6M | jnm2003 | V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6) | 7 | 10-29-2019 01:22 PM |
| 3rd gear grind | ICEMAN 316 | 5th Gen Camaro SS LS LT General Discussions | 20 | 02-20-2011 01:37 AM |
| Camaro 2010 Issues | Tim's.2010.Camaro.SS | Camaro Issues / Problems | Warranty Discussions | TSB and Recalls | 57 | 06-04-2010 10:27 AM |
| QC missed something-- AC Compressor making a whining noise under engine load | Kyle.Gilmour | Camaro Issues / Problems | Warranty Discussions | TSB and Recalls | 12 | 10-09-2009 11:42 PM |
