![]() Drives: 2010 camaro 2LTRS black w/ white Join Date: Mar 2009
Quick question
Okay beings as the battery is in the trunk will this be bad for say - degree weather. As in does the battery being in the trunk make a difference in cold weather?
Thanks |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2006 Silverado SS, 2009 G8 GT Join Date: Aug 2008
The only time you use the Batt is for starting....soooo it shouldnt make a diff
I wasnt very in depth with that.....sorry
It shouldnt make a diff unless you are starting the car in very low temps....as in below zero... What does CCA mean? Cold Cranking Amps is a rating used in the battery industry to define a battery's ability to start an engine in cold temperatures. The rating is the number of amps a new, fully charged battery can deliver at 0° Farenheit for 30 seconds, while maintaining a voltage of at least 7.2 volts, for a 12 volt battery. The higher the CCA rating, the greater the starting power of the battery. |
Okay thanks because i live in south dakota and it does get pretty cold here in the winter i do have a car which i will be driving when the roads are icy and stuff but beings as i dont really have a garage to store my camaro i was planning on driving it when it is just cold outside and good road conditions(happens most of the time).
If there are any doubts in your mind you could always by a battery with a higher CCA rating!
#6 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 00 Blazer Join Date: Aug 2008
You won't need more amps than what it will ship with. You might want some battery action if your adding lot of electronics to the vehicle. Otherwise stock is fine. It's a large battery already. If anything it will be better inside in cold weather than in the engine compartment. As the engine compartment is open air on bottom and the inside is of course weather sealed.
#7 |
The Mark of Excellence
Drives: 2010 ABM 1SS RS LS3 Join Date: Jan 2009
Is a battery warmer under the hood than in the trunk after a cold night outside?
BMR, CAI, DynoMax, Elite Eng., Hurst, Jannetty, Clear Image Headers & Hi Flow cats, Jet Hot, LSR, TSW, VMax, Vredestein |
#8 |
![]() Drives: 2012 Camaro 45th Ann SS Join Date: Oct 2008
My Lincoln LS has it's battery in the trunk and we have gotten plenty cold in Toledo the last 5 years. I have had zero problems with it and say that I prefer it in the trunk for weight and space under the hood. Plus it stays a hell of alot cleaner in the trunk well.
#9 |
Faith Keeper
Drives: 2012 Silverado LTZ, 2010 2SS/RS Join Date: Nov 2008
Battery is in the trunk on my G5. No problems whatsoever.
These things are taken into account when the car is made. They won`t let something like that slip by em. |
#10 |
My Cobalt has the battery in the trunk... no issues either. Although we really don't get that cold here.
GHOST · 2SSRS
Order Date: March 28, 2009 // DoB: June 19, 2009 // Arrival Date: July 2, 2009 Current Modifications:
#11 |
Alright thanks alot for all the help
| Quick question about HID and Halo LIghts | ttazzijr700 | 5th Gen Camaro SS LS LT General Discussions | 81 | 01-30-2011 09:43 PM |
| New member and I have a quick question | ch3vysrcool | 1st & 2nd Generation Camaros | 3 | 03-18-2009 06:17 AM |
| Quick question about my Camaro production. | CamaroEnergy4Life | 5th Gen Camaro SS LS LT General Discussions | 1 | 03-17-2009 08:27 PM |
| quick performance question | brantley847 | Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons | 13 | 09-28-2008 10:59 PM |
| New Member, Quick Question | NateZ | 5th Gen Camaro SS LS LT General Discussions | 10 | 10-11-2007 11:59 AM |
