![]() Drives: Black 99 Camaro V6 5 Speed Join Date: Nov 2011
Blinker not working?
My right turn signal isnt working.
I click it over and it just lights up on the dash (not blinking) and on the outside the front and back blinker dont light up or anything....Can anyone help?
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2001 Camaro 3.8 Join Date: Jul 2010
MAybe a relay?
2001 Camaro V6
2016 Camaro 2SS |
Gunning for Sixth
Drives: '03 ZR2 Blazer Join Date: Sep 2008
Daytime running lamp bulb is dead. Check the side that isn't blinking in the front or back for a dead bulb.
^ Me. Things I write ~>
Drives: 2010 Camaro SS Join Date: Nov 2011
Change the bulb out on the side that doesn't blink.
ndtguy
New DD: 2010 Camaro SS L99/A6 - bone stock. Gone but not forgotten... - 2001 Camaro SS m6 - SLP lid, free ram-air mod, poly sway bar bushings/end links, BMR springs and bilsteins. - 1998 Trans Am m6, forged 347, T70;alky-water injection; intercooled, 208/230 .549/.579 121LSA, Moser 12 bolt, 561rwhp/611rwtq. |
Official Lounge BAMF
Drives: '97 Camaro Join Date: Oct 2009
Means you've got a bad turn signal bulb..... usually on mine, when the light stays on, you can stand outside and the turn signal will stay on, so the one that isn't on is the one that's burnt out |
#6 | |
Gunning for Sixth
Turn signal.. Y U NO WURK- Dual Filament!? FFFFFFFUUUUUUUUUUUU!!! /reddit |
#7 |
the front and back bulb light dont blink thou.
the dash light just stays lite like this
#8 | |
Gunning for Sixth
You need to get under the car and pull the bulbs. Check them all because just ONE bulb out will trip the blinker to go solid AND kill the lights on that side no matter which bulb (front or back) failed. Check LS1tech.com for more information. |
#9 |
Maroboy2001 AKA Offset
Drives: Boosted Trans Am Join Date: Oct 2011
You can go from the top and reach under the headlamp to unmount the bulb from the blinker.. I have the same issue but instead of replacing the blinker bulb i replace the fog lights
#10 |
SS #2431
Drives: 2001 Pewter Camaro SS Join Date: Jul 2009
When that happened to my car I replaced the flasher and it fixed it, try that maybe. easier to get to than getting the bulb... and flashers are pretty cheap
![]() 2001 SS Lid, LT's, 3" Y to 4" Borla XR-1 dumped, LCA, LCA Brackets, Dbl. Adj. Panhard, Subframe Connectors, Shock Tower Brace, Eibach Prokit, Eddlebrock Shocks, C6 ZR1 Wheels 18x9.5 |
#11 |
Ok Thanks guys
#12 | |
Butter Bar!
Drives: 2011 SS, 1998 Trans Am Join Date: Dec 2010
I remember my discovery of this. Kept checking and was like WTF!? Although a 98+ Camaro should have the same problem.
2011 Camaro SS, White/Orange, LSR Short Throw, CAI
1998 Trans Am, Red, H/C/I, 3200 CircleD Stall, full suspension 2004 GSXR 1k, Matt Mladin Edition |
| Tags |
| blinker |
| Heat not working and vents wont change position | woolfman72 | Camaro Issues / Problems | Warranty Discussions | TSB and Recalls | 19 | 11-05-2018 05:05 PM |
| Working this weekend-might as well work on car too. | kmhene | 5th Gen Camaro SS LS LT General Discussions | 8 | 09-04-2011 01:21 PM |
| Blinker sound / Blinker click | xxlbeerz | Audio, Video, Bluetooth, Navigation, Radar, Electronics Forum | 4 | 05-08-2011 01:33 PM |
| Microsoft working with automakers. | TAG UR IT | General Automotive + Other Cars Discussion | 11 | 02-23-2008 01:21 AM |
| GM working on hybrid power plug-in for Saturn Vue | KILLER74Z28 | General Automotive + Other Cars Discussion | 0 | 11-29-2006 02:40 PM |
