Old 12-15-2011, 08:50 PM   #1
cnwalden24@gmail.com
cnwalden24@gmail.com's Avatar
Drives: Black 99 Camaro V6 5 Speed
Stick shift Leather
Ive got a few questions
first off when i bought the car the leather that covers the stick shift was broke as in the plastic that holds it in place was broke in half so somtimes when i shift it comes up...looks trashy didnt know if i sho0uld just glue it or if a new one would be easier
1. Whats the leather called on the stick shifter? (not on the knob but surrounding it)
2. Are they easy to fix? and how much?
cnwalden24@gmail.com is offline   Reply With Quote
Old 12-15-2011, 08:54 PM   #2
GTFD2
Drives: C7 2LT Vert 2014/2LT RS 2012
I think it is called a BOOT
GTFD2 is offline   Reply With Quote
Old 12-16-2011, 12:21 AM   #3
helmincamaro
Official Lounge BAMF
helmincamaro's Avatar
Drives: '97 Camaro
Send a message via AIM to helmincamaro Send a message via Yahoo to helmincamaro
so the shifter boot falls down? Its pretty easy to fix.... just need a zip tie. Take your shifter knob off and remove the trim piece around the base of the shifter boot and pull the boot up and inside out. There should be a little notch on the shift lever where the top of the boot should be..... with the boot inside out, put the top of the boot on that area, then put the zip tie around it, tighten it down and trim it off as close as possible.... then just flip the boot down and put everything back together and your good to go
Originally Posted by BowtieBelle View Post
I so didn't want to see poor dead white mouse butthole
helmincamaro is offline   Reply With Quote
Old 12-16-2011, 04:23 PM   #4
well actuly it does that too lol but its the opposite its the base that comes up like the plastic that hold its down broke inside
Old 12-16-2011, 07:28 PM   #5
Zabo
Gunning for Sixth
Zabo's Avatar
Drives: '03 ZR2 Blazer
Ah, the retaining ring finally broke, didn't it? Common as all hell and actually, someone fixed this:
http://6litereaterdesigns.com/store/...roducts_id=256
Answer was to make up a wire retainer ring out of heavy gauge steel wire. I plan on getting one eventually when I change out my boot.
Best places to look for things like these:
ws6store.com
Zabo is offline   Reply With Quote
Old 12-18-2011, 07:00 PM   #6
ahhh thanks man
leather jacket, manual, shift knob
Tips for first time Manual Transmission Drivers from a new Camaro Owner (First post) LoneCynic 5th Gen Camaro SS LS LT General Discussions 44 04-03-2016 02:46 AM
FS: OEM GM Leather Shift Knob White Stiching Camaro Freak Interior Parts & Accessories 6 12-22-2010 11:46 AM
OEM Leather Shift Knob Part Number Needed kmac1705 Cosmetics and Lighting Modification Discussions 4 12-07-2010 07:40 PM
stick shift shoot out SEABEE USA - Southcentral 0 08-10-2010 09:00 PM
I fail at Camaro, stick shift & life (a self deprecating rant) tommygun6644 5th Gen Camaro SS LS LT General Discussions 58 01-19-2010 02:11 AM
