Old 12-16-2011, 06:45 PM   #1
siriusdish
Drives: 2010 Camaro L99
Cheap rear rims 18's ss
Know of any good places online that sell a rim for 18" DR's? Corvett 40mm I see will work but I have not see any on Ebay. Maybe I am not looking right? Also how does the Tire pressure System work with 18's?? Also I read that the rear tire has to be the same height of the front. What size 18" DR's are recommend for the stock P-zero's on the front? My Dad wants the widest rears he can get on his car. I looked at the recommend tire size thread but I am not going to lie, it's over meThank you, this is new to me!
2010 L99
vararam intake, Vmax TB,Vmax Intake,TSP VVT 3 Cam,TSP underdrive pulley,Yank 3600,TM Cooler,ARH 2", High Flow cats, X-pipe, GM Pro mufflers, RX Catch Can,160 stat, BMR Trailing,toe,Cradle insert, Diff. Bushings, End links, Spohn-LCA's (Touring)Wheel spacer's. 422 rwhp Mustang Dyno http://www.youtube.com/watch?v=AaFNAhCL7Os
siriusdish is offline   Reply With Quote
Old 12-17-2011, 01:03 AM   #2
SUX2BU
Quit being a pu$$y
SUX2BU's Avatar
Drives: FAST
These are PERFECT!
http://www.camaro5.com/forums/showthread.php?t=187991
SUX2BU is offline   Reply With Quote
Old 12-17-2011, 11:51 AM   #3
siriusdish
Originally Posted by SUX2BU View Post
What offset on the rims that U are talking bought? 18x10.5 replica Corvette. 58 56 offset?
2010 L99
Old 12-17-2011, 09:12 PM   #4
SUX2BU
Quit being a pu$$y
SUX2BU's Avatar
Drives: FAST
Either one should work, but if course the lower the offset the better.
I have them on 18x11 wheels with 48mm offset and the tires still have about 1/2" (12.7 mm) clearance on the inside. The 18x10.5 wheels with 58mm offset wheel will sit 4mm (.157") farther in (http://www.1010tires.com/WheelOffsetCalculator.asp) so they should only have 8.7mm (.342" just over 1/3" of clearance which is cutting it close but still ok).
Obviously the lower the offset, the more clearance you will have on the inside.
Old 12-17-2011, 11:28 PM   #5
siriusdish
Z06 18x10.5 56mm will be ok then? Thanx!
2010 L99
Old 12-20-2011, 05:57 PM   #6
siriusdish
Taking that these rims will work after seeing that zo6 will work. Still need to know bought the Tire Pressure System and if its possible to have working on them rims and how. Then what size DR will be good for these rims? Thanx!!!
2010 L99
Old 12-20-2011, 06:02 PM   #7
Supercharged SS
Drives: 2010 Camaro
You DO NOT want the rims mentioned above. The offset that you're looking for is 40 mm. Anything else and you'll need a spacer. 10.5 is to wide. You want the C6, Z06 Replica FRONTS. 18 x 9.5
As for the TPMS. Simple. It won't work unless you buy new sensors then set them up for the car. It doesn't much matter if you are just using these for the track. The light will come on after enough driving but that's all.
Old 12-20-2011, 06:05 PM   #8
siriusdish
He wants to leave the rims on from the spring till fall. So 40 mm I will have to look for then. Spacer would be no good from what I read! As for the TPMS they have to be for that rim correct?
2010 L99
WANTED: (2) Original 2010 Camaro SS RS REAR 9" x 20" RIMS (MIDNIGHT 's) camaro99 Canada 0 04-16-2011 08:51 AM
FS 2 rear SS rims powder coated flat black lawdogg149 Wheels / Tires 4 07-29-2010 08:14 PM
2010 Camaro SS Blue in Syracuse NY $32690 Mitsubishi in Syracuse Camaro Price | Ordering | Tracking | Dealers Discussions 0 12-31-2009 02:44 PM
2010 Blue SS for $32990 and we pay for your plane ticket! Mitsubishi in Syracuse Dealer Camaros for Sale 0 12-21-2009 12:42 PM
2010 Camaro SS V8 in Syracuse NY-FREE TRAVEL TO PICKUP Mitsubishi in Syracuse Camaro Price | Ordering | Tracking | Dealers Discussions 0 12-10-2009 04:23 PM
