Old 12-16-2011, 09:58 PM   #1
A7x6
A7x6's Avatar
Drives: black camaro orange stripe 2ls
Check engine light after installing cold air intake!! >=[
dammit the stupid CEL came on 50 miles after i installed a spectre cold air intake. on star did a diagnostic and pulled up codes for the car running lean at cruise and idle and the air fuel ratio isnt correct. anybody know a solution to this problem? i know everything is working fine because its obvious that a intake sucks in more air therefor there is more air going in the chamber than fuel. the CEL is annoying and i want to get rid of it.
any suggestions?
A7x6 is offline   Reply With Quote
Old 12-16-2011, 10:07 PM   #2
Muscle SS
All blackkk
Drives: 2010 2SS/RS LS3
Back to stock or get a tune. Running lean is bad.
Drivin it like I stole it.
Muscle SS is offline   Reply With Quote
Old 12-16-2011, 10:15 PM   #3
its a syn
B.O.D. 02/16/10
its a syn's Avatar
Drives: 2010 SGM Sp. Edition 2017 RS Conver
unplug battery for half hour to an hour reinstall let idle for 5 mins. should be good to go. just needs to do a learning session which you might have not done to start with. if it comes back on definatly have it checked out. had the same problem with my ported throttle body, no biggie everything workes fine.
its a syn is offline   Reply With Quote
Old 12-16-2011, 10:18 PM   #4
A7x6
A7x6's Avatar
i hope that works ^^
Old 12-16-2011, 10:20 PM   #5
its a syn
B.O.D. 02/16/10
its a syn's Avatar
leave it off over night if you want,but a minumum of half hour and you'll be fine
Old 12-16-2011, 10:22 PM   #6
A7x6
A7x6's Avatar
does it make a difference?
Old 12-16-2011, 10:28 PM   #7
its a syn
B.O.D. 02/16/10
its a syn's Avatar
no, just a matter of giving it enough time to reset the fuel trims and air sensors. I don't have an exact time I think I got by with an half hour wait maybe 1 hour
Old 12-16-2011, 10:30 PM   #8
its a syn
B.O.D. 02/16/10
its a syn's Avatar
gotta go will check back tomorrow
Old 12-16-2011, 10:32 PM   #9
A7x6
A7x6's Avatar
ok thx for the help
Old 12-16-2011, 10:33 PM   #10
insomniac2k2
Drives: 2012 2SS/RS IOM
You did make sure that your MAF was not reversed right?
insomniac2k2 is offline   Reply With Quote
Old 12-16-2011, 10:34 PM   #11
A7x6
A7x6's Avatar
it wouldnt fit if i put it the other way i doubt thats the problem
Old 12-17-2011, 01:00 AM   #12
insomniac2k2
Worth looking at. They have an arrow that shows the correct direction.
Old 12-17-2011, 10:15 AM   #13
Tigwelder
Drives: 2011 1LT Black with Orange stripes
Check your install...go over everything, make sure everything is tight and aligned properly.
2011 1LT, Black w/iom stripes,Dynomax Vt axleback,K&N cai,gauge package,rear spoiler,19"polished wheels,Fesler shift boot,premium sound.
Tigwelder is offline   Reply With Quote
Old 12-17-2011, 02:24 PM   #14
A7x6
A7x6's Avatar
everything is clamped tightly and i left some room when i connected the pipes
Cold air intake/ Check Engine light. Need Help! edcamaro29 Camaro V6 LLT Engine, Exhaust, and Bolt-Ons 64 02-17-2024 05:40 PM
Diagnostic Trouble Codes (DTCs) for OBD II equipped GM vehicles steeleshark2 Tuning / Diagnostics -- engine and transmission 11 04-08-2020 11:49 PM
Roto-Fab | Engine Covers - S/C | Fuse Relay Cover | Radiator Cover | Billet Oil Cap+ AutoAgenda Exterior Parts & Accessories 14 02-06-2013 09:43 PM
Acronyms at C5 hokie2012 5th Gen Camaro SS LS LT General Discussions 34 08-10-2011 04:56 PM
Acronyms? KEEP RT Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 20 03-11-2011 09:57 PM
