Old 12-21-2011, 05:17 AM   #1
clarkshome
clarkshome's Avatar
Drives: 2012 Inferno Orange SS Camaro
To Tune or not to Tune
Here is my question to all the "Camaro Gurus" out there. I am planning on installing a Airaid intake and Doug Thorley Cat Back exhaust (and possibly later high flow cats) to my 2012 SS. I have a reputable performance shop that is telling me that even though there are some CAI that might no throw out a CEL that the vehicle should still be tuned anyways since you are changing the make up of the vehicle.
I know the shop is probably right. I just want to know if I am leaning the car out too much without tuning and would the EMC adjust itself to make up the difference? I know the vehicle would run much better with the tune but I am on the fence about doing one.
" It Is Better To Die On Your Feet Than To Spend A Lifetime Living On Your Knees"
clarkshome is offline   Reply With Quote
Old 12-21-2011, 07:23 AM   #2
n116ebo
n116
n116ebo's Avatar
Drives: 2010 2SS YELLOW TRANSFORMER AUTO
I feel your pain. I have almost 3 year warranty left on the 5 year. My pocket book has no problem buying the tune, but a little voice keeps saying "what if you have a drive train problem?" I wish I had brass b*lls and wouild just bite the bullet. chicken! chicken!
n116ebo is offline   Reply With Quote
Old 12-21-2011, 07:38 AM   #3
Steck
Drives: 2006 twin turbo Corvette Z06
When you change the air intake, you definitely need to get it tuned to correct the MAF calibration. This becomes especially important for automatic cars so that torque reporting is more accurate.
Steck is offline   Reply With Quote
Old 12-21-2011, 07:59 AM   #4
clarkshome
clarkshome's Avatar
I might just go ahead and do it. I've been told that once you drive a tuned car you will absolutely love it and wish you would have do it sooner. Anyways, these engines are tough and way underpowered and will easily take a few mods without even knowing about it. I have never, ever had a drivetrain problem with any car I have ever owned, as long as you do your regular maintenace and are not racing or tracking the car I don't think warranty should be an issue. (hopefully
Old 12-21-2011, 01:11 PM   #5
apeko
apeko's Avatar
Drives: 2011 2-SS/RS SGM
+1
2011: 2SS/RS Camaro Synergy Metallic
apeko is offline   Reply With Quote
Old 12-21-2011, 03:10 PM   #6
geaux_tigerss
geaux_tigerss's Avatar
Drives: 2019 GMC Sierra 1500 AT4
Remember folks, a tune is not a guaranteed warranty kill. It depends on the dealer and whether they want to work with you or not. Totally wreck your motor or transmission and GM will likely require an ECM check before repairs are authorized. Smaller problems may not be an issue. Also, never underestimate the power of an anonymous "gift" to the dealer service manager .
Also, the whole warranty isn't gone. Power seats stop working, windows don't roll down anymore, radio dies, still covered, ECM tune or not. That 3 year/36,000 mile bumper to bumper is still valid and will cover a great majority of common problems.
Do what you want.
However, don't ever listen to someone that says you HAVE to tune with an intake and catback (or even high flow cats or long tubes). It will not hurt anything to run without it. Always remember, you are dealing with salespeople. Most are great people, but they don't eat if they don't sell. Keep that in mind at all times.
Summit White
6" Lift, 37x13.50R24's
geaux_tigerss is offline   Reply With Quote
Old 12-21-2011, 03:13 PM   #7
insomniac2k2
Drives: 2012 2SS/RS IOM
My Airraid does not throw a CEL if that helps.
insomniac2k2 is offline   Reply With Quote
Old 12-21-2011, 05:35 PM   #8
Steck
People with automatics need to have the MAF calibrated if they want their A6 to survive and not destroy itself from inaccurate torque reporting.
Old 12-23-2011, 06:47 PM   #9
geaux_tigerss
After which mod (that I previously listed) and why?
Summit White
Old 12-23-2011, 10:40 PM   #10
Steck
A cold air intake changes the MAF calibration. The MAF in these cars is a slot MAF that is inserted into a housing. The size of that housing and the penetration depth into the airstream changes the MAF calibration, along with bends before and after the MAF. A good rule of thumb is that if you have three diameters of straight tube before the MAF and one diameter of straight afterwards, the metering won't be impacted by the bends.
The PCM/TCM rely heavily on the MAF to estimate the torque output of the engine. This delivered torque value is used by the TCM to help determine shift times and pressures along with how much timing to pull for torque management. If the reported torque value is too low or too high, the transmission will use the wrong values to complete the shift which can result in a very lazy shift that slips the clutch packs excessively or a very harsh shift which might snap something in an extreme case.
Old 12-24-2011, 12:13 PM   #11
Slowhawk
Drives: 1999 Trans Am
This is correct.
You can still play the no tuning game but it's up to the owner.
Slowhawk is offline   Reply With Quote
Old 12-24-2011, 02:55 PM   #12
Phantom.5SS
Hell yeah I'm Guilty.....
Phantom.5SS's Avatar
Drives: 2010 2-SS ABM NON-RS
???? I installed an American Thunder cat-back and a C.A.I industries cold air..so your saying I need a tune to save my auto trans????????????????????????????????????????????? ?????????????????????????????????????????????????? ?????????????????????????????????????????????????? ???
Phantom.5SS is offline   Reply With Quote
Old 12-24-2011, 05:15 PM   #13
Rhino79
Rhino79's Avatar
Drives: 2010 Camaro SS L99/Auto
Ideally, you would retune it. They are correct that the transmission shifts are based on tq values. Inaccurate tq values will equal inaccurate shift pressures and timing.
Rhino79 is offline   Reply With Quote
Old 12-26-2011, 08:43 AM   #14
apisxv
apisxv's Avatar
Drives: 2010 SS
I just put on Roto Fab intake and MRT axle backs. Wondering same thing. So, I guess the performance module I bought off Ebay wont do the trick? LOL. Didn't think it would, but for $25 and no risk of affecting any significant mechanical changes or leaving a footprint, I had to do it to see what happens...
apisxv is offline   Reply With Quote
MarylandSpeed DYNO TESTED: Diablosport Predator Canned Tune on 2010 SS A6 MarylandSpeed Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 27 05-18-2013 10:01 PM
Camaro SCT tune Vs HP TUNERS tune by Tampa Tuning Tampa Tuning Tuning / Diagnostics -- engine and transmission 21 02-08-2012 07:06 AM
•► ► AUTOCAL E-MAIL TUNE TOOL @ Corvettes of Westchester - ON SALE NOW! ◄ ◄• Sales@CoW V8 Bolt-Ons & Tunes 1 10-13-2011 09:12 AM
Manual vs Auto GTAHVIT vs PQ... The video wars. 76z28 5th Gen Camaro SS LS LT General Discussions 443 08-26-2010 12:26 PM
Lets play a game 2SSRS@Gen5diy Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 56 09-26-2009 09:08 AM
