Blu808 Spec Front Suspension Conversion System
This is the absolute best performance handling modification available for the 5th gen Camaro. Every component in this system has been engineered by Conrad Grunewald to work together to deliver race car specific handling. With an entire season of professional racing into the R&D process you can have confidence that you are getting the absolute best.
Our Blu808 spec system has won every Redline Time Attack series race that it has been entered into, along with setting a new lap record on Streets Of Willow Raceway. This all combined with a full season of the Formula Drift professional series. Our Camaro, using this system and street tires set a lap time 2 seconds faster than a Corvette ZR-1 ! System Benefits: Saves over 60 LBS of unsprung weight! Corrects roll centers for lowered cars! Drops front ride height 1" to improve control arm angle! Replaces all factory bushings with spherical bearings! Corrects ackerman angle Increases steering angle from 31degs to 55 degs! Improves steering response! System includes Blu808 CNC machined billet aluminum uprights x2 Blu808 Cromoly tig welded control arms x2 Blu808 T308 Outer tie rod assembly x2 Blu808 T308 Misalignment spacer x16 Blu808 Hardware package x2 Aurora r99 Spherical bearing x6 Aurora r14 Spherical bearing x2 This is the ultimate in performance for your 5th gen Camaro. The uprights were designed using Auto Cad and Solid Works. They are CNC machined from a single 44 lbs block of aluminum. Machining time is 8 hours per pair resulting in a individual weight of 8 lbs for each upright. Every control arm is Tig welded by a AWS certified welder in a purpose built jig. All Blu808 Items are made in house. Video: http://vimeo.com/16803941 ![]() ![]() ![]()
Blessed
Drives: 2013 Sonic RS MT Join Date: Dec 2007
HOLY!
That is just so damn sexy
Click image to see build thread. PQ - "the love of cars. It's a boys first step toward manhood and a mans last hold on boyhood." Fbodfather - "We do not want to use the Z28 moniker on a car that does not deserve this hallowed name." The_Blur - "Let's not confuse competitors with equals." |
Blessed
sorry for the double post... but I have some questions.
Can you guys help me understand the need for spherical bearings? Are they as noisy as some claim on a DD car. if so, with all the kick ass geometry changes you've made, can any stock or stock replacement items be used with your uprights to avoid the spherical bearings??? Thanks! Chris
![]() Drives: 2011 2SS/RS Camaro Join Date: Jun 2011
That stuff looks great guys, nice work. That knuckle is a sexy work of art my friend, nice job on the innovation.
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: '69 SS Convertible Join Date: May 2009
So this is only needed if you plan to go drifting?
Build Journal ![]() |
#6 |
Beautiful stuff!!! But I hate to even ask.....how much $$$$??? PM Please....
#7 |
![]() Drives: 2010 IOM 1SS M6 Join Date: Jun 2011
I would love to have that setup. Too rich for my blood right now though lol.
#8 | |
Drives: Camaro Justice Join Date: Jun 2007
It is designed for a race car by a race car driver and it looks like Conrad did a damn good job. The increase in how much the wheels turn is dramatic. The OD of the arms has been dramatically reduced. Putting loops on the end large enough to hold factory bushes wouldn't make much sense. It is serious high end purpose built mod. |
#9 |
This is a purpose built suspension system. It is ideal for a race car and there are a few people who daily drive with it.
We have used this system in road racing and drifting and is built for both. In a drifting application it creates upto 55 degrees of steering angle and quickens the steering response. In a racing application it reduces unsprung weight, eliminates the squishy bushings, corrects roll centers, and quickens the steering. There is no noise with this system. It uses high quality Teflon coated heim joints! The benefit of a heim joint is there is no deflection, or deformation. This creates rock solid precise handling. The system is on sale this month at a savings of $900 over our regular price. Link to system. http://www.blu808.com/Blu808-Spec-Fr...aro_p_350.html This system is designed and intended for race cars, and will need to be professionally installed with a proper alignment. |
#10 |
Drives: 2010 Camaro, 2006 Z06 Join Date: Feb 2009
Hey Luke, great work on this stuff. It was awesome to see the Blu808 operation in person. These are some SERIOUS parts for serious Camaros!!!
#11 | ||
Blessed
#12 |
Do you have any pics of this setup installed?
#13 |
Drives: 1994 1LE / 2006 Z51 Corvette Join Date: Jul 2009
Nice work!
#14 |
OK I just saw the link to the Vid. plenty of good info/pics in there.
I am assuming a stock style strut is still used and not a cutom made unit? Looks like a stock style swaybar as well. What size wheels are on the car in the vid? Thanks!!! |
| Supercharger / Turbocharger Results (INFO) Thread | radz28 | Forced Induction - V8 | 273 | 08-15-2023 04:44 PM |
| Hotchkis: Tuned Suspension Setups | Springs | Chassis Brace | Sway Bars | FREE S&H | AJ@ECSMotorsports | Suspension / Chassis / Brakes | 80 | 11-17-2010 02:28 PM |
| Maximize Your Suspension ~ Hotchkis Swaybars, Springs and Chassis Braces! | Circuit Motorsports | Suspension / Chassis / Brakes | 99 | 05-24-2010 04:21 PM |
| 2010 Camaro SS Blue in Syracuse NY $32690 | Mitsubishi in Syracuse | Camaro Price | Ordering | Tracking | Dealers Discussions | 0 | 12-31-2009 02:44 PM |
| 2010 Blue SS for $32990 and we pay for your plane ticket! | Mitsubishi in Syracuse | Dealer Camaros for Sale | 0 | 12-21-2009 12:42 PM |
