One of the new P13W plasma bulb for fog light is acting weird
Hey Guys,
I just finished installing the new P13W plasma with the harness; I am sure the connections are correct and follow all instructions but the passenger side fog light is acting weird here is what is doing: When I unlock the car with the remote control, both Fog plasmas turn on fine, then when I use the remote to start the engine only the driver side stays up, then I press unlock on the remote so that I can get into the car because the engine is running and then the passenger side goes out again, then finally when I turn the ignition off both turn on again. Has this ever happened to you or do you know someone that has experienced this issue before? Any idea what can be causing that particular light (passender fog) to go off and on? Thanks in advance for your advise Albertog |
More human than human
That does sound weird, I don't have any issues like that. I just have one that keeps going in and out.Sorry
![]() 1100 - 10/22/2008 3000 - 05/27/2009 3300 - 06/06/2009 3800 - 06/29/2009 4B00 - 06/29/2009 Warehouse 13 survivor Blood stains,speed kills,fast cars,cheap thrills,rich women,fine wine,i lost my sense i lost control i lost my mind. |
![]() Drives: 2010 6.2 H.O. SS/HP #002 Join Date: Jan 2010
I have one that goes on and off too...not sure what to do since I've had them for a while now.
Hey guys Happy Holidays!
Charwen4RS: I found out that the problem was a broken terminal from one of the jumpers (Harness). That's an easy fix just go to your local Radio Shak and buy a replacement of these jumpers they are very cheap I hope that solves yours too as well Albertog |
