Old 12-22-2011, 10:42 PM   #1
Super Sport 6.2
Drives: 2011 Wht w/org stripes 2 SS/RS L99
Clinking popping sound after 1" drop spring install
So I installed some eibach 1" springs and everything is good untill i go down quick little hill like a residential street that has a little steep drive way like hill on the way down i get a quick clincking/popping sound but not on the way up. I can go over speed bumps and no sound I looked at the springs and they are sitting good I did not time my bushing or do the alignment so I was wondering if that could be the problem. It seems to make the noise when the car is making a slow descent turning motion any info would be appreciated
Thanks
Rick
Vararam, V-max ported t-body, 1 7/8" kook headers with high flow cats, 2 1/2" X pipe, Magnaflow mufflers, Eibach 1" lowering springs, 20" Chrome American Racing Torq Thrust Wheels, Custom badges, SLP front splitter, NLP spoiler, oracle Led interior and fog lights, White with Orange Stripes 2011 2SS/RS L99
Super Sport 6.2 is offline   Reply With Quote
Old 12-22-2011, 11:06 PM   #2
JusticePete
JusticePete's Avatar
Drives: Camaro Justice
First thing you want to do is check your endlink nuts and make sure they are tight. They are some reports and photos posted that show the coil of an Eibach spring making contact with the outer edge, the edge closest to the wheel, of the lower spring perch. Re seating the coil butt end to the rubber in the seat may help. Others modified the perch by bending the lower spring perch edge just enough to clear the coil. You will also want to check the jam nut and strut retaining plate nuts. With the car's full weight on the wheels, remove the strut retaining plate nut and then the plate. If you have an air gun, burp the nut to make sure it is tight. Do the same with the strut retaining plate nut.
If these fail, it is time to pull the struts out and double check the assembly.
Old 12-22-2011, 11:16 PM   #3
Super Sport 6.2
Hey thanks Justice will do
Have a Merry Christmas
Rick
Old 12-22-2011, 11:29 PM   #4
Ject
aka Patrick
Ject's Avatar
Drives: '10 Camaro 2SS '04 Silverado
Send a message via Yahoo to Ject
Typically it is caused by something being loose so do as Pete said and also just double check any and everything you touched be it a bolt or a nut to make sure it is tight.
Current Modifications: Your average Bolt-ons & Suspension Upgrades
GForce Engineering: 9" Rear End, Strange Pro Iron Case w/Moser Nodular 3.70:1 Detroit locker, 3.5" Solid Drive Shaft
Ject is offline   Reply With Quote
Old 12-23-2011, 12:19 AM   #5
JusticePete
Rick
And a very Merry Christmas to you and yours.
Lowering springs question newagemuscle Suspension / Brakes / Chassis 17 02-11-2011 10:30 PM
Eibach vs. BMR KybheSS Suspension / Brakes / Chassis 24 01-13-2011 06:15 AM
My System install with fatmat sound deadening indigloflow Audio, Video, Bluetooth, Navigation, Radar, Electronics Forum 16 09-03-2010 03:08 AM
Help With Drop spring seddon Suspension / Brakes / Chassis 15 12-27-2009 03:03 PM
PEDDERS TAKING ORDERS FOR DROP COILS WITH OPTIONS! Info@PeddersUSA.com Suspension / Chassis / Brakes 25 08-03-2009 11:45 PM
