Old 12-23-2011, 09:48 AM   #1
scuba264
scuba264's Avatar
Drives: Manual 2011 CGM LS
Told by dealer that I MUST use synthetic oil?
So I got my inspection done today and got a phone call from the dealer telling me my oil change notification is on. I said I know and that I'd take care of it myself.
He told me to MAKE SURE I use synthetic oil and that its required and that if anything would ever happen to the engine and if they did an oil test and find it not synthetic I would be held responsible.
Now, at this point he wasn't trying to get a sale and was obviously aware that I was doing it myself. So it wasn't some scare tactic or anything so what gives? Did I miss this somewhere? I've seen enough threads about the benefits of synthetic and changing to it so is he just wrong? I've never checked the manual, I'll have to when I go pick her up.
scuba264 is offline   Reply With Quote
Old 12-23-2011, 09:59 AM   #2
UT-Engineer
Just Cruisin'
UT-Engineer's Avatar
Drives: 2010 Synergy Camaro
You're fine with a GM approved conventional oil. Only the L99/LS3 require synthetic. The V6s can use syn. and probably is recommended but not required.
2010 Synergy Green Camaro
25% Tint - CGM Painted GM GFX - 20" Niche M102 Wheels
UT-Engineer is offline   Reply With Quote
Old 12-23-2011, 10:16 AM   #3
pyledrivr
SW
pyledrivr's Avatar
Drives: 2011 Camaro Summit White
My dealer told me to use Mobile 1 syn. only....which was fine with me that is all I ever use in all my vehicles
2011 Summit White LS
pyledrivr@hotmail.com
pyledrivr is offline   Reply With Quote
Old 12-23-2011, 11:37 AM   #4
NavyDood
Retired Navy
Drives: 2010 2SS/RS
That would be a big negative and the dealer is only trying to get more money out of you since you have the V6.
NavyDood is offline   Reply With Quote
Old 12-23-2011, 11:39 AM   #5
PAUL SS
The Mark of Excellence
PAUL SS's Avatar
Drives: 2010 ABM 1SS RS LS3
or a lowlife.
Old 12-23-2011, 12:10 PM   #6
Kvapil28
Kvapil28's Avatar
Drives: 2012 Chevrolet Tahoe LTZ
Were they talking about Dexos oil???
Kvapil28 is offline   Reply With Quote
Old 12-23-2011, 12:11 PM   #7
Kvapil28
Kvapil28's Avatar
If your car is a 2011 is came with Dexos GM's part synthetic blend. 2011's and 2012's
Old 12-23-2011, 12:13 PM   #8
SC2150
The conventional oil in the LLT & LFX is what contributes to the timing chain stretch issues. That motor should NEVER have conventional or syn blend. ONLY full syn. Now, I'm just an engine builder and performance parts designer so what do I know.
Old 12-23-2011, 01:01 PM   #9
Marine2011
Drives: 2010 camaro
He probly thought you had a v8...
Marine2011 is offline   Reply With Quote
Old 12-23-2011, 01:16 PM   #10
The_Blur
Moderator
The_Blur's Avatar
It is possible that your dealer failed to properly understand what GM wants him to say. It is GM policy to encourage a synthetic blend now. It doesn't have to be full synthetic. The blend is better for engines than conventional oil. Of course, I would recommend Mobil 1, a full synthetic, for long life and performance.
warn 145:159 ban
Old 12-23-2011, 01:19 PM   #11
scuba264
scuba264's Avatar
I don't know what the deal was, he specifically said "you want to make sure you use synthetic, if you use regular crude oil and something happens and they test the oil it will be your engine then".
Like I said, he definitely wasn't trying to do the service at this point, just trying to be helpful. Either he thought it was an SS or is just incorrect.
Old 12-23-2011, 01:27 PM   #12
Brutal SS
Brutal SS's Avatar
Drives: 2019 Camaro 2SS 1LE
After learning the difference between conventional and synthetic, there is no way I will ever use anything but synthetic. Conventional is truly inferior and therefore obsolete. Settle for nothing less for your Camaro IMHO.
Brutal SS is offline   Reply With Quote
Old 12-23-2011, 01:29 PM   #13
usa1camaro1969
Back on the dino-juice
usa1camaro1969's Avatar
Drives: '10 LS + a few more
X2
Cadillac says only synthetic in their CTS with the LLT, but Chevy says it's okay to use conventional and put an oil life monitor that says it's okay to go forever on an oil change. Synthetic is not that much more expensive in the 5-qt jugs at Wal-mart, if you're doing it anyway, is it not worth the $10 or so difference for the peace of mind?
I wake up in the morning and I piss excellence.
-Ricky Bobby
America is all about speed. Hot, nasty, badass speed. -Eleanor Roosevelt, 1936
usa1camaro1969 is offline   Reply With Quote
Old 12-23-2011, 08:52 PM   #14
Marine2011
Drives: 2010 camaro
I would bet he thought it was the ss...
GAS PRICES GOING UP 5 CENTS IN GTA APRIL 2ND, 2011 SQUALO Canada 56 04-21-2011 03:19 PM
Great Read and Info on Oil Weight Banshee Mechanical Maintenance: Break-in / Oil & Fluids / Servicing 1 11-23-2009 09:03 PM
synthetic motor oil? bigd1276 Mechanical Maintenance: Break-in / Oil & Fluids / Servicing 71 01-29-2009 12:28 PM
Major U.S. oil source is tapped KILLER74Z28 Off-topic Discussions 32 10-30-2007 09:47 AM
