![]() Drives: 2011 Camaro SS/RS Join Date: Dec 2011
Anyone else have a rear backup sensor system randomly not engaging?
I have owned my Camaro for a bit longer than a year, and have had 3 or 4 occasions where the OEM rear backup system has failed to engage when I put the car in reverse.
Basically, when I put it in reverse that initial beep sound does not fire off to let you know the system is active, then it never beeps to let you know when you are close to something. I wrote it off the few times it happened as me putting it in and out of reverse too quick or something I did, but yesterday I didn't notice it wasn't active and counted on it. Unfortunately, I was backing up past a pillar in a parking garage and I knew it was really close to the car. When no sound ever came out I thought it was good...until I heard a scrape :( It barely made contact with the rear passenger-side quarter panel wheel flair and scratched it for about 10 inches. Has anyone else experienced throwing the car into reverse and the backup system not coming on? |
![]() Drives: 1979 Z28-Retired, 2012 RS Join Date: Oct 2011
Haven't had any problems yet. Sorry bout your damage!
![]() Drives: '11 SW/Beige 2SS RS Manual Join Date: Sep 2008
Yes, it's happened to me. When I didn't hear the initial beep, I took it out of reverse and put it back in and then got the initial beep.
YES, thank you Eich! That is exactly what I had done the few times I noticed it and it works once you take it out of gear and put it back in. Thank god someone else has actually experienced this (though it sucks there is a bug in our systems), it was so infrequent that I wasn't sure if it was just me
![]() Drives: 2010 2SSRS M6 Rally Yellow Join Date: Feb 2010
The only times it has happen to me, is when I put it in reverse and I'm actually in 6th gear. You only know this if you let the clutch out and go forward , otherwise you just think the sensors not working. If your actually backing up and it's not working, then yours is not working.
#6 | |
#7 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2SS/RS Join Date: Sep 2008
I've not noticed it with mine. What tranny are you got?
#8 |
![]() ![]() ![]() Drives: 2020 Summit White LT1 M6 Join Date: Sep 2011
I too had something similar happen I was pulling into my garage space and backing up to straighten out and thought I had more room because I never heard the beep and THUMP! right into the rear fender of my dads grand cherokee luckily it was slow enough so no damage occurred!
#9 |
![]() ![]() ![]() ![]() ![]() ![]() Drives: 2019 Camaro 2SS 1LE Join Date: Aug 2011
I had this happen only once, and I backed into my cousin's car as a result.
Hasn't happened before or since!
#10 | |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2010 Camaro 2LT/RS ABM Join Date: Sep 2009
No problems here either
1100 Order accepted at dealer: 9/15/2009 - NPGV41. 2000 Order accepted by GM: 9/29/2009 3000 Accepted By Production Control: 9/30/2009 - TPW 10/26/09 3100 Sequenced:10/12/09 3300 Scheduled For Production:10/13/09 3400 Broadcast:10/22/09 3800 Produced:10/27/09 4000 Available To Ship:10/28/09 4200 Shipped:10/29/09 5000 Delivered To The Dealer:11/09/09 6000 Delivered To Customer:11/12/09 |
#11 |
Don't Like it? Suggit.
Even active, you can't rely on the backup sensors. If the object is narrow, or not directly behind you, those little bastards will drop the ball. Mine went off AS I bumped into a narrow pole- a whopping 10 days new.
$2300 in damage. Don't count on the sensors, seriously.
"Tops off, tach up baby- loud and proud!" A Camaro lover from day one- 1996 3.8 V6 Camaro, to 1996 5.7 LT1 Camaro Z28, to the sold 2002 5.7 LS1 Camaro SS, and NOW, a [I]6.2 L99 VR 2SS/RS: XS Power stainless full exhaust, Airaid CAI, BMR drop springs and sways, custom tune by Cal Speed- 411rwhp |
#12 |
![]() ![]() ![]() ![]() ![]() Drives: 2010 Camaro 2SS/RS Join Date: Dec 2009
I noticed mine wasn't as reliable after I put the skip shift in. Go figure. It used to beep like crazy, now it seems to be less sesitive.
94 Firebird Formula (Drowned 08/30/05)
2010 IBM 2SS/RS 6M Arrived 3/25/10. ADM CAI, Borla Type S Cat Back, VMAX Ported TB, LG Short Throw Shifter, 1LE Shocks, Hotchkis Sway Bars, Whiteline Cradle Bushing Inserts, Custom Powdercoated ZL1's ,Michelin Pilot Supersports, Stainless Power Headers, Solo J Pipes, AAC LED Sidemarkers, ZL1 Rockers, SLP Splitter, ADM Stage II Cam,ZL1 Diffuser,Vitesse Throttle Controller. |
#13 | |
I tested the system with a buddy yesterday in a parking lot that had various features like poles and different sized curbs. I found out a few interesting things:
#14 | |
| Tags |
| backup, bug, malfunction |
| CAMARO WIKI | Tran | Wiki | 67 | 11-27-2024 09:02 AM |
| Poll -- Camaro vs Mustang Supercar Shootout | JusticePete | Suspension / Brakes / Chassis | 105 | 10-09-2013 03:18 PM |
| Rear window shattered randomly on freeway | ducq | 5th Gen Camaro SS LS LT General Discussions | 68 | 11-16-2011 09:30 AM |
| 2010 Camaro Backup sensors (rear park assist), confirmed * | CamaroScotty | 5th Gen Camaro SS LS LT General Discussions | 324 | 11-17-2009 05:05 PM |
| Zeta (Camaro/Commodore/G8) suspension details | Gatecrasher | Wheels and Tires Talk Sponsored by The Tire Rack | 66 | 04-16-2009 02:11 PM |
