Old 12-24-2011, 04:24 PM   #1
camaroitalia
Go Harder Than Baltimore!
camaroitalia's Avatar
Drives: 2010 CGM
Anyone know about REpainting a flat black car?
Looking at an older car to buy, the car was originally blue and apparently given a not so great flat black paint job... if i was to have the car re painted another color, would the process still be the same? you know like sanding etc?
Old 12-24-2011, 04:36 PM   #2
SnoopyAce7
(ʘ‿ʘ)
SnoopyAce7's Avatar
Drives: The one with a roof rack
if its not good then I'd want it redone. Probably sand, primer, primer, paint, paint, paint, clear.
SnoopyAce7 is offline   Reply With Quote
Old 12-24-2011, 04:50 PM   #3
camaroitalia
Drives: 2010 CGM
Ok thanks. So having flat black wouldnt screw up the process or cause some type of hidden cost?
Old 12-24-2011, 09:05 PM   #4
custompainter
Retired and diggin it!
custompainter's Avatar
Drives: 2011 camaro ss/rs
Depends on what it was painted with,and how well of a job was done. If its rattle can...run. If it was done by a shop and automotive paint was used then yea its pretty much the same process.
Tape test it. Take some green 3m masking tape (like 4" long) and pick a spot low on the car. Stick all but the last inch on the car and rub it on hard with your fingernails. Grab the loose end and yank it straight out real fast.Do this in several random spots. If the paint comes off with the tape,its most likely rattle can,but either way it will either have to be stripped off or sanded off beacuse the flat black is not adhered well enough,and will eventually peel,taking your new paint with it. Properly prepped,applied and cured paint will not come off with this test. And most automotive paints are not compatable with rattle can paint. Thus creating a host of issues.
If the guy selling the car refuses the test then walk away.
custompainter is offline   Reply With Quote
Old 12-24-2011, 09:15 PM   #5
2ndgenz28
Thread Killer
2ndgenz28's Avatar
Drives: All Black
Send a message via ICQ to 2ndgenz28 Send a message via AIM to 2ndgenz28 Send a message via Yahoo to 2ndgenz28
$20 for a gallon can of "aircraft stripper" from auto zone.
[name brand name, not type]
brush on, wait 3 sec, litterally, in 3 sec the paint will curl up and fall off down to bare steel.
done my FireBird that way, so so much easier and just cause the paint isn't goofy in a spot, allot of ugly can hide behind good looking paint. Rust grows like a plants root system and it will spider out with tiny tiny trails else where.
2ndgenz28 is offline   Reply With Quote
Old 12-24-2011, 10:07 PM   #6
Nessal
Drives: Exige, Miata, Ghia
Be careful with the air craft stripper. Wear gloves and do it OUTSIDE!
Nessal is offline   Reply With Quote
Old 12-25-2011, 12:36 AM   #7
2ndgenz28
Thread Killer
2ndgenz28's Avatar
Drives: All Black
burns like a mo-fo on your skin in mili-sec's but it works.
where other strippers you'll be at it all day.
Onstar....a spy???? please comment dieseldave24v General Automotive + Other Cars Discussion 138 02-23-2012 02:12 PM
Drying after a rain? KLow7777 Cosmetic Maintenance: Washing, Waxing, Detailing, Bodywork, Protection 7 02-17-2010 11:41 AM
Just for fun take a walk down memory lane Beandip2811 General Automotive + Other Cars Discussion 15 08-09-2009 10:26 AM
Taking care of a black car? 13F20 Cosmetic Maintenance: Washing, Waxing, Detailing, Bodywork, Protection 32 07-09-2009 11:23 PM
