Old 12-26-2011, 02:19 PM   #1
BenningJ
BenningJ's Avatar
Drives: 2013 AGM 1SS/RS LS3
Line out Converters
I got the 12" round Stealth sub enclosure this Christmas. I already have a sub and amp. Here is my problem, I don't want to change out the stock headunit. With the install kits and then getting a head unit it just costs too much right now. Also I still have OnStar and XM so I don't want to lose those. I have a 1LT so I don't have the BA system.
My question is what product would you recommend so that I can get a signal for my subs?
I have seen a lot of different LOCs but I'm not sure which one to go with. I was/am leaning towards the PAC AA-GM44 but I don't know if I want to use that one as LOC from the rear speakers or just use the T-harness. Any information or suggestions you could give me would be helpful. Does the Pac Audio AA-GM44 have a built-in remote amp turn-on wire?
Thanks in advance.
2013 Camaro 1SS/RS - Ashen Gray Metallic
| LS3 | CAI Inductions, Inc Intake | Vmax Ported Throttle Body | Dynatech 1.875" Long Tube Headers | Apex Scoop & Washer Bottle Relocation | Lethal Racing Night Fury Cam | BTR 7.400" Push Rods |LS2 Dampener | Melling 10296 Oil Pump | IWIS Chain | BTR .660" Dual Valve Springs | BTR Trunion Upgrade Kit | Lethal Racing Tuned | Anvil Notch Spoiler | BMR Split Drop Springs | Eaton TrueTrac | GM 3.91 Gears | LPW Diff Cover | Rohana RF2 275/40 20x10F 315/35 20x11R | BMR Polyurethane Motor Mounts
BenningJ is offline   Reply With Quote
Old 12-26-2011, 03:13 PM   #2
justa25thTA
justa25thTA's Avatar
Drives: 2011 Camaro SS/RS LS3
You have the BA sound system? If so use the ******** harness.
Yeah, I'll get around to it...
justa25thTA is offline   Reply With Quote
Old 12-26-2011, 05:09 PM   #3
BenningJ
BenningJ's Avatar
Yeah, I do not have the BA system otherwise I would have already ordered the ******** harness. I have been hearing great things about that harness.
Old 12-26-2011, 06:49 PM   #4
CamaroKid300
ace5.org
CamaroKid300's Avatar
Drives: 2017 ZL1 M6
I thought BA system came with RS models? Or is that 2LT and 2SS models?
Stock...For Now.
CamaroKid300 is offline   Reply With Quote
Old 12-26-2011, 07:01 PM   #5
BenningJ
BenningJ's Avatar
2LT and 2SS models only. After doing some research and sending some PMs I think I will either go with the PAC SNI-15, SOEM-4, or the SOEM-T. Just have to make up my mind. If anyone has some tips for using any of these products please let me know.
Old 12-27-2011, 07:07 AM   #6
booger78z28
booger78z28's Avatar
Drives: Waiting on my Hyper '16
and what will this do to the stock radio and amp hookup?,..which im doing also on a non-BA car..
1978z28 Original paint 355 solid roller 4 speed
2016 Hyper Blue 1LT RS package with all the goodies
Sold 6/20
12/10/21 bought a Silver Ice 2SS 6 speed with 40k
booger78z28 is offline   Reply With Quote
Old 12-27-2011, 11:52 AM   #7
Shu71
Drives: 2011 Camaro RS M6
Just to clear something up. You can get a 1LT and 1SS with premium sound option and therefore have the Boston sound and amp from the factory. For those of us with this setup the easiest way to replace the factory amp or add an amp or two for subs is with the ******** harness(s).
BenningJ, I would think the easiest way to wire up your new sub and amp would be to pull the signal from the rear deck speakers. Just splice into those lines for the signal input. That would allow all the wiring for the new amp to stay in the trunk and you wouldn't have to run any wires through the car.
Shu71 is offline   Reply With Quote
Old 12-27-2011, 12:54 PM   #8
Blacktip
Blacktip's Avatar
Drives: 2011 1LT Silver RS package
that's what i am trying to do , i am at the point to splice but need help on identifying the wires going in the speaker plug? which ones are positive and negative???
.....Well alright,alright..didn't know it was this kind of party
Blacktip is offline   Reply With Quote
Old 12-27-2011, 01:00 PM   #9
Shu71
Blacktip, I think there is a wiring diagram in this section that should answer your question. Also you will need an ignition power on 12v signal which a lot of guys have been using the 12v from the cigaratte lighter in the back of the console. I think there is another one in the fuse panel behind the passenger side carpet in the trunk though.
Old 12-27-2011, 01:02 PM   #10
Shu71
Yep, The wiring diagrams are a sticky :
http://www.camaro5.com/forums/showthread.php?t=33592
Old 12-27-2011, 02:10 PM   #11
BenningJ
BenningJ's Avatar
Yup, I'm going with the PAC SOEM-T LOC. It has a built-in remote amp turn on. It detects when there is a signal to the rear speakers and then turns the amp on. This will keep that annoying sub pop out of the picture.
Blacktip, I posted a DIY on the LOC install on your thread. I hope it helps. If you read through the text and look at the pictures it will be quite clear.
Old 03-12-2012, 08:01 PM   #12
ecko04
Drives: Too many to list
Here's another question, how would you go about adding a 4 channel and retaining OnStar, door chimes and all those goodies? Would the AA-GM44 work? I'm not concerned about running wires through the car, that's the fun part.
ecko04 is offline   Reply With Quote
Old 03-12-2012, 10:30 PM   #13
Jason@JacFab
Drives: 2016 1LT RS Camaro; 72 Chevelle
Send a message via AIM to Jason@JacFab Send a message via MSN to Jason@JacFab
PAC SOEM-T
Jason@JacFab is offline   Reply With Quote
amp install, line out converter, loc, pac aa-gm44, sub install non ba
Heet fuel line antifreeze. Part #28201 69 Rebel Canada 1 08-21-2010 08:45 PM
New Product line from Unrestricted Motorsports!! Unrestricted Exterior Parts & Accessories 47 01-18-2010 03:31 AM
2010 Camaro Line Lock ( linelock) completed! SJM Wheels and Tires Talk Sponsored by The Tire Rack 15 12-27-2009 08:45 PM
Camaro line down first week of jan 80Zedder 5th Gen Camaro SS LS LT General Discussions 1 10-22-2009 02:08 PM
# of Cars on Line...? carguy 5th Gen Camaro SS LS LT General Discussions 6 06-09-2009 12:32 PM
