Old 12-26-2011, 04:03 PM   #1
QuiksilverHg
QuiksilverHg's Avatar
Drives: 2SS, RS Package, Imperial Blue
Stuck Clutch?
So I've been working on getting better starts off the line with my 2011 2SS convertible. Normally I rev up to like 2500-3000 RPMs then slowly let out the clutch, but I know I can get better starts if I revved it up even more. Been waiting to try it out and decided to today.
So today I was at a stoplight coming back from Christmas and decided that was the time to give it a try. I revved the engine up to about 4000 RPMs and was going to ride the clutch to keep traction as I came off the line. When the light turned green I started letting off the clutch at what I thought was the appropriate speed, but for all the noise I was hardly moving. I let the clutch out a little more, and still felt like I was stuck in molasses, finally I completely took my foot off the clutch and I still was hardly moving.
I put my foot back down on the clutch, and realized it had hardly moved from where it normally first begins to engage...at this point I started worrying that something was seriously wrong (not helped by the cloud of smoke I could see in my mirror, and the pungent odor of burning clutch in my nose). I pushed in the clutch and tried to let it out again and it still didn't seem like it was tracking with my foot, or like it was fully engaging.
I forget exactly what I did at this point, it all happened within a few seconds, but I think I either shifted to 2nd, or let off the gas and tried letting out the clutch again. Either way it worked fine after that point, but I was reluctant to give it a full power start off the line for awhile.
So I'm not sure exactly what happened and am trying to figure it out. Do I have a weak clutch-spring? Is there some kind of feature in traction-control that keeps you from letting out the clutch too fast? I had not disengaged traction control or gone into competitive mode, as they've never had any negative effects on me so far. Or is there some phenomenon that normally occurs with aggressive starts that would keep the clutch from engaging all the way?
Also, what should I do now? Should I have the dealer check if I have a weak clutch-spring or have them check something else?
Should I try again to make sure I wasn't just imagining it? (pretty sure I wasn't)
Any ideas? Thanks for the help
QuiksilverHg is offline   Reply With Quote
Old 12-26-2011, 06:08 PM   #2
Weezerj
Weezerj's Avatar
Drives: 2012 Camaro 2SS -- 02 Escalade
I found this read (from this site) very informative.
http://www.camaro5.com/forums/showth...t=stuck+clutch
Weezerj is offline   Reply With Quote
Old 12-26-2011, 06:13 PM   #3
QuiksilverHg
Ugh, looks like I will need to inspect and possibly replace my clutch fluid.
Good site for info on clutch issues:
http://www.rangeracceleration.com/Clutch_Care.html
Old 12-26-2011, 06:23 PM   #4
QuiksilverHg
Wait a minute, if the clutch fluid needs replacing already, shouldn't this be covered under warranty? I bought my car Aprilish and have about 8300 miles on it. No reason I should have to change the clutch fluid already.
Old 12-26-2011, 07:47 PM   #5
MileMAN402
RIP JoePa
MileMAN402's Avatar
Drives: 2010 2SS/RS & 2001 Audi S4
I cycle new fluid in mine like you found on Rangers site with every oil change at least. I'll be putting the separate reservoir on as soon as it arrives
MileMAN402 is offline   Reply With Quote
I want a new clutch, you too????? Sign here tjbusa V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6) 370 08-10-2013 04:27 AM
The 2011+ Mustang Thread GatorBlue371 General Automotive + Other Cars Discussion 11874 08-23-2011 01:30 PM
Anyones clutch get stuck w/o launch ctrl? KB2010 V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6) 10 09-20-2010 07:15 AM
Stuck Clutch Warranty Work CBH V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6) 1 02-20-2010 01:23 PM
Clutch "Sticking" Issue - Not Clutch Dust - Not Boiling Fluid Embalmer Camaro Issues / Problems | Warranty Discussions | TSB and Recalls 1 09-11-2009 10:52 AM
