Old 12-27-2011, 08:02 PM   #1
gisuho_g8
Drives: Pontiac G8 or Corvette
2010 SS rear cradle connection measurement
Can anyone give me the measurements to the cradle connections points?
I am looking at possibly utilizing a whole camaro ss rear cradle in my 2009 G8 and need to know the measurements between the connection points to see if it is the same or will i need to make modifications or do i just use the parts.
This is what i know
1. the rear diff will swap in
2. the knuckles will swap in, i believe i have to swap out one of the control arms.
3. i have to utilize the camaro axles.
4. I will need to utilize the rear brembo brakes and rotors, one of the reasons for the swap out.
But if could utilize the whole cradle, then it is easier to remember what parts are from what cars.
Any assistance would be appreciated.
gisuho_g8 is offline   Reply With Quote
Old 12-27-2011, 11:56 PM   #2
gisuho_g8
bump. anyone???
Old 12-28-2011, 12:31 AM   #3
gisuho_g8
bump
Old 12-28-2011, 01:15 AM   #4
RED DEMON SS
OFF THE CHAIN
RED DEMON SS's Avatar
Drives: PSHHH UWISH
That is a tough question, maybe a sponsor with more knowledge could chime in tomorrow when they get back onto the board?
Old 12-28-2011, 10:34 AM   #5
gisuho_g8
thank you Farthestnorth
bump anyone?
Old 12-28-2011, 10:37 AM   #6
Drew10
Enjoys a good train wreck
Drew10's Avatar
Drives: 2010 IBM Camaro 2SS/RS
I am trying to find it in the wiki section. I will see what I can come up with.
Drew10 is offline   Reply With Quote
Old 12-28-2011, 12:11 PM   #7
gisuho_g8
thank you Drew
Old 12-29-2011, 06:38 PM   #8
gisuho_g8
anyone?
Old 12-31-2011, 08:14 PM   #9
gisuho_g8
bump - happy new year to all
Old 01-02-2012, 11:25 AM   #10
gisuho_g8
bump
Old 01-02-2012, 12:12 PM   #11
ShnOmac
OP you would probably be better off posting this in the Suspension section...
http://www.camaro5.com/forums/forumdisplay.php?f=93
Lots of vendors with first hand knowledge hang out in there!
ShnOmac is offline   Reply With Quote
Old 01-02-2012, 07:40 PM   #12
tadams72
When is enough ever...
tadams72's Avatar
Drives: 2006 Silverado 2500HD CC/SB LBZ
Location: Residence: Chula Vista, CA Home: Billings, MT
I just laid under mine and eyeballed it with a tape measure so there is goign to be a slight variance from these but if they are way off then you will know right away. Hope it helps.
Measured Center Bolt to Center Bolt
Cradle Back Mounts: ~41.5"
Cradle Front Mounts: ~40.25"
Front to Back: ~24.5"
Depth Change: ~8" higher at the back mount than the front
The Project: 2011 Camaro 2SS/RS (ERL 427 Superdeck NA Monster)
"Just like farmer engineering. Find the weak link and fix it, then find the next one." Salt Cat Racing
tadams72 is offline   Reply With Quote
cradle, diff, rear
Thinking About Swappin' Gears? Here are the numbers! Apex Motorsports V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6) 32 04-24-2017 03:12 AM
2010 SS Stock Front and Rear Shocks for sale SikMaro Suspension / Chassis / Brakes 0 08-12-2011 12:24 AM
2010 SS rear spolier 35th02ss Exterior Parts & Accessories 8 03-09-2011 10:47 AM
Magnaflow 2010 Camaro SS Systems JDP Motorsports V8 Bolt-Ons & Tunes 61 12-12-2009 01:13 PM
