Banned
Battery / Alternator / Starter?
i believe im having problems with one of these. and i was wondering..wth they are under warranty after 36k? how much could one of these cost? because the car takes a little to start up a few whines..
Drives: 2010 CGM Camaro 2SS/RS 429 LSX/F1X Join Date: Aug 2011
What exactly is it doing? Does it crank for a while before it starts? Probably not one of those if thats the case.
Chances are those items are not covered under warranty after 36k, but depending on the dealer, they may help you out. If you determine it is an electrical issue with one of those, you can take it to the dealer for diag (probably around $100), and they can give you a quote. - Jeremy
Banned
well what happens is that i put the key in the ignition and then i crack her and she cranks whop whop whop and then turns on.
Banned
bumpy for helpy
My car runs on acorns....
Drives: 2010 SS RS Inferno Orange Join Date: Feb 2010
So it's turning over but takes a few revolutions for the car to start? Probably not electrical in nature.
My car runs on acorns, the tears of ricers and these other slightly less important things...
2.9 Polished Whipple, Kooks LT 1 7/8 headers, HiFlow Cats, Kooks Sleeper catback, Cooling Mist Methanol Injection, PFADT Sport Sways, PFADT Springs, PFADT rear trailing arms, ADM intake, JDP stainless brake lines, Jegs Catch can, Stock SS wheels widened to 10 3/4, Hawks HPS Pads, Pedders Rear Subframe Bushing Inserts, BMR Center Brace, MSD BAP, AAC side markers, Emblem Pro's Custom Lighted Door Sills, Dash-Floor-Cupholder ABL lighting and other stuff.... |
#6 |
Plugs/fuel.
#7 |
Banned
you think? how much do plugs run for? warranty?
#8 |
Could be, pull em and take a look. I pay about 10 a peice for mine. Could still be a ton of other things though. Wouldn't be covered under warranty. If there's a problem with your fuel it could be though.
#9 |
![]() Drives: 2011 2LT RS Join Date: Apr 2010
Are they slow revolutions that pick up just prior to starting? If so, with the onset of cold weather I wouldn't be surprised if it weren't your battery getting weak.
#10 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: GM Vehicles Join Date: Jun 2010
The only thing that wouldn't be covered under some sort of warranty would be the spark plugs. Those are a maintenance item and would have to be taken care of by the customer but the battery and the starter should be covered under the 3 year 36,000 mile warranty or the 5 year 100,000 mile warranty respectively. I hope it's not a serious issue for you panda. Let us know if you take the vehicle in or figure this one out on your own.
Jeff Morris, Chevrolet Customer Service |
#11 |
Banned
ill have to wait to i get back to miami. when i get back im getting a battery and alternator test done and ill check the plugs. before i took my car in it was low on fuel..really low...realllllly low but when i got out i filled her up with 93 so i doubt fuel would be the issue. Shell 93 too!
#12 |
Banned
#13 |
![]() Drives: 2010 2SS rally yellow Join Date: Dec 2011
check the battery, do not sart the car before you do it. At the same time check the cables coming off the battery. Clean as nessessary. If all that is good, then go to starter, check for corosion on cable ends, replace as needed. If end are good then you can replace the starter. have fun
#14 |
Banned
Well I doubt its the battery because the fact that the battery voltage without being started is 11.0-12.0 and when the car is on and running its 13-15. But I will check the battery. Cables and such.
| CTEK Battery Chargers | southerncarparts | Miscellaneous Items | 28 | 10-27-2019 12:25 PM |
| CTEK US3300 $69.99 - Free Shipping and Free Cig Lighter Adapter! | Double D Mods | Audio / Visual / Electronics/ Gauges / Nav | 6 | 06-06-2012 07:29 AM |
| CTEK Multi US 3300 Battery charger available at www.gmpartshouse.com | patrickt | Audio / Visual / Electronics/ Gauges / Nav | 15 | 03-02-2012 03:20 AM |
| Smartest Battery Charger in the World!!! | southerncarparts | Audio / Visual / Electronics/ Gauges / Nav | 0 | 12-04-2009 08:35 AM |
| GM To Build Battery Plant | Mr. Wyndham | General Automotive + Other Cars Discussion | 5 | 01-13-2009 02:03 PM |
