Old 12-28-2011, 10:09 PM   #1
siriusdish
Drives: 2010 Camaro L99
Oil temp?
What should the oil temp be running on a L99? My Dad thinks it's running high now after cam swap. Also is their a Stock Oil cooler? Thanx.
2010 L99
vararam intake, Vmax TB,Vmax Intake,TSP VVT 3 Cam,TSP underdrive pulley,Yank 3600,TM Cooler,ARH 2", High Flow cats, X-pipe, GM Pro mufflers, RX Catch Can,160 stat, BMR Trailing,toe,Cradle insert, Diff. Bushings, End links, Spohn-LCA's (Touring)Wheel spacer's. 422 rwhp Mustang Dyno http://www.youtube.com/watch?v=AaFNAhCL7Os
siriusdish is offline   Reply With Quote
Old 12-29-2011, 05:20 AM   #2
Scott@Bjorn3D
225-250 max on mine on a really hot day.
Scott@Bjorn3D is offline   Reply With Quote
Old 12-29-2011, 11:17 AM   #3
siriusdish
Thanx for the reply!
2010 L99
Old 12-29-2011, 11:30 AM   #4
SC2150
Oil temp needs to be above 210 to "flash-off" the harmful contaminates that are volatile so the PCV system can evac them to prevent engine damage. The max is what BJorn stated to be safe. At that high of temp though conventional oil will begin to break down so full syn is a must.
Old 12-29-2011, 11:39 AM   #5
siriusdish
Is the line before 300 250? This is just sitting in the driveway w/o driving.
2010 L99
Old 12-29-2011, 12:02 PM   #6
Scott@Bjorn3D
Thats fine, that is where mine site most the time drving.
Old 07-24-2013, 09:47 AM   #7
Unobtainium
Fabricator
Unobtainium's Avatar
Drives: 2011 2SS Summit White
Bringing this back as I have had the oil get pretty hot recently on long WOT runs. Looked into the temps for good synthetics and it seems 300F is not an issue. It hasn't gotten that hot, but over 250F for sure.
Going to do a change and see. Might need a bigger cooler, but it doesn't get very hot here.
Not going to stop driving the way I like, so a solution must ba available.
A hot day here is 90F or less.
Roto-fab CAI
Unobtainium Welding Exhaust
ARH LT's
393whp L99
GPI VVT Turbo Cam-in
Unobtainium is offline   Reply With Quote
Old 07-24-2013, 10:11 AM   #8
BullF-16
USAF retired! Thank God!
BullF-16's Avatar
Drives: 2011 1SS, 1LT red,1LT/RS SGM 98Z28
Are you saying that 300F is not an issue with good synthetic oil? I am running Amsoil Dominator 15w50 race oil with lots of phosphorous and zinc and installed an aftermarket Earls 16 row, wide oil cooler and my temps in town with ambient temps above 105 are only 225 at max.
When i take it out on the back roads for spirited driving it goes up to 240F. At highway speeds it runs about 210. I am however worried about temps on the road course and thought that 300 deg was not good for the oil at those temps. What has your research led you to conclude?
I am hoping that when i take it to the 2.5 mile road course that i can keep the temps below 270 for the first 3-5 laps, then back off if i approach 300F. I am far from stock though?
HKE LSX427(Mast blk lbl 305 6bolt LS7heads, PatG231/246 blower cam, RWHP/TQ: 1281/1133 SNL Performance Custom Twin PT6766 BB turbos 4 to 25psi selectable on the Boost Leash controller, Squash dual 400LPH/ID2000s, ALKY 4 gal meth, Autometer AFR/Bst/oilpres/oiltemp/fuelpress gauges, Pedders Justice road crs pkg: All HD bushes, supercar 12kg coil overs, supercar ZL1 sways, camber plates all setup by JusticePete! :Gforce 9" 35spline S-Trac, 1500hp Outlaw axles, 3.5"alum DS, Monster Triple disc; 4xForgeline 19x10.5 4xBridgestone 305/30R19 RE-11, CTS-v calipers/rotors/Cobalt friction XR1/3 pads
BullF-16 is offline   Reply With Quote
Old 07-24-2013, 11:06 AM   #9
Unobtainium
Fabricator
I'm not sure taking it there often is good, but it seems that the wear protection isn't much worse than at 270F.
Mine will get 250-260, then I have to let off and cruise for a while, cools to 230-210. It takes about 7-8 miles to get hot, and only in the summer months. I'm very close to stock, worried about my turbo set-up if this combo gets hot. So much oil in these cars I didn't think it would be an issue over short-medium blasts. There will be much more heat in an FI set-up, so I guess I had better start digging in. Didn't move out to the country to not enjoy the empty roads...
Roto-fab CAI
ARH LT's
393whp L99
Old 07-25-2013, 05:29 PM   #10
SPCBA
Drives: pleather and Chiclets
the guage in the camaro that comes stock is a estimation not a true figure
SPCBA is offline   Reply With Quote
Old 07-26-2013, 02:11 PM   #11
BullF-16
BullF-16's Avatar
Im running custom full sweep oil pressure and oil temp gauges and have the temp sensor positioned on the line coming off the oil cooler. Not oem. My oil cooler is also a custom 16 row Earls performance wide cooler.
Old 01-02-2021, 02:27 AM   #12
Aldokhi
Drives: camaro 2010
I need help oil temp for camaro 2010 SS
Recently, I noticed an increase in the temperature of engine oil, as it appears in the picture, and it increases at long distances Is this normal ..? If not, what should I do to fix the problem
The radiator is new and the fan is running normally
I need help
Aldokhi is offline   Reply With Quote
DIY: Camaro Oil Change adub4185 Camaro DIY & HOW-TO instructions & discussions 180 04-23-2014 06:11 PM
Should I trust my oil life computer? 2011CamaroRS/SS Mechanical Maintenance: Break-in / Oil & Fluids / Servicing 39 11-15-2011 10:10 PM
synthetic motor oil? bigd1276 Mechanical Maintenance: Break-in / Oil & Fluids / Servicing 71 01-29-2009 12:28 PM
Major U.S. oil source is tapped KILLER74Z28 Off-topic Discussions 32 10-30-2007 09:47 AM
