Old 12-29-2011, 08:45 PM   #1
emsguy
Drives: 2012 2ss convertible
Must Tune?
happy new year everyone.
I have a 2012 2SS A6 convertible. I am putting on JBA shortie headers, JBA high flow catted midpipes, a Corsa cat back exhaust, and Volant intake.
I know that a tune will give me more power, but that it may also invalidate the powertrain warranty.
so - - - here's the question: what if I put on all of these mods and don't tune? I know I won't get as much power, but will the new mods without a tune screw things up?
as always, all opinions are welcomed but informed, experienced opinions are preferred.
emsguy is offline   Reply With Quote
Old 12-29-2011, 08:47 PM   #2
SUX2BU
Quit being a pu$$y
SUX2BU's Avatar
Drives: FAST
No.
SUX2BU is offline   Reply With Quote
Old 12-29-2011, 08:49 PM   #3
lakersftbl69
lakersftbl69's Avatar
Drives: 2010 camaro ss
You will need a tune in order for the engine light to not come on
ordered dec 15 2008 picked up on june 8 2009.
upgrades kooks 1 7/8" LTH w/ deleted cats, corsa exhaust, hurst short throw shifter stage 3 comp cam, 3.91 gears ecs kit blower, meth injection, upgraded axles, drive shaft, McLeod rxt clutch, fully forged 416ci stroker all installed and dyno tuned by slowhawk performance in bridgewater ma.
lakersftbl69 is offline   Reply With Quote
Old 12-30-2011, 07:39 AM   #4
Steck
Drives: 2006 twin turbo Corvette Z06
Putting those parts on voids your warranty anyway.
If you don't tune it, and your MAF calibration is off, the transmission will eat itself. It may happen slow, and it may happen quick. The MAF is used for torque reporting, and if the torque values are inaccurate, the TCM uses the wrong shift properties which can result in a burned up transmission. Manual trans guys don't really have a concern... It just won't run at full potential.
Steck is offline   Reply With Quote
Old 12-30-2011, 10:50 AM   #5
Cpanthers85
Drives: 2011 Camaro 2SS RS
You will throw a check engine light because of the headers and the high flow cats. It's going to throw the O2 sensors off.
Besides, if a dealer sees your headers, unless they are "cool", they are going to void the warranty.
Even if you put the car back to stock before you take it to the dealer, they will still be able to see in the ECU history that you were running with a CEL and very lean. They will put 2+2 together...
2011 2SS/RS L99
2017 Chevy SS
1979 Z28
Mods: Kooks Long Tube Headers, RotoFaB EForce CAI, American Thunder Catback Exhaust, PFADT Stage 1 Drag Kit + Front Sway Bar, GM Strut Tower Bar. ZL1 Fuel Pump. Nitto NT05R. RX Catch Can.LS9 Cam and Springs.LS3 Conversion.JRE Fuel Rail Upgrade.Edelbrock Eforce.60# Eforce Injectors.Extreme Racing Tune. 523/495
MY BUILD THREAD
Cpanthers85 is offline   Reply With Quote
Old 12-30-2011, 08:56 PM   #6
emsguy
thank you all
thank you all for your informed and informative responses. I have read them all, and have tried to understand.
I was reminded by your responses that I am a somewhat of a dinosaur. I got my first drivers' license in 1966. That's right. I have been driving for 45 years. My first car was a '65 Buick Skylark GS convertible with a two-speed automatic transmission. I think it was a power glide. I can remember buying Sunoco 260 for 32.9 cents per gallon. I was educated on cars with manual chokes. I can, and have, synched three SU carbs on a 4.2 E-Type DOHC straight six. Rebuilt a TR-6 frame-up. I understand, and have experienced, the smoke theory of Lucas electrical systems. I understand, and appreciate, mechanical systems. Electrons, however, baffle the heck out of me.
You say that the AT of my 2SS senses the torque the engine is putting out and shifts accordingly. I believe you, but I don't understand. If the transmission truly senses the torque output of the engine directly, then it shouldn't matter whether I add headers, midpipes, and aftermarket exhaust. Any change in the engine torque caused by these mods would be sensed by the transmission and it would adjust accordingly. After all, 300 ft/lbs of torque is 300 ft/lbs of torque regardless of which header is used to produce it, or at what rpm it is produced.
However, if the transmission interpolates the torque figure from a pre-programmed map of stock engine values (at 3,000 rpm, the engine is putting out X ft/lbs of torque and at 3,500 rpm it is putting out Y ft/lbs of torque), then changing the headers, etc. would confuse the transmission. It would be looking for X ft/lbs of torque at 3,000 rpm and the engine was in fact putting out Z ft/lbs of torque.
Have I got it?
Once again, I am not questioning your superior wisdom and experience on this point, just trying to understand it.
Thanks again.
Old 12-30-2011, 09:42 PM   #7
Steck
That's pretty close. The headers won't impact it much. The PCM takes the airflow that it is seeing and says "based on this much air flow and this engine speed and this spark, the engine is making X torque". The reason the MAF calibration is very important is it is the basis of the torque calculation.
Old 12-30-2011, 10:27 PM   #8
ParisTNDude
Owning SSes for 50 Years
ParisTNDude's Avatar
Drives: Sharkskin Grey LT1
I think you would want one, but the shorty headers won't cause you to throw a code from what I've heard on this forum. I understand lot's of C5 members went the shorty header route instead of the long tubes just to avoid the need for a tune! Long tubes locate the oxygen sensor probably a foot or more further from the exhaust ports and apparently they run cooler there and aren't calibrated for the cooler temperature. My Camaro didn't throw a code when I installed my long tubes and I was surprised.
The new ride: 2023 Camaro, LT1, Sharkskin Grey
Previous Performance Cars:
1966 Chevelle SS 4M, 2010 Corvette 6M
1968 Dodge Charger R/T Auto 2012 1SS 6M
1982 Corvette Auto 2010 1SS 6A
1984 Corvette Auto 2016 2SS 8A
1999 Camaro Auto 2017 HBM 1SS 1le
2002 C5 Corvette 6M 2018 2SS
2006 Corvette Auto 2023 Camaro LT1
ParisTNDude is offline   Reply With Quote
Old 12-30-2011, 10:57 PM   #9
emsguy
thanks. good information.
how far is your shop from Chicago? from Peoria?
Old 12-30-2011, 11:06 PM   #10
Rhino79
Rhino79's Avatar
Drives: 2010 Camaro SS L99/Auto
The o2 codes come from lack of a catalyst or a high flow catalyst. The secondary o2s are the ones that throw the codes. A lot of long tubes delete the cats as mine did and obviously the codes for the rear o2s have to be disabled to prevent a cel.
Rhino79 is offline   Reply With Quote
Old 12-31-2011, 03:05 AM   #11
Steck
About 200 miles from Peoria.
While true, some headers also result in slow switching of the front O2 sensors.
Old 12-31-2011, 02:52 PM   #12
emsguy
how long does a tune take for you to do? I am truing to figure out if I can drive down from Peoria, have you do the tune, and drive back in a day.
thanks
Official 1/4 Mile (V8) 2010+ Camaro Fast List Merc Dragstrip and Launch Techniques Discussion 3656 11-01-2025 01:41 PM
MarylandSpeed DYNO TESTED: Diablosport Predator Canned Tune on 2010 SS A6 MarylandSpeed Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 27 05-18-2013 10:01 PM
Camaro SCT tune Vs HP TUNERS tune by Tampa Tuning Tampa Tuning Tuning / Diagnostics -- engine and transmission 21 02-08-2012 07:06 AM
Manual vs Auto GTAHVIT vs PQ... The video wars. 76z28 5th Gen Camaro SS LS LT General Discussions 443 08-26-2010 12:26 PM
Lets play a game 2SSRS@Gen5diy Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 56 09-26-2009 09:08 AM
