Old 12-31-2011, 09:40 AM   #1
Ratt
Drives: 2ss
3.73 vs 3.91 gears in an SS A6
Is anyone running the new 3.91 gears with an SS A6? If so how do you like it?
What would be better for an SS A6, 3.73 or 3.91 for someone who drives every day?
Ratt is offline   Reply With Quote
Old 12-31-2011, 06:55 PM   #2
Ratt
Drives: 2ss
This post is going well, I take it nobody with a A6 is running with 3.91 gears?
Old 01-03-2012, 08:21 AM   #3
Slickcas
Drives: 12' 2SS/RS LS3 IBM
I do not have the A6 but with its low 1st gear 3.91s would be over kill i bet you will smoke the tires every time you try and play. 3.73s are about perfect unless you have a lot of mods.
Slickcas is offline   Reply With Quote
Old 04-01-2012, 03:21 PM   #4
mike.nite
mike.nite's Avatar
Drives: 2011 2SS L99, 2010 LT RS
I'm interested in this as well. Any other feedback?
mike.nite is offline   Reply With Quote
Old 04-01-2012, 03:41 PM   #5
grocerygetter
instigator
grocerygetter's Avatar
Drives: 2020 6.2 Trail Boss, 2022 XC90
i love my 3.70s...with a blower, you won't want any more gear than that.
-John S.
Old 04-01-2012, 03:47 PM   #6
lexlueger
lexlueger's Avatar
Drives: V10 BMW M5, Supercharged 2SS/RS
3.70/3.73 are all you need. Just don't buy any richmond gears.
MAST 416 STROKER: STAGE 3 TVS 2300
CUSTOM CAM
TPIS 102 TB
IW 8 RIB PULLEY W/ OD COG REARS
NX EXPRESS/NANO KIT
KDI HEAT EXCHANGER/ROTOFAB RESERVOIR
CIRCLE D 2800 TC/FLEX PLATE/ADM TRANS COOLER
DSS DRIVESHAFT/1400 HP AXLES
EATON TRUETRAC -LPE 3.27 GEARS
DYNATECH HEADERS/MAGNAFLOW EXHAUST
SQUASH RETURN STYLE FS ID 850's E85/ FLEXFUEL
BMR/EIBACH SUSPENSION
KILL MODE, ON.
lexlueger is offline   Reply With Quote
Old 04-01-2012, 04:15 PM   #7
mike.nite
mike.nite's Avatar
I'd prefer LPE gears. I do have a automatic trans.
I got you on the FI setups. But since I just have bolt ons and a very mild cam I'm not shure if I could also go for the 3.91 gears.
Old 04-01-2012, 04:17 PM   #8
Kyle2k
LVL 50 Troll Stomper
Kyle2k's Avatar
Drives: 2010 Camaro
If you aren't planning on drag racing and trying to match the right gear for your trap speed then go with whatever.
Kyle2k is offline   Reply With Quote
Old 04-01-2012, 04:37 PM   #9
mike.nite
mike.nite's Avatar
Yes I wont drag race. But a lot of city/stop&go and some highway traveling. I'm just not shure with thte 3.91 because a friend told me that this is just to crazy for the A6 and even bone stock you'll have traction problems with a 3.91 - is that true?
Old 04-01-2012, 04:41 PM   #10
lexlueger
lexlueger's Avatar
3.91 in a mild street car is overkill IMHO. I have LPE 3.70's.
CUSTOM CAM
TPIS 102 TB
NX EXPRESS/NANO KIT
KILL MODE, ON.
Old 04-01-2012, 07:47 PM   #11
grocerygetter
instigator
3.70s. Lpe/aam
-John S.
Old 04-02-2012, 02:07 PM   #12
mike.nite
mike.nite's Avatar
thank you verry much for the feedback guys
can someone explain to me why the 3.91 in a street car is a overkill?
What are the downsides?
thanks
Old 04-02-2012, 05:39 PM   #13
Fiftydriver
Fiftydriver's Avatar
Drives: 2010 Camaro 2SSRS RJT L99
I have LPE 3.91 in my 2010 A6 with a Maggie on top. Its alot of gear for a supercharged L99 but once you get used to them, they are amazing. I had the 3.73s before this and would not go back.
Fuel milage is not a huge difference, slightly better in town, slightly less on the highway, averages out about the same depending on how much of each you drive.
Dramatic kick in the rear compared to factory 3.27 gears!!! 1st gear can be pretty wild, almost uncontrolable if you mash the throttle so you have to be careful.
Fiftydriver
2010 SSRS, RJTC, L99, Maggie 2300 SC, 3.4" pulley, Roto-Fab CAI, Dynatech Supermaxx LT headers, Dynatech High Flow cats, Corsa Cat back exhaust, Dual Elite Engineering catch can, MSD wires and Jannetty custom tune, JRE custom diff w/ posi mod, 3.91 LPE gears, Pfaht trailing arms, Pfaht trailing arm and Diff bushings, drop springs and sport sway bars front and back, Fesler dual guage pillar pod w/ AM Cobalt Boost and A/F guages.
More to come!!
Fiftydriver is offline   Reply With Quote
Old 04-02-2012, 05:59 PM   #14
SGOS252382
SGOS252382's Avatar
Drives: 2010 Camaro 2SS/RS
As mentioned. Be careful.
The L99 A6s has a very aggressive 1st gear and it can easily become useless with too much gear.
Need a SS M6 Rear end with 3.45 stock gears steeleshark2 Transmission / Driveline 11 11-03-2011 07:55 AM
2010 v6 0-60 with 3.73 gears gjarzabek009 V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6) 29 04-07-2011 09:16 AM
Do you want the Z28? ChrisB Camaro ZL1 Forum - ZL1 Specific Topics 1616 09-04-2010 11:49 PM
SS chirp gears? CamaroEnergy4Life 5th Gen Camaro SS LS LT General Discussions 46 03-08-2009 07:42 PM
