Old 01-20-2012, 05:57 PM   #1
nightshift
nightshift's Avatar
Drives: Victory Red 2011 2SS/RS
Fuel/ Air Mixture/Check Engine Light/Mods
I posted this in the Engine mods section but it's probably better off here.
Last week I installed and Airaid intake and today I installed a Solo Axel back with J pipes. Shortly after the exhaust install, my check engine light came on. Onstar said my vehicle is running lean (Fuel/Air) based on the codes. I contacted Solo and asked if this was something they have come across with their system. I was told they have not encountered this issue and perhaps there was an exhaust leak.
I took it back to the exhaust shop and had them check. There is no leak. Onstar said based on the modifications, the computer may reset itself in a few days/miles after it adjusts to the increased airflow.
Has anyone encountered anything like this? I'm hoping the ship rights itself as I don't want to go to the dealer or have to troubleshoot this issue with the vendors. Thanks,
-Nick
nightshift is offline   Reply With Quote
Old 01-20-2012, 07:11 PM   #2
Steck
Drives: 2006 twin turbo Corvette Z06
You most likely have a vacuum leak on the intake system after the MAF.
Steck is offline   Reply With Quote
Old 01-20-2012, 10:36 PM   #3
67badbird
67badbird's Avatar
Drives: 2010 Camaro 2SS/RS 1967firebird 632
Yes this happend to Me after mods....I cleard the code {P0171} and it has not came back on.
67badbird is offline   Reply With Quote
Old 01-20-2012, 11:19 PM   #4
evilbeef54
tail lights for u
evilbeef54's Avatar
Drives: Bumble Bee 2010 2SS/RS
i too just got a CEL, i installed Kooks LTs and HFCs about a week ago, no CEL drove a few hundred miles probably since the install. Put on my CAI intake and scoop yesterday and driving around today i got a CEL, not sure if it is from the headers or a leak, after reading this i need to go check my intake again to see if there is a leak
1972 Camaro 350/Muncie M22 - SOLD
1986 Camaro RS - R.I.P.
1994 Camaro Z28 - SOLD
2010 Camaro 2SS/RS RY M6- LOVIN' it
Kooks LT's & HFC's, Flowmaster Single chamber mufflers, C.A.I. Intake, ADM Scoop, Rotofab w/w relocate
Semper Paratus
You have to go out You don't have to come back!!!
evilbeef54 is offline   Reply With Quote
Old 01-21-2012, 12:36 AM   #5
bluetorp
bluetorp's Avatar
Drives: 2010 2SS/RS IOM M6
What Steck said. Most likely there's a leak in the intake somewhere past the MAF letting unmetered air in.
Whipple 2.9L S/C, ARH LT's, Flowmaster AMT, HPTuners
bluetorp is offline   Reply With Quote
Old 01-21-2012, 02:12 AM   #6
nightshift
nightshift's Avatar
It was the intake. The hose clamp attached to the throttle body was loose. CEL reset itself after about 70 miles and light is gone......thankfully. Runs and sounds great! I'm always impressed at the knowledge on this board. It is the best resource out there for these cars. I appreciate the tuners and vendors chiming in with their input. Thanks!
-Nick
Old 01-21-2012, 03:58 PM   #7
evilbeef54
tail lights for u
evilbeef54's Avatar
Well I double checked the installation of my CAI and re-adjusted and tightened everything...
then i found my LM2 WBO2 and scanner it was a p0420 which is a cat efficency code, so it is probably from the LTs and not being tuned, I cleared the code we will see if it comes back, i guess it was just coincidence that it poped up right after doing the CAI install
Semper Paratus
Cold Air Inductions Intake System! ADM Performance Cold Air Scoop! & Packages! AutoAgenda V8 Bolt-Ons & Tunes 438 11-23-2013 10:49 PM
Hot air Intakes -By Kenne bell ADM PERFORMANCE Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 66 02-08-2011 08:33 PM
Check engine light on Boricua Camaro Issues / Problems | Warranty Discussions | TSB and Recalls 4 08-28-2010 01:12 AM
Stock Injectors vs Magnuson Kit Injectors Mark-HD Forced Induction - V8 24 01-27-2010 08:04 PM
Camaro ls3 news...true or false? Dark Knight Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 74 06-05-2008 05:29 PM
