Old 01-21-2012, 01:18 PM   #1
verboten
Drives: Black
What year cts-v brakes fit camaro?
Wtb: ss or cts-v brakes.
2004-2007.
verboten is offline   Reply With Quote
Old 01-21-2012, 01:33 PM   #2
nebchevy
nebchevy's Avatar
Drives: 2011 2SS SGM Camaro
Why would you want to but cts on your camaro
nebchevy is offline   Reply With Quote
Old 01-21-2012, 01:35 PM   #3
ShnOmac
ShnOmac's Avatar
Start your research here...
http://www.camaro5.com/forums/showthread.php?t=71401
ShnOmac is offline   Reply With Quote
Old 01-21-2012, 04:29 PM   #4
verboten
Drives: Black
The 2004-7 appear to be same as SS brakes, except in silver?
Old 01-21-2012, 04:32 PM   #5
verboten
Drives: Black
Originally Posted by ShnOmac View Post
These are newer 6 piston cts-v brakes. 2009+
Old 01-27-2012, 12:59 AM   #6
JusticePete
JusticePete's Avatar
Drives: Camaro Justice
2009 CTS-V brakes fit the 2010 on Camaro.
Old 01-27-2012, 01:00 AM   #7
JusticePete
The fronts on the CTS-V and now the ZL1 are six piston. The SS fronts are four piston. The rear calipers on the CTS-V and SS are the same.
Old 02-06-2012, 09:08 AM   #8
ChapelSS
Drives: 2011 Camaro 1SS M6
I used the 04-07 CTS-V rear calipers on my 1SS. I only needed to do the standard flip on the bleeders and hard line. Additionally; I have not heard this mentioned before but the 04-07 rear calipers have to be notched for clearance as was the original SS calipers. I found it to be alot cheaper to buy these calipers than the much newer versions when the only difference is a factory machined notch.
ChapelSS is offline   Reply With Quote
Old 02-06-2012, 04:46 PM   #9
DougDanger
Drives: 2011 2SS RS
Can you post pics of where you notched the calipers? and did the rear CTS-V go on your front? original rotors or CTS-V rotors? Any other specs when looking for those calipers ie 17 or 18 inch wheel on the CTS-V?
Also Pete said "The rear calipers on the CTS-V and SS are the same" I asked that on another thread and Pete said they where 4 pots?
Thanks trying to get this sorted and installed - Doug
DougDanger is offline   Reply With Quote
Old 02-06-2012, 04:51 PM   #10
JusticePete
the 2009 CTS-V rear 4 pot calipers are the same as the SS rear calipers. The connecting tube on the CTS-V rear calipers has to be flipped on end to the other dure to the different mounting position on the Camaro SS. The rear CTS-V rotor is NOT compatible with the SS so you use the OE SS rear rotor.
Up front, the 2009 CTS-V 6 pot caliper is different than the SS 4 pot front. The CTS-V uses a larger front rotor. The CTS-V rotor fits on the SS hub and is required for use with the CTS-V six pot caliper.
We used the 2009 CTS-V brake setup, because we had a fair idea they would be used on the ZL1.
Old 02-06-2012, 05:23 PM   #11
DougDanger
Drives: 2011 2SS RS
Ok I am almost with you on everything but if CTS-V rear are 4 pot and so are SS then why put the CTS-V rear calipers on the SS?
Thank you for your patience, I am sure I am not the only dumb one in class today.
Old 02-06-2012, 05:49 PM   #12
JusticePete
The ONLY reason to sway out the rear SS calipers for the CTS-V rear calipers is to match the color. It has or had nothing to do with function.
Old 02-06-2012, 05:58 PM   #13
blackTT600
Drives: 2011 2LT M6 SC
JusticePete, are the front 04-07 CTS-V 4 pistons the same/will they fit on the rear?
blackTT600 is offline   Reply With Quote
Old 02-06-2012, 06:59 PM   #14
JusticePete
I don't know. We only did the 2009 on conversion. Sorry.
GT5 Camaro pics brantley847 Camaro Photos | Spyshots | Video | Media Gallery 93 05-27-2013 08:35 PM
Over 230 Satisfied 2010 Camaro Customers! Paddock Chevrolet has 40 in stock NOW camarojoe Dealer Camaros for Sale 2 05-24-2010 05:58 PM
