![]() Drives: 2011 LS CGM / '01 Trans am (ls6) Join Date: Jul 2011
Yesterday I installed my new shifter, the quality of the product is great and i love how short the throws are. I do have a pretty bad noise coming from it though, even around 1500 RPM's i can hear a slight noise. I tried teflon tape on the thread of the shift nob and it didn't make a differnce.. Just looking for some tips because i don't think i can keep it on if i can't fix the vibrations. I'll upload a video when i get a chance of WoT
Thanks for any assistance! |
NEcamaro5
That's the first time I've ever herd this from a Barton. Mine sounds and works great. I'm thinking maybe check the centering springs if you reused them
The centering springs were not even reused, could that be the problem?
![]() ![]() ![]() ![]() ![]() Drives: White M6 1LT RS Join Date: Mar 2010
It might be. I reused mine. The springs do put pressure on the shifter and that might prevent it from vibrating/making noise. Does it vibrate when you wrap your hand around the rod. If it doesn't then reusing the springs will help. I think.
Pfadt Sway Bars - FE3 Suspension - Barton Shifter - IdealG's Clutch Master Cylinder - Trifecta - Vmax TB - Vararam Intake - MACE 25mm Insulator - Plenum Insulator - Ported/Gasket Matched Intake Manifold - Rx Catchcan - AAC DRL's - 4 Pack Aux Gauges - Steering Controls - AAC Afterburners - DIY Led Sidemarkers - ZL1 Front End
Next mod: Done! |
There is a slight vibration but it's not nearly as bad as the sound coming from the shifter
#6 | |
Is it a rattling sound?
Next mod: Done! |
#7 |
Yeah, i'll post a video in just a minute that i took on my phone
#8 |
Then its vibrations that are causing the noise. Try reinstalling the centering springs.
Next mod: Done! |
#9 |
Okay I can't get the video to upload but i'm going to put the springs in tomorrow and hopefully get some positive results.. thanks for all your help
#10 |
![]() Drives: '10 1LT/RS Join Date: Apr 2010
Most do NOT re-use the centering springs. I didn't put mine back in, and no vibration. This is the first time I've heard of significant vibration with the Barton.
Remember, a short throw shifter will amplify transmission noise, but it shouldn't be annoying. I would check that the bolts underneath (that hold the bearing in place) are tight. If the bearing didn't seat completely when you installed it (from under the car), you may have those two bolts tight until the bearing seats, which will leave those bolts loose. Worth a check anyway. |
#11 |
Okay thanks because i put the springs back in today, i had my dealer do the installation but so far it's been a night mare for me ever since i put this shifter in... Springs didn't change anything
#12 |
I had a vibration that went away with centering springs.
Next mod: Done! |
#13 |
I think it got worse? After having the shop do it the car wont go into 5th or 6th on top of that the whole thing ended up bein loose
#14 |
![]() ![]() ![]() ![]() ![]() ![]() Drives: 2010 2ss/RS 4l80. 2009 2500 HD Join Date: Mar 2009
Who installed it?
Follow along as we build and race this 2010 Camaro!
https://www.facebook.com/pages/FNSS-...75028626000379 FNSS Racing! |
| NEW MGW short throw shifter - never installed | dennismcadams | Transmission / Driveline | 2 | 09-09-2011 09:12 PM |
| FS - Barton Short Throw Shifter | macwest | Transmission / Driveline | 4 | 04-07-2011 07:03 PM |
| Ordered the barton Short Throw Shifter. | Jarhead | V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6) | 10 | 04-22-2010 09:40 PM |
| If you installed MGW short throw: | Infern0 | Transmission / Driveline | 14 | 03-07-2010 11:22 PM |
| Just Installed My Hurst Short Throw Shifter | Blueclyde | V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6) | 3 | 02-17-2010 08:47 PM |
